EEPROM File Source
  • randtek
    • Oct 2011
    • 280
    • US
    EEPROM File Source
    Does anyone know of a source for ROM files for various consumer electronics devices? I'm talking about the hexadecimal files for writing to blank EEPROMS.
  • selldoor
    Slow Learner
    • 7870
    Re: EEPROM File Source
    http://elektrotanya.com/ have some i think - never used them
    last section on search header.
    • randtek
      • Oct 2011
      • 280
      • US
      I am trying to figure out how to create an account on that site, Any suggestions?
      • vinceroger69
        • Mar 2012
        • 6714
        what about this only have to answer 5 questions to register
        http://elektrotanya.com/?q=dotest&lang=en
        • my2k2
          Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
          by my2k2
          Good day to every one,
          I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
          Does anybody have an eeprom dump file? I really appreciate any help.
          Thanks in advance.
          07-01-2024, 09:04 PM
        • Chuper
          RCA RLDED4016a-b
          by Chuper
          So I got this TV with not turning on symptom.
          Using my backlight tester I confirmed that LED backlight is fine. Ordered a replacement main board TP.MS3393.PB851. With this replacement board TV turned on but original remote control will not work on a TV and side buttons are mixed up(for example if I press "Source" TV will increase volume).
          So I swapped Eeproms and confirmed that it is a problem on my original main board, meaning with my original main board and an Eeprom from replacement board I got TV to turn on with not working remote and mixed up side buttons and the replacement...
          11-09-2023, 11:26 AM
        • Forest79
          by Forest79
          However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...
          07-23-2023, 07:39 AM
        • tofik
          MOSFET equivalent K8A60DA
          by tofik
          Hello guys,
          I have a shorted MOSFET K8A60DA with the following characteristics:
          Type Designator: TK8A60DA
          Marking Code: K8A60DA
          Type of Transistor: MOSFET
          Type of Control Channel: N -Channel
          Maximum Power Dissipation (Pd): 45 W
          Maximum Drain-Source Voltage |Vds|: 600 V
          Maximum Gate-Source Voltage |Vgs|: 30 V
          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
          Maximum Drain Current |Id|: 7.5 A
          Maximum Junction Temperature (Tj): 150 °C
          Total Gate Charge (Qg): 20 nC
          Rise Time (tr): 25 nS
          Drain-Source
          07-19-2023, 05:18 AM
        • Lvsitano
          Asus X532FL 3.2V at source and gate
          by Lvsitano
          I am having some trouble with troubleshooting a Asus X532FL rev 2.0 motherboard, which does not power on. So at the first MOSFET, I am getting 19V at the drain, and then 3.2V on both gate and source (compared with ground). Of course, the 2nd MOSFET's source will have 3.2v at source.
          First MOSFET is a QM3056M6 and 2nd MOSFET is a QM0930M3
          I already checked first MOSFET and source and gate are not shorted (drain with source not shorted either). Also I have 1.7V at the LDO rail (measured at the keyboard connector, as the power button is on the keyboard).
          First...
          06-26-2024, 02:13 PM
