Ceramic capacitors half short circuit or full short circuit?
  • samtron786
    • Aug 2016
    • 178
    • germany
    Hello
    two small ceramic capacitors with values 040. Can you tell me
    whether they are half short circuit or full short circuit?
    Thank you
  • lotas
    • Jan 2016
    • 5381
    • Russia
    Ceramic capacitors should not have any resistance.
    • samtron786
      • Aug 2016
      • 178
      • germany
      Sorry SMD capacitor?
      • lotas
        • Jan 2016
        • 5381
        • Russia
        Yes, unless in the circuit or on the board there are some resistors or other components in parallel, if in doubt, unsolder them and check them on the board.
        • samtron786
          • Aug 2016
          • 178
          • germany
          OK thanks
          • thinkcentre
            Dell Optiplex 3060 Micro USFF (IPCFL-CG Motherboard) - No LED / Short Circuit
            by thinkcentre
            this is my first post at Badcaps and in general i am new to fixing electronics. I am looking forward to learn a bit more about diagnosing and repairing :-)
            What I have around is a DELL OPTIPLEX 3060 Micro (USFF), which is not powering on, even not showing any signs of life (No amber / white LED).
            I got a original 65W DELL PSU / Power brick (PA-12 / 074VT4) which hopefull should be the correct one. I could get another DELL PSU with the Partnumber 0G6J41 with the same 4.9mm DC Jack connector as the one I already have, but I dont think that would help (maybe...
            11-09-2025, 12:39 PM
          • Rofix
            HP Probook 640 G5 Short circuit on the 19 volt line
            by Rofix
            Hi everyone, I wanted to ask you for some advice
            on this board: HP ProBook 640 G5
            6050A3028601-MB-A01(A1)
            I have a short circuit on the 19-volt line.
            I initially found and replaced this faulty MOSFET, Q60C10.
            Then, when I powered up the board, I had the same problem. The MOSFET failed and is giving me a short circuit.
            I wanted to ask if it's possible to try to find the faulty component by injecting current, and at what point, so I can check the damaged component with a thermal imaging camera.
            Thanks everyone for the advice.
            06-03-2026, 09:05 AM
          • Geeker007
            9th Gen Dell Optiplex Micro PC motherboard repair: Short Circuit?
            by Geeker007
            Hi All, I have a 9th Gen Dell Optiplex micro PC motherboard which doesn't power on. When I connect the motherboard with power adapter, it goes into safe mode and turns off. So from info I have gathered online, it looks like there is a short circuit on the motherboard. So can you guys help me with figuring out the issue?
            I am new to electronics repair, so my queries could be naive but I am ready to learn.
            So I have a multimeter and a solder with me. But I can try to get a variable voltage power supply with a thermal camera as well. From what I seen online, best way is...
            01-28-2025, 03:31 PM
          • Tarot Superstars
            Short Circuit tester
            by Tarot Superstars
            Hello.
            I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
            The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
            Link
            The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
            https://www.youtube.com/watch?v=0eixDdCpiO4
            My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
            09-25-2023, 09:11 AM
          • fab13
            Nintendo Switch lite charging chip heats up and does not short circuit
            by fab13
            Hello everyone
            Small technical problem on a Nintendo Switch lite
            Here's what I noticed: the USB port has been damaged internally, with a short circuit on the power supply line to the small fuse.
            After replacing the USB connector, the short circuit went away and I can't see any other short circuit in the whole motherboard.
            When I charge the console, it seems to be charging: I get 15 volts and an amperage of 0.450 A.
            Then, after a while, the amperage increases to 1.1 A and the BQ24193 charging chip starts to heat up, as evidenced...
            09-16-2023, 04:59 AM
