Ferm One electric screwdriver has no power
  • Antti
    • Sep 2014
    • 52
    • Finland
    Re: Ferm One electric screwdriver has no power
    Originally posted by stj
    put a meter across the battery and tell us the voltage both normally and when the charger is plugged in.
    btw, does the motor run if you connect it to something else?
    Ok, it was only 3.64 volts, i charged it and waited about 5 mins, and it was still 3.64 volts... weird because last time I checked it, volts were higher and it started almost right away charge the battery.
      • 31278
      so what voltage did you see with the charger PLUGGED IN. ??
      i asked that for a reason - i wanted to know if it was trying to charge.
      • Antti
        • Sep 2014
        • 52
        • Finland
        it was still 3.64 volts when the charger was plugged in.
        Greenlight was flashing like it does when its charging.... but it didnt charge...
          • 31278
          then we are progressing.
          • Antti
            • Sep 2014
            • 52
            • Finland
            I just tested the motor, soldered the battery and motor off and connected them together, motor started rolling, so atleast motor is working
              • 31278
              so it's around the charge/battery controller.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                #27
                replace the tp4056.
                its not charging and the battery is below low voltage disconnect.or is the instant you pull the trigger.
                • Antti
                  • Sep 2014
                  • 52
                  • Finland
                  #28
                  Ok, Is it hard to solder? its a very small piece...
                  • kc8adu
                    • Nov 2003
                    • 8832
                    • U.S.A!
                    #29
                    need hot air.heatsink pad under chip.
                      • 31278
                      not so sure, in the foto it looks like they used thermal paste / glue instead of solder.
                      interesting method, i may try using it myself next time.
                      • fzabkar
                        • Mar 2009
                        • 772
                        Check the output voltage of the charging IC. It should be 4.20V. If this voltage is present, but the battery voltage is 3.64V, then I would think that either M1 or M2 is not being switched on. ISTM that one is involved in charging, the other in driving the motor. The smaller chip probably controls the charging/operating modes.
                        • Tynan Dill
                          by Tynan Dill
                          Assuming...
                          11-22-2024, 01:46 PM
                        • PantherDave
                          by PantherDave
                          Hi all!
                          05-29-2024, 02:01 PM
                        • GLISIT
                          by GLISIT
                          01-16-2025, 02:29 PM
                        • e-repair
                          Broken connector on an electric boat power steering
                          by e-repair
                          Hey, i have to repair an electronic board on an electric power stearing. the package was damaged during delivery and the connector was broken. but i can't find a part. the connector is the same BUT reversed as fiat power steering. I searched on digikey, mouser and aliexpress and i can't find any part similar. it's an uflex electric power steering, but i don't have more reference on the power steering block. if needed, i can buy any complete part just to recover the conector on the board and put it on this board...
                          09-24-2025, 07:30 AM
                          03-31-2024, 02:12 PM
