Does anyone know of a source for ROM files for various consumer electronics devices? I'm talking about the hexadecimal files for writing to blank EEPROMS.
EEPROM File Source
Re: EEPROM File Source
http://elektrotanya.com/ have some i think - never used them
last section on search header.Please upload pictures using attachment function when ask for help on the repair
http://www.badcaps.net/forum/showthread.php?t=39740 -
what about this only have to answer 5 questions to register
http://elektrotanya.com/?q=dotest&lang=enComment
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
Channel: BIOS Requests ONLY!
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
by ahmedtouHi everyone,
help me please
I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
I will share all the details with you, including the disc information.
...Code:HL-DT-ST BD-RE GGW-H20N XA02 (ATA) Current Profile: BD-R Disc Information: Status: Empty State of Last Session: Empty Erasable: No Free Sectors: 12,219,392 Free Space: 25,025,314,816 bytes Free Time: 2715:27:17 (MM:SS:FF) Next
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I have opened the laptop and identified the main BIOS chip...2 Photos-
by ChuperSo I got this TV with not turning on symptom.
Using my backlight tester I confirmed that LED backlight is fine. Ordered a replacement main board TP.MS3393.PB851. With this replacement board TV turned on but original remote control will not work on a TV and side buttons are mixed up(for example if I press "Source" TV will increase volume).
So I swapped Eeproms and confirmed that it is a problem on my original main board, meaning with my original main board and an Eeprom from replacement board I got TV to turn on with not working remote and mixed up side buttons and the replacement... - Loading...
