Weird looking soldered joint?
  • teeb
    • Feb 2012
    • 21
    Hi BADCAPS community!
    I'm investigating on a TV which display shows crap intermittently.
    Here is the inverter board with its crappy looking joints. What do you think? Is it normal ? (caps aren't blown)
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: Weird looking soldered joint?
    That's just left over flux.
    Sloppy work but it shouldn't hurt anything.
    A tooth brush [or Q-tips] and some isopropyl alcohol should clean it up so you can actually see the joints to check them.
    Mann-Made Global Warming.
    - Dr Seuss
    • teeb
      • Feb 2012
      • 21
      Thank you for the prompt answer PCBONEZ
      • Koda
        • Aug 2011
        • 317
        • Macedonia
        Those are actually pretty good joints by me, maybe a bit too much solder but they look clean and well connected so probably better then most.
        Guns don't solve problems. I'll take 12
        • teeb
          • Feb 2012
          • 21
          the brownish part looked suspicious though!
          • 999999999
            • Sep 2006
            • 774
            It is normal? No. Normally through hole capacitors are soldered on the other side of the board and only about 1/3rd as much solder is used. So, I question whether the solder joints are good but they may still electrically be fine, don't look grainy or disrupted like a bad joint usually does.
            However, the inverter board is for backlighting, should only affect the operation of that, not other display issues.
            • Scenic
              o.O
              • Sep 2007
              • 2642
              I've seen a few single-sided inverter boards which had no through-holes at all.. Just solder pads. The caps were soldered in just like in the pics in the first post.
              It does look quite sloppy with the leftover toasty flux, but it shouldn't do any harm or cause problems usually. Just like PCBONEZ said, you could just remove the flux if you want to/if it bothers you.
              As for the display showing garbage, I'd focus on the mainboard and maybe the T-CON board if you took care of the PSU caps already.
              • PeteS in CA
                • Aug 2005
                • 3579
                • USA, Unsure of Planet
                Looking at the joints, I'm going to guess that the part is installed as if it were a surface mount part, with the leads laying on and soldered to pads on top of the board. I would also guess that this cap was replaced during manufacturing test or in a previous service event. So, maybe too much solder was used, or maybe the cap leads were not quite long enough to reach the PCB, making extra solder necessary to complete the circuit. And whoever did the solder work didn't clean off the flux (which ages with heat and turns brown).
                PeteS in CA
                • selldoor
                  Slow Learner
                  • 7870
                  How about a picture of the other side of the board ?
                  • teeb
                    • Feb 2012
                    • 21
                    Well, there is no wiring on the other side
                    • popeye
                      • May 2011
                      • 155
                      If I were you I would take a picture of the fault when it happens and tell us of anything else that happens also model number and make of lcd board numbers and pictures all boards if possable you will get a much better responce from a TV engineer that way hope this helps.
                      regards
                      popeye
                      • teeb
                        • Feb 2012
                        • 21
                        The TV has been repaired. The tin must have melt as 2 pins were in contact under the main processor unit. Thanks for your help.
                          • Jul 2011
                          • 6037
                          When I see soldering joint like that I reflow them I question how good they are because a few times I have seen alot of flux flow out of the joint
                          • Nagyesz
                            Lenovo IdeaPad Gaming 3 15ACH - Ideapad 3 well known solder joint issues
                            by Nagyesz
                            I have a Lenovo IdeaPad Gaming 3 15ACH, which has started exhibiting the well-known issues of the Lenovo IdeaPad 3.
                            All stress tests run perfectly, and there are no performance issues. However, the solder joints are almost certainly starting to fail. If the top two screws on the back are not screwed in, moving the screen results in a BSOD or, in some cases, a slight artifact and freeze. This is a 2023 notebook..
                            How can I extend its lifespan? Could reflow help?
                            It has ryzen 5 5500h, rtx 2050, no soldered ram.
                            Example of the artifacts:
                            03-01-2025, 11:11 AM
                          • flibidy
                            Magnum IA.100 Amplifier Switches on, No Output, Possible Input Side fault?
                            by flibidy
                            I have here a Magnum IA.100 which belongs to my parents.
                            The unit powers on & when the relay kicks in, you get a pop from the speakers (this might sound weird but is usual behavior for this amp). However, you get nothing coming through it from any of the inputs & no pops and crackls from any of the controls.
                            Because of the sound from the speaker when the amp turns on I have assumed that the output section probably works but I could be wrong & I'm not sure how to test that side of things further.
                            What Ive done........
                            01-01-2025, 01:26 PM
                          • DoOm86
                            Doubts about: working laptop without a soldered ram/vga/battery
                            by DoOm86
                            I'm new to elettronic, so perhaps my question has no sense.
                            Can a laptop still work without one of the soldered ram?
                            I was wondering if a laptop (or any other device actually) can still works if removing a faulty soldered ram without soldering back a good replacement. Of course considering the mainboard has other ram chip perfectly functional.
                            I tried on a MacBook Air and also an Asus laptop and it seems no possible without a replacement. At least, not just removing the faulty one.
                            Sometimes for the seek of data recovery on a flash soldered drive on the mainboard,...
                            04-14-2023, 05:05 AM
                          • Loki_Fido
                            (Weird) BIOS info for HP Pavilion Aero 13-be1021AU
                            by Loki_Fido
                            Hi folks,
                            This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
                            I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
                            BIOS - XMC 25RU128CH10 (1.8v)
                            What the heck is this? I looked all over the MB. This is the only bios.
                            When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what...
                            03-20-2025, 01:57 AM
                            APC BR1000G battery backup has a weird issue sometimes a bad battery icon and making a weird sound for about 30 seconds
                            by sam_sam_sam
                            This started a few days ago and does this about every 8 hours
                            After it does this it goes back to normal no bad battery icon and no weird sounds and it goes to battery backup mode so I am not sure what is going on with this battery backup
                            The battery backup is about 3 or 4 years old
                            Dose anyone have any idea on how to troubleshoot this issue I have never had a battery backup do this kind-a thing before so I am not sure exactly how to troubleshoot it and where to start
                            06-02-2024, 02:30 AM
