ASUS Rog Strix G17-712LV Laptop Liquid damaged
  • XxMicroSoldering
    • Oct 2022
    • 38
    Hello Guys
    I have a ASUS Rog strix laptop that I bought recently to fix and the previous owner spilled water on it . He brought it into a repair shop for them to check it out and instead of fixing it they damaged the battery connector of the laptop ! Other than that they damaged damaged nothing . But since the liquid damage the laptop only turns on and the keyboard lights up and then immediately turns off. I really want to repair this laptop and I also have experience in repairing phones etc and laptops and a bit of soldering but the diagnosing part is where I need help with and how can I find out wich diode / resistor is broken. I did some visual inspection under my microscope and find out this part was corroded ! How to start from here and how to fix it now ? Btw my multimeter is Manuel
    all help is appreciated
    thank you very much in advance !
    • 21874
    What is the motherboard model number
    • XxMicroSoldering
      • Oct 2022
      • 38
      Model number is G532LWS
        • 21874
        The schematic and boardview will help https://www.badcaps.net/forum/troubl...atic-boardview
        • XxMicroSoldering
          • Oct 2022
          • 38
          Thanks for that ! I still don’t know how to diagnose this problem and fix it . Do you know how ? And what to start with ?
          • reformatt
            • Feb 2020
            • 1497
            Liquid damage can result in a dead CPU or GPU so make sure the power rails for either aren't shorted as it's usually game over at that point. GPU's however can measure under an ohm to ground though and be perfectly normal. What to look out for is shorted FET's/DRMOS in the CPU or GPU power delivery. You have liquid damage around the GPU power controller so that's not a great sign.
            The way I deal with liquid damage is to photograph each area first for reference (so I know what components were affected prior to cleaning). Then I use a mixture of de-ionised water and Chemtronics Flux Off with a small toothbrush, clean off with a Kim Wipe. You have to be careful if you don't have a schematic or boardview as this can dislodge a component that's corroded. Assess each components end cap and solder connection and replace as necessary. QFN's liquid damage often results in destruction under the high current connections (like Vin, Vcc etc) so may need to be removed. Any BGA that's had liquid under it needs to be removed and reballed (I just did another Asus ROG laptop with onboard RAM, had to remove 8 RAM IC's and reball to get it working).
            Once you have dealt with all liquid affected areas, then you power on, and use the power sequence in the schematic to see what is present, and where it stops.
            EDIT: BTW, an ultrasonic cleaner is the last thing you do with such a board. It wipes away all evidence, and in some cases, can introduce faults. I use it only as a last resort these days.
            • XxMicroSoldering
              • Oct 2022
              • 38
              Thank you very much for your reply! Thing is I don’t know how to measure with a multimeter and especially with that of mine. Can you maybe explain to me a little bit on how to do this
              thanks you
              • reformatt
                • Feb 2020
                • 1497
                https://learn.sparkfun.com/tutorials...multimeter/all
                Sounds like you might need to spend some time on simple faults (non liquid damaged devices) before you make an attempt to fix this board. Liquid damage is challenging and require a lot of knowledge, even for experienced techs.
                • XxMicroSoldering
                  • Oct 2022
                  • 38
                  Yes but I really want to repair this laptop ! So where to start ?
                  • reformatt
                    • Feb 2020
                    • 1497
                    Already gave you that info in post #6. Did you miss that?
                    • XxMicroSoldering
                      • Oct 2022
                      • 38
                      So what your basically saying is photograph all the parts that were affected by the water and then go replace all the parts wich are corroded with the same value parts ?
                      • rogfanther
                        • Jul 2006
                        • 458
                        • Brazil
                        As he said, photograph then clean the board. The photos are to see if some component doesn´t get dislodged when cleaning.
                        After that, inspect solder points to see if some are damaged.
                        From the pictures, you have corrosion on some components that are not so easy for a beginner to replace. Try to clean it well, and test your luck.
                        But as said, it would be better to start with something easier to get a little more experience before tacking this one.
                          ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook Strix G15 Specification for Upgrade or Repair
                          This specification for the ASUS ROG ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD boardview and ASUS ROG Strix G15 G51 NVIDIA GeForce RTX 3050 Laptop GPU AMD Ryzen 5 5600H 8Gb 512GB SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated...
                          09-07-2024, 01:00 AM
                          ASUS ROG Hero II GL504GM-DS74 Gaming Laptop Notebook Strix Specification for Upgrade or Repair
                          This specification for the ASUS ROG Hero II GL504GM-DS74 Gaming Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Hero II GL504GM-DS74 Gaming Laptop boardview and Hero II GL504GM-DS74 Gaming Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                          09-06-2024, 07:00 AM
                        • Technodoc
                          ASUS G614JZ G634J-PMV-VGT Rog Strix need some bios help, laptop black screen
                          by Technodoc
                          Asus laptop G614JZ-N3012W Rog Strix with i7
                          Mainboard G634J-PMV-VGT
                          6050A3441302-MB-A01
                          2023-02-10
                          Power button works okay....power light goes on
                          Red "bottom" leds go on
                          Charging led works
                          Fans do not spin, capslock key does nothing, screen stays black
                          I would like to program the bios again, to rule out a corrupted bios.
                          However I run into a size error
                          The bios chip is a Winbond 25R256JVEN
                          Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
                          02-24-2025, 04:46 AM
                          ASUS ZenBook UX433FA-DH74 Ultra-Slim Laptop Notebook 14 Specification for Upgrade or Repair
                          This specification for the ASUS ZenBook UX433FA-DH74 Ultra-Slim Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX433FA-DH74 Ultra-Slim Laptop boardview and UX433FA-DH74 Ultra-Slim Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                          09-06-2024, 07:33 AM
                          ASUS ZenBook UX331FN-DH51T Ultra-Slim Laptop Ultrabook 13 Specification for Upgrade or Repair
                          This specification for the ASUS ZenBook UX331FN-DH51T Ultra-Slim Laptop Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the UX331FN-DH51T Ultra-Slim Laptop boardview and UX331FN-DH51T Ultra-Slim Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
