How to get free desoldering braid...
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    I have discovered a method for scavenging free desoldering braid. Basically CRT TV's and monitors have a braided wire running around the tube near the degaussing wire. This braid is basically the same stuff as desoldering braid, except it has been tinned. As it is, its useless for desoldering. But, if you take a sanding sponge and run the braid back and forth over the sponge ala "polishing your shoes" it is possible to expose enough copper in less than a minutes time that the wire will wick solder. Its not quite as good as the real stuff... takes just a little bit more time and heat to get it started wicking but once up to temperature it works great.
  • mariushm
    • May 2011
    • 3799
    Re: How to get free desoldering braid...
    The real solder braid also has some flux between the strains of copper. It's not quite the same thing.
    • Sparkey55
      • Jan 2010
      • 1523
      Yes sir. I have done that and used old coax cable braid also. I have found that when I hammer the braid flat it works even better. YMMV.
      • ratdude747
        Black Sheep
        • Nov 2008
        • 17136
        correct. you have to add your own flux.
        sigpic
        (Insert witty quote here)
        • Sparkey55
          • Jan 2010
          • 1523
          I have never had to add flux to copper braid in order to wick up solder. The secret is in how you clean the braid.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            you do if it isn't prefluxed... the flux is what makes the solder wick...
            sigpic
            • Toasty
              • Jul 2007
              • 4171
              When you're broke, you learn <quickly> how to make do.
              veritas odium parit
              • Evil Lurker
                Warranty Voider
                • Feb 2011
                • 454
                Oh yeah, just figured out something else... how to chemically strip the tin. I tried using plain old drain opener to get the job done, basically it wouldn't touch the tin... the acid needs an oxidizer to get the job done.
                So I took some Rooto sulfuric acid drain opener and made about a 50-50 solution with water. Then I very sparingly sprinkled in a bit of potassium nitrate into the acid bath. Within 30 seconds the tin was stripped completely leaving nice clean copper.
                • kc8adu
                  • Nov 2003
                  • 8832
                  • U.S.A!
                  i have simply wetted the dag ground braid with liquid rosin.
                  thought of that when i was a teen(70's)
                  • Sparkey55
                    • Jan 2010
                    • 1523
                    Capillary action is what makes the solder flow into the braid. Flux, when heated to form a liquid acts as a void filler to remove air pockets and to clean the braid surface while in emulsion of contaminants. Flux is not needed if you clean properly.
                    • ratdude747
                      Black Sheep
                      • Nov 2008
                      • 17136
                      Not really... yes, that's how it adheres to the copper, but you are missing part of how braid works.
                      The flux also distributes the heat and allows the solder to flow up the braid... otherwise, the solder would only wick to the braid being directly heated by the iron.
                      what braid should look like when being used: http://www.youtube.com/watch?v=2L4iv...igdnwBeJLDaoM= (pay attention to the second joint at the end...)
                      I know this by being forced to use fluxless braid before... its useless without adding flux...
                      liquid rosin is flux (for all intents and purposes) so yes, that would work. as long as it can both clean and distribute heat.
                      sigpic
                      • Sparkey55
                        • Jan 2010
                        • 1523
                        Ratdude, I have been soldering before you were born and have worked for several Aerospace companies in that time and have had excellent training in that arena. I learned techniques that are used industry wide. You have not the life experience to know that there is more than one way to skin a rat; I mean a cat.
                        • ratdude747
                          Black Sheep
                          • Nov 2008
                          • 17136
                          I know from experience that flux always makes braid better and generally leads to better desoldering.
                          I may be young but i first learned to solder just over 4 years ago, and for the past 1.5 years or so I have been soldering almost every day, honing my skills. I know damn well what does and doesn't work, and for anything major/multilayer, fluxless braid does't.
                          Why? I've maid the mistake of trying it. it's like trying to solder without flux or fluxed solder... it just doesn't work very well, and for the exat same reason- in order for solder to flow and adhere properly, there needs to be flux somewhere, or else very little solder adheres to the base metal.
                          In industry, AFAIK, flux is used with the braid somewhere... even the military uses flux on the braid (applied externally).
                          as for your comment about skinning a rat, yes, there are multiple way to TRY to skin a rat, but only certain ones work. In the world of desoldering, the methods that work best are vacuum sucker/irons/station, fluxed braid, and picks/needles.
