Is there a site or an instruction book on how to use an oscilloscope? I need help .... I am trying to teach myself electronic profession. I have background in multiple areas and one being electrical wiring and schematic reading.
H-E-L-P! How do I learn to use my new oscilloscope?
Tags: None
Re: H-E-L-P! How do I learn to use my new oscilloscope?
I recommend mjlorton's YouTube channel for beginners. -
It is not very difficult you will pick it up in no time. It is just like using a graph for voltage and time, but this graph is variable according to how you set it. Just remember 1/time = Frequency. Once you under stand those principles the X-Y and triggering will come next. Good Luck.Comment
A couple of othersI recommend mjlorton's YouTube channel for beginners.
W2AEW
EEVblogComment
http://www.ionpool.net/arcade/tech/s...les/scope.htmlComment
BTW, also look up about using scope in the primary side of the circuit.Never stop learning
-David VanHornComment
I am in a similar situation as the OP. I have used analog Hameg scopes in school 15yrs ago. I have a general understanding and can use a scope in controlled environment. On semi-regular basis I have also used automotive scopes on cars, so voltage vs time, current vs time and some basic triggers are not new to me.
I am more concerned about the "rules", the do's and dont's of using a scope. I tried to find some kind of a list on the web, but I could not.
I know that a ground loop is a big no,no, but I do not really know when can it happen. I know, in theory, when a path thorough a scope presents lower resistance then the part on the board the scope can be fried. Does it concern only the primary side of AC powered devices or are also some other situations where a ground loop occurs? What's the situation with an AC powered DC device?
I have a new Rigol 4ch 70Mhz digital scope, it is in the box for at least seven months because I got some scare that I'll fry it.
Now there is a signal generator that arrived a few days ago, for which I also have to find what shall I never do with it before I power it up for the first time.
Any kind of help would be much appreciated,
SasaComment
Or remove the earth pigtails from the probes.
Use the probes on both channels
Use the probe tips to obtain measurements while setting the scope MATH function to A - B.
Still have to observe the probes voltage limit but grounding issues are avoidedComment
I expect that would be tricky to get right, in terms of ensuring it does not affect the signal at the least?
A mains isolation transformer is probably the best idea. Easy to use and cheap to buy. At least, mine was about $15 second hand."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
@Chriso:
If I have understood you correctly, when the grounding clip is removed and the probe catches only a signal it is referenced to scope ground. Another probe traces the ground clip's position in the same way through signal wire. Then do the math function as signal minus ground, and the result is the the first signal. That makes sense.
Have I understood it correctly, the dangerous loop can only be made through the ground clip connector, and not trough the signal connector?
What happens with the integrity of the signal if just the signal is measured with one probe, but without ground clip and without the ground component on the other channel? Is it even possible?
@Agent24:
Can you tell me in which cases does the device go through an isolation transformer? What are the drawbacks of routing the scope trough the isolation transformer when the current rating of the transformer is not sufficient for power requirements of the tested device? Is it even recommendable?
Thank you all,
I have learned something new
This link may be useful for isolation transformers and where to put them. https://www.badcaps.net/forum/forumdisplay.php?f=33Comment
https://www.badcaps.net/forum/showpo...&postcount=201Never stop learning
awesome information BudMComment
Nice, thanks!Comment
Hello!
Unfortunately my Lenovo L14 Gen 1 (motherboard NM-C741) was involved in a terrible mishap. At first, one of my friends accidentally spilled coffee on it which made some of the ports stop working but the computer worked fine otherwise. After that I stupidly opended it and forgot to disconnect the battery... One thing leads to another and I accidentally short it between two components (unfortunately I do not remember which components). After that I get nothing, no charging indication, no boot indication, no fan spin, nothing.
So I'd love to learn my mistakes and... -
by SolomonManAll,
Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor... -
Hello.
I have jut got my first analogue oscilloscope. An Isotech 620 20MHz.
I want to learn how not to damage it, and I found instructions on the internet obscure.
They talk about ground, earth, floating ground, this, that....
But they don't actually say anything anything useful so far.
I want to know:
Don't connect exactly this to exactly there or it blows up.
For example, I am tracing a signal from a function generator in an audio amp, or testing for voltages in different parts of a circuit.
I want to know what not to connect... -
by BartoloniHi, i have a Lenovo S145 that after 20 seconds shutdown and restart (it's working correctly on thse 20 seconds)
everything seems ok, but on Vcore inductor ( this is an i3 with just 1 switching power supply for CPU)
there is an output to teh CPU with a spike.. seems that inductor can't handle the input...
replaced the capacitor (330) and the inductor (R15) without any change
any idea? very thank you!
input of the inductor seems as usual... only strange thing is that the upper/lower voltages seems to be 21V (main power line is 19.3) ... but not sure this... -
by repair-itSearched online but wasn't able to find. Trying to locate a copy of this document - AutoLeap Oscilloscope Handout.
- Loading...
