Geiger counter battery
+ More Options
Posts
  • pentium
    • Mar 2006
    • 2778
    Today I saw for $10 a locally made (assembled in Vancouver) geiger counter.
    It looks in good shape (I have yet to see if the tube is still good) but it uses one of those oddly shaped batteries.
    I have no idea what the battery type is and I doubt they still sell the things for anything less than $50 a battery. What is the actual make of the battery and what could I use to substitute it with say, a few D cells?
    Find Nedry!
    Check the Vending machines!!
  • Wizard
    • Mar 2008
    • 2296
    Re: Geiger counter battery
    AWESOME. You found it in tube era! That's wax capacitors!
    Cheers, Wizard
    • pentium
      • Mar 2006
      • 2778
      Ir also came with a really nice (and really old) headset.
      Now about that battery....
      Find Nedry!
      • Scenic
        o.O
        • Sep 2007
        • 2642
        any model numbers or something else written on those batteries to search for on google?!
        • pentium
          • Mar 2006
          • 2778
          Ther is a stamp inside the case that tells me:
          Model: 5
          Serial 102
          Volts...
          I don't get it. the required voltage is not stamped on the thing.
          I honestly don't have the slightest clue on what it needs and the company who built this went out of business a long time ago.
          Find Nedry!
          • Scenic
            o.O
            • Sep 2007
            • 2642
            umm... i meant under the sticky tape on the batteries, not somewhere else
            • pentium
              • Mar 2006
              • 2778
              There was no battery installed when I got the unit and those two yellow things are, as mentioned, wax capacitors.
              The battery plugs into the black and red leads seen in the photo.
              Find Nedry!
              • pentium
                • Mar 2006
                • 2778
                Also, the capacitors are rated for 600 Volts....
                Find Nedry!
                • Wizard
                  • Mar 2008
                  • 2296
                  Wax caps can give problems and simply replace it with electrolytic.
                  Um, Anything else on that could say what brand of and model?
                  Cheers, Wizard
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    probably some sort of radio "b"
                    battery.
                    45 or 90 volt
                    • zandrax
                      Hit and miss
                      • Dec 2007
                      • 1157
                      • Italy
                      Running at zinc-carbon battery was too expensive since they were (and are) disposable and NiCd were expensive in the '50s and '60s (the era of your conter judging from appeareance: NiCd batteres arrived in Usa from Sweden in 1946), so I suppose it uses plain lead-acid batteries, the most common and cheap rechargeable battery at the time: there should be a transformer upping the tension from battery to 400-500 V range. Still unsure about voltage: 6, 12 or 24 V? Maybe more photos can help us.
                      You wrote it was manifactured in Vancouver: according to an hobbyst site, there is Canadian counter manifacturer, Bicron Instruments now Thermo Scientific, but I don't know when and where it settled. The "model 5 - serial 102" means there was a small production and this was the fifth model made: no other information at all?
                      Zandrax
                      Have an happy life.
                      • zandrax
                        Hit and miss
                        • Dec 2007
                        • 1157
                        • Italy
                        10 min time limit ...
                        Hmm, KC8 may be right: never heard of B battery untill now but size and tension may be compatible.
                        Pentium, there is a battery holder in your counter, isn't it?
                        Zandrax
                        Have an happy life.
                        • pentium
                          • Mar 2006
                          • 2778
                          There is no batery clip in the thing at all. Looks like it just big enough to fit in the unit and didn't move around much when the cover was on.
                          As for getting more photos, there is really nothing left to see. Aside from those two large caps, a knob, a resistor, another smaller capacitor and the tube there is pretty much nothing else in the thing.
                          Find Nedry!
                          • zandrax
                            Hit and miss
                            • Dec 2007
                            • 1157
                            • Italy
                            No other text except the model/sn sticker and the Made in Vancouver?
                            Zandrax
                            Have an happy life.
                            • andrew77
                              • Jan 2008
                              • 81
                              I don't have any information about the batteries, but maybe this link will help figure it out?
                              link
                              • arneson
                                • Sep 2005
                                • 1267
                                It's possible that you have only the probe, and the counter was a shoulder strap unit that contained power?
                                Jim
                                • pentium
                                  • Mar 2006
                                  • 2778
                                  Aside from a plug that you connect your headset to, a handle, three holes underneath the box that are covered in bakelite (the tube is on the other side) and the knob I mentioned earlier, there is really nothing else special about the box aside from a tag that reads:
                                  Frederick Goertz Ltd.
                                  Instrument makers
                                  Vancouver, B. C.
                                  It's a complete unit, it just needs a battery.
                                  I would post more photos but my camera is currently charging.
                                  Find Nedry!
                                  • kc8adu
                                    • Nov 2003
                                    • 8832
                                    • U.S.A!
                                    if you can find out the voltage you can rig up something.
                                    a friend has a pocket radio with tubes he had as a kid.
                                    i restored it and made up a set of 9v battery snaps to hook 5 9v batteries in series to make a cheap b battery.
                                    heaters run on a d cell.
                                    he can rebattery it for about $1 with biglots deals.
                                    • pentium
                                      • Mar 2006
                                      • 2778
                                      And that is the thing.
                                      I can't figure out what exactly the voltage needed is.
                                      Find Nedry!
                                      • arneson
                                        • Sep 2005
                                        • 1267
                                        This surplus shop has a couple battery clips and some gieger counter owners manuals at the bottom.
                                        I don't think it's helpful with yours but it could lead you down the right road.
                                        http://www.surplustuff.com/radiolog.html
                                        Jim
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • mkdj
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Tests already made:
                                          - I have removed...
                                          07-14-2025, 09:16 AM
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          09-14-2023, 11:10 PM
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
                                        • ferah831208
                                          by ferah831208
                                          03-18-2025, 01:18 AM