                          sigpic
                            master hoarder
                            • May 2008
                            • 12175
                            Sure, just try cleaning the area on a motherboard after a BGA chip removal. If you can do it with flux-less braid, without any flux, and without lifting any pads where the BGA chip was - my hat off to you, sir!
                            Oh, and by cleaning, I mean silky-smooth BGA pads.
                            Besides, even if you do have all of that experience, many other people don't. So for all intents and purposes, I recommend everyone to use braid with flux because in the end: braid with flux (whether you add the flux yourself or use pre-fluxed braid) is way much easier and less risky to use than flux-less braid with no flux added. When you have customer's shit you don't want to screw up, it's just a no-brainer to add a drop or two of flux.
                            • 999999999
                              • Sep 2006
                              • 774
                              I always add flux to braid, including pre-fluxed braid... it just works better, faster that way.
                                I always use flux, for about 35 years now, not worth to damaged the board, parts can be replaced, but board is harder to replace, best not to damage the traces. Good 40watts iron, flux, fine braid copper solderwick. First day of electronics training in school was taught how to solder properly, most people knows the theory well but damages the parts and the boards and causes more problems due to poor soldering jobs, I see that in new tech coming in for the job, first test is to show us how well the person can solder and un-solder parts from the PCB.
                                • severach
                                  • Aug 2007
                                  • 1055
                                  I use flux everywhere except for hot air desoldering where it impedes the process as would be expected. Fluxless soldering is a form of self torture. Sure it can work but flux soldering is always faster and better. The quality improvement, saved time, and reduced damage to the work piece is well worth the time spent swabbing the residue off.
                                  I call BS on the industry wide argument. Flux is industry wide. Non flux is nowhere, nothing but a beginners mistake. Flux is cheap compared to the alternatives like vacuum soldering, inert gas soldering, high failure rate, and working all day wrecking the tools while getting nothing done. I'm not spending a ton of time scrubbing clean copper when a dollop of rosin paste cures all that ails me in places the scrubber can't reach. The only time I scrub copper is when the wire cannot be replaced and time has corroded it so deep that no amount of acid paste can clean it.
                                  Flux! It does a solder good.
                                  As for free soldering braid I'm surprised that noone has mentioned the copper wire we all throw away in bad power supplies. Strip, flux, and desolder. It is consumed faster than real braid and doesn't draw as well but at almost zero cost I can afford to use too much. I don't need to place orders or remember where I put it. Don't forget that the insulation makes a heat resistant handle and pieces of it can be placed on component leads that need to be insulated.
                                  sig files are for morons
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 4981
                                    • New Zealand
                                    It's an interesting idea, but I'd argue the point that your CRT-salvaged braid is 'free' after you factor in the time spent un-tinning it and then deciding what to do with the rest of the monitor afterwards...
                                    -David VanHorn
                                    • ratdude747
                                      Black Sheep
                                      • Nov 2008
                                      • 17136
                                      All things considered, nothing is "free". It's the first rule of Economics.
                                      Some people have more time than money, so to them, all that matters is monetary cost... so in that case, it is psydo-free.
                                      sigpic
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4981
                                        • New Zealand
                                        Well, unless you got some for a Christmas present or such, perhaps...
                                        -David VanHorn
                                        • wnlewis
                                          New wire for my RDE3340 Whirlpool electric range
                                          by wnlewis
                                          OK. I got the rocker switch figured out thanks to the good advice on this forum.
                                          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
                                          This is a Whirlpool RDE3340 electric range.
                                          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
                                          Where may I find parts...
                                          01-08-2025, 11:21 PM
                                        • emeskay
                                          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
                                          by emeskay
                                          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
                                          08-06-2024, 07:13 AM
                                          03-31-2024, 02:12 PM
                                        • technicalspecialist
                                          Vintage fan repair, copper wire question
                                          by technicalspecialist
                                          I currently have a customer's vintage fan on the work bench to repair.
                                          It uses an induction motor with 4 poles. One of the poles is open.
                                          I couldn't find the break so i cut off the original wire.
                                          I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
                                          I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
                                          The enamelled copper...
                                          03-16-2023, 12:54 PM
                                          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
                                          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
                                          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
                                          12-16-2023, 08:39 PM
