How to get free desoldering braid...
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    Re: How to get free desoldering braid...
    Its actually pretty easy figuring out what to do with the rest of the guts. The degaussing wire goes towards my magnet wire collection provided of course it is in a size that I don't have already. The PCB is scavenged for inductors, mosfets, low tolerance ceramic and film capacitors, current sense resistors, zener diodes, and whatever else looks interesting. Then on the back of the tube the yoke is stripped off and the copper wire is put back to sell for scrap along with any degaussing wire that I don't need. Finally the tube is "necked" to remove the vacuum inside the tube to prevent it from imploding when it is moves, the set is put in or on top of a barrel or other large container capable of holding glass shards and the tube is smashed to make room for another one. The plastic part usually goes in the burn pile.
      master hoarder
      • May 2008
      • 12170
      Bad idea!
      The fumes from that are highly carcinogenic.
      Smash it up as much as you can instead, and put it in your recycling bin.
      • mariushm
        • May 2011
        • 3799
        True.
        The plastic in CRT TV sets usually has flame retardants and hardeners which are toxic, carcinogenic.
        The tube also contains lead and phosphorus, both bad for you - you shouldn't inhale any dust that results from breaking the screen.
        • wnlewis
          New wire for my RDE3340 Whirlpool electric range
          by wnlewis
          OK. I got the rocker switch figured out thanks to the good advice on this forum.
          Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
          This is a Whirlpool RDE3340 electric range.
          The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
          Where may I find parts...
          01-08-2025, 11:21 PM
        • emeskay
          Lenovo Yoga 710 15ISK, 80U00002US battery cable wire broken.
          by emeskay
          We have an Lenovo Yoga 710 15ISK that we use as a secondary laptop. To cut a long story short, around May 2023, while traveling, I connected the laptop into an electrical outlet that was already switched on. Something made a "pfft" sound and the laptop refused to turn on after that. After getting back home, I gave the the laptop for repair to an informal repair person. He replaced the adapter and an internal motherboard part, but after he returned it I noticed that the LCD did not look normal. Essentially, every alternate horizontal line on the screen had gone missing. The laptop was...
          08-06-2024, 07:13 AM
          03-31-2024, 02:12 PM
        • technicalspecialist
          Vintage fan repair, copper wire question
          by technicalspecialist
          I currently have a customer's vintage fan on the work bench to repair.
          It uses an induction motor with 4 poles. One of the poles is open.
          I couldn't find the break so i cut off the original wire.
          I have measured the other poles and the resistance is about 28 ohms per pole and I measured the diameter of the wire with my digital calipers and it is 0.35mm in diameter.
          I need to work out how much 0.35mm diameter enamelled copper wire i need to order for it to be 28 ohms. I have used this calculator and it says i need 160.35 metres.
          The enamelled copper...
          03-16-2023, 12:54 PM
          Heater element wire type instead of a fuse when troubleshooting a short circuit DIY
          I was Ollie today which is a close out / surplus outlet store I do not go in there to often because you find things that you should not be tempted by but that is a another story
          I saw a small space heater that used a wire type of heater element which I been looking for a while but not really hard mind you but when I saw this I grabbed it I going to go back tomorrow and buy the last one that is like the one I bought today because I need the heater element and the ceramic insulators and more of heat element wire because this one has two different wattage settings one 1300 watts ( tap...
          12-16-2023, 08:39 PM
