Geiger counter battery
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: Geiger counter battery
    Frederick Goertz got acquired by Land Measurement System in 2005 when the brand settled in Vancouver: try contacting them, there is a small chance someone in the Vancouver office still remembers old Goertz products or can help you in other ways (eg. address of an old qualified tecnican, old user manuals and so on).
    Otherwise start with low values: try with 3 V from a couple of AA battery, then increase to 6 and 9 V. I think tensions lower than 12 V aren't likely to damage your counter.
    Zandrax
    Have an happy life.
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • mkdj
      by mkdj
      Mark and model: ASUS X571
      Tests already made:
      - I have removed...
      07-14-2025, 09:16 AM
    • techfreak9356
      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
      by techfreak9356
      09-14-2023, 11:10 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • ferah831208
      by ferah831208
      03-18-2025, 01:18 AM
