hum after recap
  • jeffbrown1966
    • Sep 2014
    • 9
    hum after recap
    I am working on a cheap all in one radio IHOME I think, cd player ext it has one dead channel and had a blown cap and two more had swelling so for practice I decided to try and fix it, the re cap went fine the channel is still dead and now it has a hum, when you change stations it plays for about 2 seconds and then the hum takers over, I suspect maybe another bad cap, maybe the radio plays until a cap discharges and cant recharge, it is almost like a volume control , also It had united (M) caps but not knowing I put in Robertson (ZLG) caps in would that Couse the hum.
    Thank you for reading this.
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: hum after recap
    the amplifier may be bad.
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
      • 30983
      Re: hum after recap
      united / robertson????
      (M) is Matsushita - aka Panasonic.
      ZLG is made by Rubycon.
      • jeffbrown1966
        • Sep 2014
        • 9
        Re: hum after recap
        Yes , Sorry it is Rubycon but the M cap does say United on it.
        I would like to know if it is possible for the Caps I have replaced to cause a HUM, it is in both channels and it was not there before witch leads me to think maybe the amp is bad and now that all the caps are good it is acting up, I will have to test it also but did not know if the capos can cause the hum by using ZLG and not M.
        Thank you and sorry for the mix up on the name.
          • 30983
          Re: hum after recap
          ZLG is a bit extreme, but it may not be the problem.
          have you got any foto's?
          • shelby5041
            clock radio / radio lifespan?
            by shelby5041
            hi
            ive got a modern digital clock radio approx 15yrs old
            my question is how long can a clock radio or a simple radio last ss farcas operating hours?
            since elec components have limited hour lifecspan i would imagine the radio or clock radio would eventually fail.
            the reason i ask is because i have my clock radio on radio function 24/7 for the past 7 years and its still working fine....i leave the radio on ..never turn off past 7years...thats approx 60000 hours
            it uses very little power just a few watts i would imagine that may have something...
            09-14-2024, 03:30 AM
          • eccerr0r
            old X58 triple channel board... memtest86 memory speed?
            by eccerr0r
            Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
            Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
            Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
            06-28-2025, 09:06 AM
          • spleenharvester
            Reverse engineering of 18650 4-channel tester
            by spleenharvester
            Hi friends
            I have reverse engineered this tester, schematic is attached and is complete except for capacitor values. These testers annoyingly have no model number but they are the ones you find on the first page of just about any website if you type in "18650 4-channel tester". There is also a 2-channel variant and a newer 8-channel variant. They are very cheap (about £15) and can measure voltage, current, internal resistance and capacity. They have a multicolour display for all these statistics. They also have terminal blocks so that if you want to use a breakout board...
            05-04-2025, 02:43 AM
          • praveenramavath
            Majority PETERHOUSE GRADUATE Internet Radio (Auna Silver Star) - Stuck at boot "Welcome" Screen
            by praveenramavath
            Hello All,
            I have an issue with my Majority PETERHOUSE GRADUATE Internet Radio, it keeps rebooting at the boot logo Welcome screen. I have an another forum active in other website but due to lack of response I am posting the same here. I am positing a link below that has pictures including all the troubleshooting I have tried, appreciate if someone can take a look and give me any suggestions.
            https://www.hifivision.com/threads/m...-screen.98243/
            Troubleshooting Summary: Majority Internet Radio - Flash Chip
            04-26-2025, 09:08 AM
          • BOSCHNJAK
            by BOSCHNJAK
            ABOUT ME INTRODUCTION FILE
            2
            024 BEV, BIH, SARAJEVO START PROJECT: ELECTRIC VEHICLE TOYOTA 4 RUNNER CONVERSION http://www.bev.ba/TOYOTA4RUNNER/index.html
            2023 BEV, BIH, SARAJEVO START PROJECT: SECRETS AND MANUFACTURING PLANS (AS MY REPLICA) OF THE LIBERTY ENGINE 2.0.
            2022 BEV, PROJECT ?
            2021 BEV, PROJECT ?
            2020 BEV,BiH, Sarajevo: PROJECT IS: HOW TO SWITCH OFF PERMANENT MAGNET FIELD and HOW TO SWITCH ON PERMANENT MAGNET FIELD?
            2019 BEV, Croatia, Ston:, Broce: PROJECT - PROJEKT ELEKTRIČNI GLISER http://www.bev.ba/ELEKTRICNIVANBRODSKIMOTOR/indexHR.htm...
            12-28-2023, 02:09 PM
