Re: Adding a bigger panel for a new house.
I gotcha. It's a bit hard I think because we use different terminologies. Maybe twist nut over there means something different than what it means over here? I believe the consumer unit, over here, we just call them panels. Like a 200-amp panel. That's where the wire from the meter goes to. If you run it to another panel after that, I believe that other panel is called a sub-panel. For ring, I'm guessing you're meaning just a circuit, right? From the breaker to where ever the lines go? Not sure what a spur is.
Normally, if I can, I'll just jump from one outlet / light switch to the next, within reason. I try to figure out how much load each outlet will have at one time and not go over a limit. But there's times when there's no outlets to jump off of. When you want to run a new wire and yeah, you could open up walls or dig up ground or just splice into a wire. That's where wire nuts come in handy here.
