Scientology woo-woo meter
  • Hondaman
    • Sep 2008
    • 1092
    Recently, I acquired one of L. Ron Hubbard's E-Meters (aka "Space Cootie Detectors"). Just for laughs. I'm not posting in "laptops and portable devices" because I believe more people will see it in this forum. I plugged it in for hours, turned it on, unplugged it and turned it on, grabbed the "soup can" leads, twisted some dials, touched the alligator clips together, etc. but nothing happened. The meter needle didn't move.
    (This is the Mark 5 [the early model with the hardwood case], not one of the "craptastic plastic" units they made later on.)
    It has 6 rechargeable AA batteries (in series), probably Nickel Cadmium. They are quite old and corroded (from age or sitting). (Also, they are probably not the original power source, but the meter presumably worked in the current configuration). The device has a plug for 120 volts, but I can't find any internal charging circuitry. I would like to just use a battery eliminator (AC adapter) if I can.
    But I can't just use any old AC adapter. After the fifth battery, some power goes to the center post of a rheostat (or potentiometer). The rest of the device takes all 6 batteries to power it.
    I think I would need, effectively, TWO AC adapters. One for 6 volts (5*1.2V) and one for 1.2 or 1.5 volts. But I am not aware of any AC adapters that produce 1.5 volts.
    I'd like to rehab this thing, as a project, for fun. The analog meter movement and germanium transistors (not used since the early 1960s, IIRC, with 0.6 inch exposed leads, not exactly surface mount) do NOT inspire confidence. I would like to use this lousy, ancient analog device that really doesn't do anything to detect "space cooties" or "space alien spirits" that really don't exist. Does this sound like fun to you? Well, it does to me.
    Be assured, I'm not going to join Scientology and hand over $350,000 when I can just watch the South Park "Trapped in the Closet" episode instead. This is just for intellectual curiosity, soldering practice and if successful, a little fun.
    I will DEFINITELY need to mark the wires when I un-solder the board from the meter movement to get this thing apart.
    Any ideas on powering this unit?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Scientology woo-woo meter
    next you have to see if it can detect chip weevils!
    • SteveNielsen
      Retired Tech
      • Jun 2012
      • 2327
      You'll need to trace out the power circuit and draw a diagram if you can and post it, unfortunately the verbal description isn't enough to go on.
        Pictures of the inside the unit , please!
        Watch out the stranger outside your house if they know you have one of their magic box.
        How did you get the hold of it in the first place.
        • SteveNielsen
          Retired Tech
          • Jun 2012
          • 2327
          I wonder if it would detect Zuul, who is inhabiting our fridge.
          • mockingbird
            • Dec 2008
            • 5488
            You might get added to Scientology's Suppressive Person list just for posting this lol.
            • redwire
              • Dec 2010
              • 3912
              I remember it's a skin galvanometer, a simple lie detector. It picks up skin resistance changes and can be fooled, but it does make people spill the beans during "auditing"...
              Something about the panel meter having a very specific response time and dynamics, so I think the operator is fiddling with the knobs, the meter is moving around so it looks like the aliens are part of the action...
              Schematic, patent etc. is here: http://www.cs.cmu.edu/~dst/Secrets/E-Meter/
              Your meter looks like a "clarity meter" , whatever that is.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5085
                • New Zealand
                Try watching a few Tom Cruise DVDs first...
                The best feeling is obtained by watching them go in the garbage can though.
                -David VanHorn
                • Hondaman
                  • Sep 2008
                  • 1092
                  Pictures? I'll try. Hope I don't get into trouble for thread necro, this may take a LONG time. Looks like pots and multi-position switches were made by Allen-Bradley. Does anyone know how old those might be? Also it looks like switch terminals have multiple lugs, this could be time-consuming to draw out.
                  Thank you, redwire, I hadn't seen Professor Touretsky's page in a while. The "clarity meter" is for "Freezone" people who play "ghostbusters" among themselves for something like 90% lower fees. (Long ago, Larry Wollersheim won a court judgment against Scientology, but the "church" removed assets from their California corporation so there would be no money left to pay him. When nobody showed up at the bankruptcy auction, huge parts of LRH's "sacred scripture" [trust me, it's gibberish] became public domain. Anyway.....)
                  Would inkscape be a good choice when going from paper sketches to computer? Is there any other software I should consider for this? EDIT: TinyCAD? FreePCB? I don't need Ratdude's fancy software. If I can export to a format others can use (.SVG, .PDF, even 2-color JPEG) that is best.
                  Thanks!
                  Last edited by Hondaman; 02-20-2015, 01:41 AM. Reason: did my homework, searched for schematic/PCB software
                  • eccerr0r
                    lowest current galvanometer/analog meter (passively powered!)
                    by eccerr0r
                    Most analog meters are actually current driven - a current is needed to deflect the pointer full scale. They can be lots of different values. There are ones that can take several amperes to swing the pointer as they have internal shunts.
                    On the other hand there are many that are rated in microamps for the intent that they draw as little power as possible from the devices under test. Some are 1mA, 500µA, 200µA, 100µA, and the ubiquitous 50µA frequently used in analog VOMs. There are even 20, 25, 30 µA and even down to 10µA. Been collecting a bunch of different ratings and...
                    04-16-2025, 12:41 AM
                  • u666sa
                    HP Envy x360 13-bf0013dx (i7, 8gb) ipa32 la-m024p rev 1b short near PJ1802, type-c not switching to 19 volts
                    by u666sa
                    Laptop is HP Envy x360 13-bf0013dx, hp website link, it's an i7-1250U with 8 gig onboard ram.
                    Platform: ipa32 la-m024p rev 1b
                    Originally you'd plug power supply into it and it would take up to 1.2 amps and then drop to 200 milliamps and then go back up again to 1.2, staying all the while at 5 volts. Pressing power button would results in power LED blinking amber 3 times. 3.3 volt rail, 5.1 volt rail present, main power rail 8.8 volts. Power button test pads near EC chip 2.7 volts.
                    I found a short on the other side:
                    10-04-2025, 05:03 PM
                  • chth96
                    by chth96
                    03-09-2024, 10:03 PM
                  • Superbee_dad
                    Sharp 80” long short flash backlight error - Help
                    by Superbee_dad
                    Hello Sharp TV experts
                    Our Sharp LC-80LE642U displays one short one long flash error code which is a backlight error. I went into service mode and there were 8 lamp error counts recorded. I reset the count to 0 and did a reset. The last monitor error cause was 16 B00014639:12. 16 is the code for backlight error. I tried to power the tv up but went back into error mode.
                    > I checked voltages on the power supply board and they all check out .. including 3.28 volts at the error pin.
                    > There is power to the cpu and T-CONN and no faults found there. The cpu has a flashing...
                    01-24-2025, 11:51 PM
                  • jorpec
                    by jorpec
                    Hi
                    Thnaks
                    01-23-2023, 10:37 AM
