(Weird) BIOS info for HP Pavilion Aero 13-be1021AU
This topic has been answered.
  • Loki_Fido
    • Mar 2025
    • 126
    • Japan
    Hi folks,
    This HP Pavilion Aero 13-be1021AU came to me for a repair. And it seems to have a weird BIOS chip. (Pic attached)
    I asked my CH341A to read it and doesn't even know what to do with this. We are both very confused.
    BIOS - XMC 25RU128CH10 (1.8v)
    What the heck is this? I looked all over the MB. This is the only bios.
    When I asked the NeoProgrammer to detect it, it just pops up an empty screen, and asked me to enter the bios number. And when I did, it doesn't do anything. NeoProgrammer showed me just this SPI ID: 204418. Don't know what it means.
    I even googled it. No results.
    Weird, right?
    Is there a way to detect and read this chip? Anyone knows?
    Any help is appreciated.
  • Answer selected by Loki_Fido at 03-21-2025, 09:02 PM.
    Loki_Fido
    • Mar 2025
    • 126
    • Japan
    I found the answer.
    https://www.badcaps.net/forum/troubl...os#post3565103
    Fr those who are facing the same problem as me, go to the above link and read the complete thread.
    Credit goes to SMDFlea, Volinakis.
    Thanks all.​
    • peste
      • 13401
      • ROMANIA
      Originally posted by Loki_Fido
      Hi folks,
      Weird, right?
      program it manually... try a similar chip from the database...
      • Loki_Fido
        • Mar 2025
        • 126
        • Japan
        Hi peste,
        Its not even getting detected. Then how to programming manually?
        I googled the chip. No results. There's nothing about this bios in the internet.
        I tried Neoprogrammer. AsProgrammer, XgPro and nothing.
        HP threw a curve ball at me and it seems like i took it to me face.
        • peste
          • 13401
          • ROMANIA
          Hi peste,
          you have to power it at 1.8v..not 3.3v...
          The bios chip must be unsoldered from the board before writing or reading..
          do not use the clip, you may have errors..if you do not have anything to unsolder it with,
          solder wires between the programmer and the bios chip..
          https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
          • Loki_Fido
            • Mar 2025
            • 126
            • Japan
            Hi peste,
            I used the clip to attach it to the 1.8V adapter and then to the CH341a. Pics attached
            Only received SPI ID: 20441.
            Then I skipped the 1.8v adapter and directly connected to the CH341a.
            Same result.
            Is it possible to take a BIOS chip from another make/model motherboard and solder it here and download bios from HP website and write it into this bios, the system would be ok?
            • peste
              • 13401
              • ROMANIA
              remove the chip from the board and stick it on the adapter where the clip comes from...and see if it detects it..
              • Loki_Fido
                • Mar 2025
                • 126
                • Japan
                Hey peste,
                Just did as you said. No difference.
                Same result as before.
                Im guessing at this point we just have to replace the BBIOOS chip. What do you think?
                • Loki_Fido
                  • Mar 2025
                  • 126
                  • Japan
                  I just found this exact BIOS chip in Lenovo Yoga 6.
                  And i couldnt read that too.
                  Any idea why?
                  Is there something wrong with my CH341A? or its driver software?
                  • Loki_Fido
                    • Mar 2025
                    • 126
                    • Japan
                    I found the answer.
                    Thanks all.​
                    • Bloodhoundje
                      by Bloodhoundje
                      03-16-2024, 03:12 PM
                    • trepachka
                      BIOS rebuild requested for HP Pavilion Aero 13-be0003ca laptop
                      by trepachka
                      Hello, I have the following laptop:
                      ProdID: 2L7M8UA#ABL
                      S/N: 8CG150GPV6
                      Motherboard information is below:
                      HP Part# M52826-601
                      448.ONE04.0011
                      203016-1
                      It needs BIOS repaired.
                      I created a flash drive using HP firmware utility and then had it plugged into the computer. I did the standard WinLogo-&gt;B key-&gt;Power button press. A window appeared and immediately began flashing the bios using the flash drive.
                      But I don't think it finished all the way. So, now when I attempt...
                      04-21-2024, 10:57 PM
                    • sssssssssssssss
                      Need BIOS for HP Pavilion 15-n058sr recovery - Caps Lock blinking twice
                      by sssssssssssssss
                      I'm dealing with a classic BIOS corruption issue on an HP Pavilion 15-n058sr and hoping someone here might have the original BIOS file or point me in the right direction.
                      Symptoms:
                      • Laptop powers on but no display at all (completely black screen)
                      • Caps Lock blinks twice with a pause, then repeats continuously
                      • F12 LED stays on permanently
                      • No POST, no boot sequence, nothing on screen
                      Based on HP diagnostic codes, the 2-blink Caps Lock pattern indicates BIOS corruption/failure.
                      What I've tried:
                      • Hardware reset (battery removal, power
                      09-04-2025, 06:45 AM
                      by Vesko356
                      08-11-2023, 03:27 AM
                    • c.daniel
                      Lenovo V310-15IKB weird bios problem...
                      by c.daniel
                      Lenovo V310-15IKB Type 80T3 laptop, i7 7th cpu with dedicated Ati video
                      sn LR09493E
                      MB DAOLV6MB6F0 REV. F
                      The laptop was working fine, the only problem was that when I turned it on, the screen was hard to turn on, it would wait for about 30-40 seconds before an image appeared on the screen.
                      Initially, I updated from windows to Intel Management Engine 11.8 Firmware, restarted, everything was fine.
                      Then I updated the bios, also from windows, to the last vs, vs 46. It restarted, those lines with bios update progress appeared, restarted and that's it, since then...
                      08-22-2025, 05:39 AM
