ElectroVoice ETX-18SP (powered Subwoofer) damaged after lightning strike
  • pfl
    • Jul 2017
    • 10
    • france
    Hello Everyone.
    This powerful amplified subwoofer doesn't make any sound after lightning striked near the house were it was plugged in.
    It consists in :
    • a power board were the full H bridge class D amplifier and main power rails are located
    • a preamp board (ref. F.01U.299.771) receiving 2 symetrical inputs(IN1, IN2), a digital chain (A-D converter -> Digital Signal Processor -> D-A converter) and a micro controler in charge (at least) of the human interface (lcd display and 1 rotating button)
    Power rails are ok.
    human interface is working fine
    Input levels are displayed on the screen whenever a signal is applied on either inputs
    But ...
    1. a red led is blinking (every seconde) what does it means (nothing good i guess)
    2. The 2 analog Inputs on the A-D converter (pcm1802) seem wrong : one is somehow IN1+ IN2 in common mode the other the same at very low level and noisy ; what are these inputs supposed to be ?
    3. Is the entire program for the DSP (DSP5674) stored in the external SPI eeprom or is there some code stored in DSP rom ?
    4. there's a relay (coil unactivated) : what is its purpose ?
    If someone has got answers or even better owns the service manual and is ready to share it it would be christmas time (again)
    Thanks for your time
    pierre-françois
  • Bardou Kari
    HP EliteBook 840 G6 – no power after lightning strike
    by Bardou Kari
    I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
    – Charger is OK and 19V is present at the motherboard.
    – No charging LED, no fan, no reaction.
    – I don’t see any 3.3V or 5V near the coils.
    – Battery is unplugged.
    – I’m new to board repair but can use a multimeter.
    I added a clear photo of the board.
    Any idea where to start or what to check next?
    Thanks a lot for your help!...
    07-01-2025, 10:45 AM
  • SluggerB
    Panasonic TH-50PX80 killed by lightning strike, help me save her!
    by SluggerB
    Yes it's a 17 year old Panasonic plasma!
    I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
    06-04-2025, 07:02 PM
  • karthur
    Samsung UN60EH6000 wont come on after lightning strike.
    by karthur
    We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
    I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
    When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
    Here is what I have checked.
    On the power supply board, 14pin connector:
    1 :12.7 Vdc
    3 :12.7
    5 :12.7
    7 :12.7
    9 :0
    11 :5.
    13 :5....
    11-01-2023, 06:18 PM
  • MrCreosote
    Lightning Strike: 55" TV dead: is display panel OK?
    by MrCreosote
    THE LIGHTNING:
    This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
    Very close and probably a very strong EMP.
    THE TV:
    No standby LED. Some voltage from PSB (not totally dead).
    But found a kit of ALL 4 circuit boards for $55.
    At first thought, this will fix my TV.
    But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
    08-16-2021, 10:27 PM
  • pbig
    advices for repairing Sony Bravia 32EX600 after lightning strike
    by pbig
    hi everyone,
    my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
    On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
    - the 450V/150uF capacitor voltage when plugged is normal at 394V
    - from connector CN6150 (15 poles)
    STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
    06-28-2023, 02:43 AM
