CMOS battery life
  • Shodan486
    • Nov 2009
    • 203
    CMOS battery life
    Just this:
    What is the average lifetime of a classic coin battery used in today's computers for maintaining BIOS settings?
    And another one : If the battery is placed in the mobo and the mobo is not used for let's say 10, it's surely depleted, right? To be more precise, in what time does the socketed battery dry out while the motherboard has never been turned on?
    Mobo: MSI K8N Master2-FAR CPU: 2x Opteron 265 OC'd @ 2,25GHz RAM: 2x2GB Crucial DDR400 CL3 ECC/Buff. (ECC OFF), VGA: ASUS HD6950 2GB Reference edition FLASHED TO HD6970 HDD: 80GB ATA133 Seagate ,OnBoard: 2xGLAN, 8-Ch. Realtek audio, USB2.0/Firewire, PCIe Physx card PSU: 850W Corsair AX Case: Cooler Master HAF932 + NZXT 5 Fan Controller.
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    Re: CMOS battery life
    Not used for 10 what?
    Depends on use...
    On modern boards the CMOS battery is bypassed any time +5vstb is available.
    There is no drain on it during that time.
    Mann-Made Global Warming.
    - Dr Seuss
    • Shodan486
      • Nov 2009
      • 203
      10 years Sorry for that.
      Just wanna know if a board left 10 years of no use, no AC plug, no nothing, has the battery still working...
      • PCBONEZ
        Grumpy Old Fart
        • Aug 2005
        • 10661
        And no, they are not rechargeable batteries.
        I took out an old PII/PIII BX board the other day to test some ECC PC100 RAM.
        It probably hasn't been used in 5+ years and the battery was still working.
        Of course the cheap Chinese variety probably doesn't last that long.
        - Dr Seuss
        • Shodan486
          • Nov 2009
          • 203
          And is it possible that the battery may show 0.01v on a multimeter after 10 years?
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Yes but that's not enough voltage to 'hold up' the CMOS.
            - Dr Seuss
            • Shodan486
              • Nov 2009
              • 203
              Right, that's clear. Just wanna know the numbers...So PCBONEZ, you claim that it depends on the battery manufacturer, rite? Interesting, thought at least batteries, which tend to explode when handled inappropriately, are manufactured with safety provided to the consumers...
              • Scenic
                o.O
                • Sep 2007
                • 2642
                the coin cell inside the "dallas module" on my 486DX33 board still has 2.97V
                and it's far older than 10years..
                • brethin
                  • Dec 2008
                  • 1907
                  I have several Nintendo NES games with coin batteries in them still good after 25 years.
                  • Evil Lurker
                    Warranty Voider
                    • Feb 2011
                    • 454
                    I guess the old saying "your mileage may vary" applies. I replace mine about every 4-5 years or so and on all used motherboards I aquire when I aquire them. Its all trivial since CR2032's and CR2025's can easily be found at most discount retailers for a couple bucks each.
                    • mike-hock
                      I Know Nothing
                      • Mar 2011
                      • 9
                      Would it make ANY difference if the OP's ( Shodan486) board had the cmos jumper in the OFF position?
                      As I understand it, all regular lithium etc cells have a limited lifespan. Thankfully they're not expensive to replace. I'd never throw a board for the lack of one!
                      it's Michael Hockley actually... my parents have a sense of humor.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Jumper simply shorts the + and - together momentarily [through a resistor so it doesn't fry the battery.]
                        Leaving the jumper off would have no ill effects.
                        Leaving it in the reset position for a while would eventually drain the battery.
                        I usually just remove the battery instead of fooling with the jumper.
                        - Dr Seuss
                        • cmosbios
                          • 12
                          PCBONEZ, can you please give us an idea of basic BIOS circuit, I mean NOT the circuit inside the BIOS, but the circuit behind the BIOS system on a motherboard. Some kinda diagram and its basic components.
                          • PCBONEZ
                            Grumpy Old Fart
                            • Aug 2005
                            • 10661
                            I don't know that one. Never traced one out.
                            I only know how the BIOS chip is powered.
                            - Dr Seuss
                            • cmosbios
                              • 12
                              One thing that interests me, its your profile (About Me page) .. you are interested in chasing women.. and that's the special science LOL
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Not so much anymore.
                                The problem is getting away after you catch one.
                                - Dr Seuss
                                • TheLaw
                                  • Jan 2011
                                  • 477
                                  You definitley can get 10+ years out of them with normal use.
                                  • oldnwrinkly
                                    • 5
                                    Which, woman or batteries? ..............
                                    Dave.
                                    • Rob Northen
                                      • Jan 2010
                                      • 137
                                      • Denmark
                                      Dave.
                                      Depends how hard you use them.....
                                      • Agent24
                                        I see dead caps
                                        • Oct 2007
                                        • 4978
                                        • New Zealand
                                        10 years seems pushing it for a CR2032...
                                        Why worry anyway? Quick test with DMM and if it doesn't work get a new one... If you don't have a DMM use an LED. Works perfect for testing them. It should glow brightly!
                                        -David VanHorn
                                        • Bowline
                                          by Bowline
                                          06-11-2025, 10:13 AM
                                        • mkdj
                                          by mkdj
                                          Mark and model: ASUS X571
                                          Tests already made:
                                          - I have removed...
                                          07-14-2025, 09:16 AM
                                        • techfreak9356
                                          Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                          by techfreak9356
                                          09-14-2023, 11:10 PM
                                        • magistertc
                                          CMOS battery drains quickly
                                          by magistertc
                                          This problem is based on my experience with an ASUS Z390 Prime motherboard, but it appears to affect other motherboards
                                          as well Install a new CMOS battery, configure computer, turn off computer and disconnect from AC power or switch off SMPS.
                                          Return somewhat later and find that battery is drained, dead, or weak. Clock is wrong, other settings lost, etc.
                                          Examine the power 'sharing' circuit -- when the ATX 3V supply is on, the computer will function normally. The computer is also
                                          configured to support the RTC and some volatile RAM (when SMPS is on). What you may...
                                          07-06-2024, 09:55 AM
                                          NVDC charger configuration...
                                          11-05-2024, 03:28 PM
