help copying a Circuit
  • predator0357
    • Jul 2014
    • 159
    • Israel
    Hi all.
    I need your help from all the experts around here, i have a that i need to copy and i need some help please to make Schema of it, so if u can help i will be extremely happy.
    The electrolytic capacitor are:
    C1+C2- 100uF 35V
    C3-2.2uF 63V
    there is there like tiny blue thing that i didnt really know i think its 0.1uF 100nF 50V 104 (104 what printed on it) Multilayer Monolithic Ceramic Capacitor and there is round thing that i think its Ceramic Disc Capacitor 50V 103 0.01uF (103 what printed on it).
    there is a blue Square thing that i dont know how its called.
  • predator0357
    • Jul 2014
    • 159
    • Israel
    Re: help copying a Circuit
    the chip is 555
    • predator0357
      • Jul 2014
      • 159
      • Israel
      I want copying it on a DIY Prototype PCB
      • predator0357
        • Jul 2014
        • 159
        • Israel
        Help some1 pls
        • SteveNielsen
          Retired Tech
          • 2327
          You must be patient. People will help if they can, just got to give them time. What is the purpose of the circuit?
          The blue object is a trimmer pot. Can't tell what value. The circuit appears to be a 555 timer circuit. The trimmer adjusts the timing.
          • predator0357
            • Jul 2014
            • 159
            • Israel
            Its for big billboard on the roads. and its controls the timing of the board that have 3 Advertising's.
            like the one on the pics.
            and on the trim pot i think printed 2046B cuz the "4" looks like U
            P.S
            Sorry that i am impatient cuz its related to my new work (i am responsible of maintaining these billboards).
            and tnx u very much 4 the help
            • paulstef
              • Dec 2013
              • 724
              Like Steve said if you tell us what the purpose of the circuit is we can help you better.
              Look here for basic 555 configs: http://en.wikipedia.org/wiki/555_timer_IC
              If you take two pictures exactly from the top and bottom (not taking the photo at an angle like you did) one can easily overlay the two pictures and draw the schematic.
              The circuit is very simple...
              • mariushm
                • May 2011
                • 3799
                So what do you expect from us?
                Use a flashlight or some bright light, put the pcb over the light and you should see the traces through the board.
                Take a sheet of paper and draw the traces.
                The 555 chip is ancient and very well documented and easy to understand, if you'd bother to open the datasheet for it and read it, and if you'd search for tutorials/lesson about it , just type 555 in Google.
                Even the datasheets have example circuits which may even be similar to the one you have.
                Basically, the chip outputs a series of ON and OFF signals, some voltage and no voltage, the blue thing (a potentiometer) simply adjusts how much time the output stays on and how little it stays off.
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  Originally posted by predator0357
                  Help some1 pls
                  I listed the top of the board schematic the best I could. Coloring on resistor was hard to tell. Best to take picture of boards with no flash and in natural light. If you had a way of printing this picture on some transparent paper then print out the bottom of the board on solid paper one could trace out the rest of the circuit. Anyway it is best I could do with the paint program.
                  • predator0357
                    • Jul 2014
                    • 159
                    • Israel
                    i expect from someone to help me copying that, cuz i am a beginner with building Schema from a circuit.
                    and the circuit isn't near me so i cant just put some light under it, i wish i had one that why i am asking from any one here that can help me and experience .
                    And by the way about the tiny capacitors am i right?
                    and again thanks for the help and understanding.
                    • predator0357
                      • Jul 2014
                      • 159
                      • Israel
                      thanks for the help but i need diagram of this circuit to build new one on a prototype PCB.
                        I need STRAIGHT SHOT pictures of the board, top and side and bottom side so I can make virtual PCB to trace out the circuit.
                        Isn't this the same circuit you were asking for help but did not follow through and abandon the thread?
                        https://www.badcaps.net/forum/showthread.php?t=39368
                        • predator0357
                          • Jul 2014
                          • 159
                          • Israel
                          yes its kind of the same circuit
                          but this one is more detailed.
                            Well, then give me the good clear straight shot pictures as I requested then.
                            • paulstef
                              • Dec 2013
                              • 724
                              I don't know if they'll do it, there is too much glare on them... better he takes other pics maybe...
                              • keeney123
                                Lauren
                                • Sep 2014
                                • 2536
                                Last one is a transparency it is just a matter of following the lines and putting in the symbols.
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  predatoro357 I think if you focus straight down on the electrolytic caps making sure they are perpendicular to the board and turn camera so it goes in landscape direction instead of portrait. Try an do it with flash off without power on board so that LEDs are off. If using a flash make sure bright spot is in area where circuits are not.
                                    BTW, what is the board dimension?
                                    • predator0357
                                      • Jul 2014
                                      • 159
                                      • Israel
                                      btw, what is the board dimension?
                                      6.4cm x 4.2cm
                                      • predator0357
                                        • Jul 2014
                                        • 159
                                        • Israel
                                        thanks a lot m8
                                        • samtron786
                                          Ceramic capacitors half short circuit or full short circuit?
                                          by samtron786
                                          Hello
                                          two small ceramic capacitors with values 040. Can you tell me
                                          whether they are half short circuit or full short circuit?
                                          Thank you
                                          01-07-2024, 05:20 AM
                                        • Astonished
                                          Fixing the Charge Circuit of the Batteries of the DC Motor
                                          by Astonished
                                          Hi friends of electronics
                                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                                          Please help me fix this circuit.
                                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                                          01-28-2025, 06:24 AM
                                        • rddube
                                          Lenovo L490 Ram voltage circuit malfunction
                                          by rddube
                                          Hello friends,
                                          Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                                          I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                                          07-15-2025, 04:41 PM
                                        • Tarot Superstars
                                          Short Circuit tester
                                          by Tarot Superstars
                                          Hello.
                                          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                                          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                                          Link
                                          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                                          https://www.youtube.com/watch?v=0eixDdCpiO4
                                          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                                          09-25-2023, 09:11 AM
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
