Freeze spray and hair dryer etiquette..
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Just working on a TV at the moment, and I'm faced with the same situation a lot of you are also faced with no doubt......
    TV wont power on, so you take the hairdryer to the back of the power supply and it magically comes on after a few seconds... However, this only gives you the general area of where the problematic component lies. Especially given that the components are so small nowadays.. Same issue when using the freeze spray (thought less so when using the straw)
    I've tried a process of elimination using BOTH, but I never seem to be able to narrow it down to one component successfully.... Any tips or tricks that might help?
    • 31283
    Re: Freeze spray and hair dryer etiquette..
    cardboard sheet to block area's you dont want to heat.
    btw if it works when you warm it then it's either broken solder joints or a bad small capacitor.
    because with silicon stuff it's the other way around - they work when they are cold.
    btw if you get a cheap hot-air soldering unit they come with nozles down to 2.5mm
    http://www.ebay.co.uk/itm/261434050278
    • JonathanAnon
      • Jul 2012
      • 457
      • Ireland
      Just curiuos as to why you would say "small" capacitor specifically. ?
        • 31283
        because if you lose a few uf of capacitance from a 1000uf cap you dont notice - if you lose it from a 10uf cap it's a third gone.
        and small caps are often part of the startup/feedback circuit and have a shorter rated lifespan.
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          totally agree had this on a good few repairs ive have done.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            Got me wondering, would a very low temp soldering tip work for a fast heat test of small parts?
              • 31283
              risky, it's earthed.
              if you put a thermal pad between the iron and part it should work - maybe a bit too well!
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                As I thought, however I do recall it being done by a radio tech I worked with a very long time ago.
                  • 31283
                  maybe his iron wasnt earthed.
                  my last one wasnt earthed, i put a 1meg resistor inline wih the earth so i could work on live wiring!
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    I think it was an ESD-safe iron. He was heating up the face of TO-92 transistor. I asked him about it and he just said, "Don't worry about it!" It didn't matter what I ever asked him about though, that was always his answer.
                    • Topcat
                      The Boss Stooge
                      • Oct 2003
                      • 16959
                      I've got an Acer AL2423W that has this issue.....I've narrowed it down to the inverter board.....but can't pinpoint it.... Cold, no backlight. Once warm, either naturally or by hairdryer, works like a champ.......... I've reflowed the bastard till I'm blue in the face....
                      <--- Badcaps.net Founder
                      Badcaps.net Services:
                      Motherboard Repair Services
                      http://folding.stanford.edu/
                      Team : 49813
                      Join in!!
                      Team Stats
                        • 31283
                        maybe there is a break in a coil and the heat is making it expand and connect.
                          Once you narrow down the area with hair dryer, then I use variable temp soldering iron for pin point, board unplugged of course.
                          I use Q-TIPS for localize cooling:
                          https://www.badcaps.net/forum/showth...NG+LN32B540P8D
                          • Cmat2l
                            Hair dryer in water
                            by Cmat2l
                            Hello everyone!
                            I dropped a hair dryer in the water after using it. I pulled it out fast but it was still hot, plugged in the mains and switched off. Still in warranty but the shop I bought it is in another country. The local repair shops asked 50-60 eur for repair. The dryer cost 60 so I was thinking maybe there is smthng I could do to fix it my self. I took it apart but I reached the point that I cant understand what the problem might be. I dont have electronics knowledge. Just some basic electrical.
                            There are 3 leds that are blinking when is plugged in but it does...
                            09-15-2024, 06:58 PM
                          • Eaglecrest
                            Whirlpool dryer control board
                            by Eaglecrest
                            I have a Whirlpool dryer that runs for a while then stops with a blinking timer screen. The dryer can't be reset by hitting any input and if you pull the plug and plug it back in it also won't respond. Light is on in the drum when you open the door, but no other sign of life. If I leave it unplugged for a period of time, which is multiple days, it runs again. May be able to get a load done, but now seems to be less than full load before it errors out.
                            Since unplugging will get it to work, I am assuming that there is an error condition that is causing the onboard processor to shut...
                            11-05-2025, 07:09 PM
                          • BigPete
                            Panasonic Heatpump Dryer Repair
                            by BigPete
                            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
                            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
                            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
                            Unfortunately the whole machine has to come apart to fix it.
                            I have...
                            11-01-2025, 06:40 PM
                          • CapLeaker
                            Bosch Nexxt 500 dryer blinking start button - no start fix
                            by CapLeaker
                            My Bosch NEXXT 500 dryer quit today, press start nothing happens and the start button just keeps blinking. Not cool. Reset the dryer, same thing.
                            Even so the buttons feel good, my problem was the start button smd tactile switch on the PCB. Cleaned the switch with alcohol followed with Deoxit and the sucker runs like a champ again.
                            I like these easy evening fixes!
                            12-07-2023, 04:38 PM
                          • notallbad
                            Heat pump tumble dryer regas
                            by notallbad
                            Just wondering if anyone has successfully attempted a re-gas on a heat pump tumble dryer.
                            The dryer currently in question runs on R134a.
                            The dryer has been completely stripped down/cleaned/tested and re-assembled however there is no heating/cooling effect so working on the assumption it requires re-gassing. Of course, its likely theres a leak which would require soldering or even the possibility that the compressor has an internal fault even though it is running.
                            I was thinking of getting a car aircon regas kit or probably easier but slightly dearer an hvac...
                            07-16-2023, 01:27 PM
