How Can I Charge this Battery ?
  • mmartell
    • Oct 2013
    • 3189
    I've never much understood this so I'm sure this will be useful to me
    I have a battery from a solar lamp which I think is lead acid but I can't be sure (pic below). I've measured the output of the solar cell and it's just under five volts.
    What math is used to determine charge times for a battery ?
    Re: How Can I Charge this Battery ?
    Looks like the 6AH may be hard to get:
    http://www.longwaybattery.com/en/new...wsTypeName=FAQ
    http://www.longwaybattery.com/en/pro...me=GB%20Series
    • mmartell
      • Oct 2013
      • 3189
      This battery was stored for several years before the lamp itself went in service so I think it may no longer be good but I want to attempt to charge it externally before I move on.
      So how do I charge this up ? Can I use a walwart charger at 4.5v and how long would I leave it on ? If it's based on the mA of the charger what is the math to figure this stuff out ? Thanks
        • 31009
        the datasheet should give the charging details.
        if not, get a datasheet for the equiv from yausa
        • joshnz
          • Feb 2011
          • 969
          • New Zealand
          Give it 5 volts and limit the current to less than 1 amp
          My pc
          CPU : AMD PHENOM II x4 @ 3.5Ghz
          MB : ASUS M4A89TD PRO USB3
          RAM : Kingston ValueRAM 16gb DDR3
          PSU : Cooler Master 850W Silent Pro
          GPU : ATI Radeon HD 6850
          • joshnz
            • Feb 2011
            • 969
            • New Zealand
            Charge current divided by the capacity plus 20 percent.
            so 6AH +20% / 500ma = 14.4 hours
            My pc
            • mmartell
              • Oct 2013
              • 3189
              Thank you thank thank you ! I wasn't really sure how to phrase what I was looking for
              So can a wall wart work to charge this battery or would that be a problem ?
                Ideally you should use a current-limited bench power supply. The typical wall wart isn't regulated or properly current limited.
                • mmartell
                  • Oct 2013
                  • 3189
                  I have an atx ps that needs recapping maybe I'll start there.
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    If you have a wall wart that dumps out the voltage you need (use a meter to make sure, use the voltages printed on the battery as a guide), you probably can just stick a resistor, perhaps a 50 ohm 1W or so (depends on what wart you're using) in series as current limiting and use that to charge. Make sure that you disconnect it before it starts getting warm to prevent overcharge.
                    Yes that battery does look like sealed lead acid (AGM) from voltage and current capacity, but likely it's fairly sulfated by now. If it doesn't show any voltage across the terminals it's probably sulfated and a lost cause. Some people had luck with desulfators but most of my dead SLAs have other issues that the desulfator circuit do not help with...
                    • techfreak9356
                      Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                      by techfreak9356
                      I bought a Vostro 3400 motherboard (LA-K033P) to upgrade over my damaged Inspiron 5593 (LA-J091P) board. Everything else is ok except for the battery. This battery I am using now is already a replacement one since I disposed of the bloated original one. Back in the Inspiron 5593 motherboard, the battery charges fine and is identified just fine. However, with the upgraded motherboard, suddenly the replacement battery is labeled as "Not a dell battery". When I borrow a similar battery from my colleague (which did not have replacements yet), it is identified and charges just fine.
                      09-14-2023, 11:10 PM
                    • razenxd
                      How can I charge that battery pack?
                      by razenxd
                      it's not a laptop/desktop related question but I figured that someone here will have the right knowledge.
                      At work we use a few Aldebaran(now Softbank/United Robotics group) Nao Robots which they use some custom 6S li-on battery packs.
                      Nao robots tends to draw from the battery even if they are shut down, and the BMS tends to be a little aggresive, if the pack stays on a turned off robot for 3 months it's gonna lock and will refuse to charge.
                      Now, I have noticed a few things.
                      The "dead" battery, while connected to charger and NOT Charging will...
                      12-05-2024, 06:11 AM
                    • ruletero
                      Acer a515-43 low battery charge voltage
                      by ruletero
                      Hi
                      Acer A515-43
                      LA-H801P
                      Fail: Does not charge battery, has low voltaje on connector.
                      Laptop didn't want to turn on, only charge led blinked.
                      I found PQB5 (mosfet high battery charger) in short, voltaje in +12.6V_BATT was 19 v ...
                      I changed it, changed PQB6 too and now battery charger voltage is 4.4V but battery is 3 cell, 11.25v, then is very low to charging.
                      Laptop turns on without battery and works fine, but with battery turns on and turns off inmediately, I suspect battery bad but I don't know...
                      10-24-2022, 02:31 PM
                    • Klevjetack
                      Charge a L19D3PDA battery externally from the laptop
                      by Klevjetack
                      Is there a way to externally charge a L19D3PDA battery from the laptop. I have a broken charging port on my laptop and am trying to find a way to charge the battery for it. I have been doing some research and I have found that there is a module, TP4056, that can be used to charge Li-ion batteries. It says it is used to charge single cell Li-ion batteries. The L19D3PDA battery is a three cell battery. Is it possible to use the module to charge my battery and it would just be very slow? Or would that be a bad idea. Is there a different kind of module I can use to charge my Li-ion three cell battery?...
                      03-05-2024, 07:26 AM
                    • dclass-pro
                      Latitude 3301 not charge battery
                      by dclass-pro
                      Hi guys I have this dell that with the battery charged it turns on correctly, but if I connect the charger I get the charging symbol but it doesn't charge the battery.
                      I found the shorted charger PU4401 ISL9538h that had pins 14 and 15 shorted and I replaced it. but it still doesn't charge.
                      I noticed 2 things:
                      1) without the battery connected if I connect the power supply, on the SDA and SCL pins of the battery I have 0V I measured the resistance with ground and it is very high, if I connect the battery I have 3v on the 2 lines.
                      2) if I try to turn it on without the battery...
                      05-06-2025, 06:19 AM
