Ferm One electric screwdriver has no power
  • Antti
    • Sep 2014
    • 52
    • Finland
    Hello!
    My friends screwdriver got water inside and stopped working.
    He loves it so much that it needs to be repaired.
    If anyone has any idea where and what I could measure it would be really helpfull. Motor works fine.
    here is some pictures
  • Antti
    • Sep 2014
    • 52
    • Finland
    Re: Ferm One electric screwdriver has no power
    heres the pics inside the screwdriver
    • megaraider
      • Jul 2015
      • 307
      • Portugal
      [Probably you posted this in the wrong place... ]
      More details needed... but start by:
      look for water damages: corrosion, open/shorted connections;
      measure battery and see if it charges when connected;
      test the power switch;
      I don't think the water damaged any electronic component...
      • Antti
        • Sep 2014
        • 52
        • Finland
        oh, well the admin can change this for the right place
        I dont know how to test the power switch with a multimeter......
        If you can see, the C3 component, is it a smf fuse? if the water did blow up only fuses..
        • fzabkar
          • Mar 2009
          • 772
          Can you tell us the markings on M1, M2, U2, U1, D1, D2?
            • 31046
            there are solder balls and splashes on it,
            it needs to be attacked with a stuff brush & some IPA
              The slide switch is for Forward-Reverse function, and the micro switch is for the Trigger ON/OFF right?
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                u1 and the 2 mosfets is undervoltage protection.if battery low that shuts off unit.
                u2 is the charger.
                probably a tp4056.
                whats the battery voltage?
                • fzabkar
                  • Mar 2009
                  • 772
                  C3 is a capacitor.
                  Not sure if the battery question related to the battery's actual voltage or its spec, but it is a 3.7V 1300mAh Li-Ion type.
                    • 31046
                    crappy spec, you can get those cells upto atleast 2700ma
                    makes me wonder what's in my one.
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      its current voltage.if too low low voltage cutoff occurs.
                      Originally posted by fzabkar
                      C3 is a capacitor.
                      • kc8adu
                        • Nov 2003
                        • 8832
                        • U.S.A!
                        thats a high rate cell.it can probably take 30a continuous and 100a pulse discharge.i have 3500 mah 18650's here but they have ptc protection.
                        i bet a tesla cell would do ok.
                        i put 10 of them in a milwaukee pack 5s2p.
                        they do fine.
                        but that grade of cell is way out of budget for that screwdriver.
                          I would hope that the OP has already tested the Voltage of the battery already before asking for help.
                          • megaraider
                            • Jul 2015
                            • 307
                            • Portugal
                            laughing to myself...
                            scrolled down and no one is helping the guy!
                            btw,
                            gave up using bat on screwdrivers a long time ago:
                            if i 'forgot' to use it... when picked it up » no bat left » do it by hand
                            if i used it for some extensive or long period job » bat died » do it by hand
                            thus,
                            using them with an extensible long power cord connect power source
                              "scrolled down and no one is helping the guy! " The OP never comes back and tell us of what he had tested and test result, hard to help some one when there is no feedback. May be you have crystal ball to know what OP have done so far?
                              OP said he know how to use the meter but does not have enough experience to know if C? is capacitor or fuse.
                              You can help by telling us which component/s on the board are/is bad.
                              • rhomanski
                                nowhere man
                                • 5157
                                • U S of A
                                Sim, sim, salabim, C15 is toasty.
                                sigpicThe Sky Is Falling
                                • Antti
                                  • Sep 2014
                                  • 52
                                  • Finland
                                  I asked the question 2 days ago, gotta go to work. This is only a hobby to me.
                                  The slide switch is for Forward-Reverse function, and the micro switch is for the Trigger ON/OFF right? ---- Yes
                                  I would hope that the OP has already tested the Voltage of the battery already before asking for help. ---- battery is fine
                                  I dont have the time to measure components now, but i do it today..... or tomorrow...
                                  • megaraider
                                    • Jul 2015
                                    • 307
                                    • Portugal
                                    That's a custom problem, i agree with you @budm!
                                    Most junior, not only but mainly, start a thread and forget to give feedback:
                                    either because they lost interest along the way or because they solved the problem.
                                    Seen a lot threads where the last one happened and they failed to leave feedback,
                                    even when prompted by participating (senior or not) members.
                                    Since we are all learning with both our experiences and others this is frustrating imo
                                    Nevertheless @Antti just posted explaining himself and leaving some feedback.
                                    • kc8adu
                                      • Nov 2003
                                      • 8832
                                      • U.S.A!
                                      still no voltage reading.define "fine"
                                        • 31046
                                        put a meter across the battery and tell us the voltage both normally and when the charger is plugged in.
                                        btw, does the motor run if you connect it to something else?
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • GLISIT
                                          by GLISIT
                                          01-16-2025, 02:29 PM
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          Tankless hot water heater controller board not powering up when power is applied
                                          by sam_sam_sam
                                          I recently bought a used tankless hot water heater and the controller board is completely dead no power up when power is applied the display board works however the main controller board does not work correctly at all the fuse is good
                                          I bought a used replacement controller board that also had issues that I was able to fix and now the tankless water heater works correctly now
                                          However I would like to know if I could figure what happened to this controller board if possible
                                          Tomorrow I will take some better pictures of both side of both boards
                                          The...
                                          12-09-2022, 09:14 PM
