Advice on finding a rotary knob
  • Player2
    • Aug 2009
    • 98
    Hello all, long time no see! Haven't been active here in some time due to a job change, still in the electronics field but not doing board level work anymore. Good to see some familiar names still around, and some new blood as well!
    Anyway, I'm hoping that you guys (and gals) can offer me some advice. I am trying to find a rotary knob, not a potentiometer, for a personal project and after browsing some offerings on Mouser I quickly realized that I don't know the correct terminology for what I'm looking for. I am trying to replace two separate momentary push buttons that function as 'up' and 'down' with a rotary knob. What I'm thinking of is a knob like you'd find in many cars for use with the entertainment systems, or on some home audio equipment, where you can feel clicks or detents as your turn it. Basically each click in one direction moves a selector, or volume, up by one notch, and vice versa in the other direction. In my head, this would have either one input (which goes to ground) attached to two switched outputs, where a click in one direction makes momentary contact between the ground input and one output, and likewise for a click in the opposite direction and the second output. Two inputs and two outputs would also work, if input and output A were linked and isolated from input and output B which are also linked to each other.
    Most of the rotary switches I've seen have several contacts, which I'm thinking would be each position or "click" of the knob as a different output. For that matter, maybe what I'm envisioning doesn't even exist, maybe there has to be an associated controller that says something like "if input changes from contact 'x' to contact 'x'+1, then output 'up' signal; if input changes from contact 'x' to 'x'-1, then output 'down' signal." Dunno, but hopefully someone does!
    Thanks in advance for any help!
    Re: Advice on finding a rotary knob
    It is called ROTARY ENCODER SWITCH. You do need the decoder circuit.
    http://electronicdesign.com/analog/s...otary-encoders
    http://www.edn.com/design/systems-de...ne-from-coarse
    ENCODER I.E.:
    https://cdn.badcaps-static.com/pdfs/...060ac37d37.pdf
      • 31256
      yep, rotary encoder.
      you also need a bit of logic to do what your after.
      one output will pulse for each step, the other will either be on or off at the start of the signal on the first depending on direction.
      it's called "quadrature encoding"
      • selldoor
        Slow Learner
        • Dec 2010
        • 7870
        Not sure how a rotary switch would work as when you went from 0+3 when you click it down it would not be down - only less up?? well I know what I mean. Presumably if you are replacing buttons the required circuit is in place.
        Easiest would be to replace the buttons??.
        Next - could you use a 3-WAY ON/OFF/ON ROCKER SWITCH or an onoffon toggle type switch. That could be connected with the on/off1 to the circuit for one press button and the off/on2 to the other button circuit.
        Does it really have to be a rotary switch? and what voltage are you talking about switching? and is there a size factor?
        • R_J
          • Jun 2012
          • 9607
          I think you are looking for a selector switch with momentary contacts center off
          http://www.digikey.com/product-searc...itches/1114766
          when turned to the right it would go up when released it would be off when turned to the left it would go down. Something like this?
          • ClockChip
            Advice sought - Selector switch knob repair
            by ClockChip
            Hello Everyone,
            I am seeking to repair a knob on an old (circa 1971) Panasonic clock radio (a model RC-6900). The good news is that I have the small, easily lost knob. The bad news is that the knob has come off a slotted post and I need to re-attach it in such a way that I won't have to worry about it coming loose again.
            Here is a picture of the bare slotted post (if I have the term right) the knob should be attached to:
            As you can see, this is an Old School selector switch, which means it's pretty stiff. Put another way: the knob has to fit...
            07-20-2024, 04:52 PM
            NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
            I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
            I bought this from an eBay seller but unfortunately they only had one
            I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
            I bought three of from them to also make battery packs with this output power limit in mind
            I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
            04-23-2025, 05:50 AM
          • CoppellTVRepair
            Troubleshooting PFC with SPC1012T not raising output
            by CoppellTVRepair
            It has been a long while since I posted here to ask anything....hope you can help.
            I have this Samsung power supply that uses SPC1012T as driver for the PFC and it's giving me a problem that I can't narrow down though I've troubleshooted and fixed hundreds of boards similar circuits.
            I am attaching a schematic from a different Samsung board, but the topography is very very similar if not 100% the same and it uses SPC1012T, which BTW is a pinout match to UCC28063 for which there's plenty of information. I haven't confirmed they are functional equivalents, but I strongly...
            03-09-2025, 10:38 PM
          • FrancescoV
            Onkyo HT-R390 no sound output, video output ok
            by FrancescoV
            Good morning everyone,
            I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
            The firmware reported is the following:
            M:1.00/11107BLP
            D:?.??/????????
            O:1.00/11107AL
            The DSP firmware given the question marks seems corrupt.
            On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
            05-11-2025, 02:59 AM
          • mecha1166
            Copper corrosion? Yamaha HS8S Audio 1 output only
            by mecha1166
            OAUD Yamaha HS8S Audio one output only.
            I have pulled the output board. Output txsistors are ok (only 2 main output). Everything measures the same on each side. Customer did not bring in speakers so I cannot go too deep. I did notice a greenish tint on the tip of the solder joints that connect to the COPPER output connectors. All 6 have a greenish tint at the tip - each side has 3 pins each. Anyone else have copper speaker output pins that corrode at the place on the PCB where they are soldered? I will try to add a photo. Thanks.
            08-04-2023, 02:55 PM
