RCA RLDED4016a-b
  • Chuper
    • Sep 2017
    • 36
    RCA RLDED4016a-b
    So I got this TV with not turning on symptom.
    Using my backlight tester I confirmed that LED backlight is fine. Ordered a replacement main board TP.MS3393.PB851. With this replacement board TV turned on but original remote control will not work on a TV and side buttons are mixed up(for example if I press "Source" TV will increase volume).
    So I swapped Eeproms and confirmed that it is a problem on my original main board, meaning with my original main board and an Eeprom from replacement board I got TV to turn on with not working remote and mixed up side buttons and the replacement main board with original Eeprom won't turn TV on.
    So I used my CH341A to read the original Eeprom and it reads and writes back in it no problem. Now I have no idea how to fix that Eeprom dump file.
    What puzzles me is the fact that model numbers of the main boards are the same.
    How do I find a proper Eeprom dump for my models of TV and main board?
    Or can someone please help me fix the Eeprom dump?
    Thanks!
  • lotas
    • Jan 2016
    • 4708
    • Russia
    Re: RCA RLDED4016a-b
    Post the second working dump, I'll try to assemble one from the two.
    • Chuper
      • Sep 2017
      • 36
      Here it is
      • lotas
        • Jan 2016
        • 4708
        • Russia
        Try.
        • Chuper
          • Sep 2017
          • 36
          Both Eeproms now work on both main boards turning TV on and side buttons having correct functions.
          Thank you, lotas!
          Remote still won't work though
          • Tynan Dill
            by Tynan Dill
            Assuming...
            11-22-2024, 01:46 PM
          • ygorsan
            by ygorsan
            🧩 Problem Summary:
            • I
            07-28-2025, 08:34 AM
          • jb_Bak
            by jb_Bak
            CN6401
            Pin 01 NC
            Pin 02 NC
            Pin 03 "BL_ON": 0V
            Pin 04 "N/C"
            Pin 05 "STBY 3.3V": 3.5V
            Pin 06 "GND": N/C
            Pin 07 "AC_OFF"...
            09-27-2021, 04:52 PM
          • tech9pc
            Original RTU6549-MAIN-V2 RCA Main Board, CV3458H-A, 7.T3458HA1000.0008
            by tech9pc
            Hi does anyone have firmware for RTU6549-MAIN-V2 RCA Main Board, CV3458H-A, 7.T3458HA1000.0008. It is not available nowhere on the internet.
            I got a Version 1 CV3458H-A, 7.T3458HA1000.0003 off ebay for 30.00 and popped it in and board works but about every 20 or 30 minutes tv loses input signal and have to flip HDMI source than back to get picture up again. Probably from not being the same board as original which had lost its HDMI ports signals. I baked the board in oven but have not tried to put back in yet.
            Is there a way I could dump the original mainboard 7.T3458HA1000.0008 image...
            10-26-2021, 04:52 PM
          • cheeky2
            by cheeky2
            05-25-2024, 03:27 AM
