RiddleMeThis - What smokes but doesn't burn?
  • Crystaleyes
    • Sep 2021
    • 493
    • Brazil
    hope life is treating you well.
    I have a question, as I am genuinely puzzled.
    There is this old Tektronix 2215 scope which has been laying around for some time, that I knew had some issue, but couldn't remember what...
    Anyways, last night, I thought I'd give it a look, as space is needed, so put it on the bench and plugged it in.
    The CRT had a terrible trace which only filled half the screen and didn't seem to respond much to any of the controls, so I decided to give it 15 minutes to warm up whilst I cleared up the bench a bit.
    After maybe ten minutes, I heard the dreaded 'pffft-pfssss-pop' followed by the most almighty amount of smoke!
    Even though I'd yanked the plug from the socket, there was so much smoke coming from the HV section, that I was expecting to see flames.. But no, just plumes of smoke.
    I mean, I have an impressive record of toasting electronic components but I honestly don't remember such a dramatic event without flames.
    As it sank in that that was a major fuck-up, I realised that at least the toasted component would indicate in which circuit the problem lay, so set about opening the HV section which is sandwiched between the main board and another smaller board which sits above.
    Anyway... the point is, there was nothing burnt!
    None of the caps had exploded, no resistor had roasted, no damage was done to any component or trace on either board. Not even the slightest scorch mark.
    Weirder still, is that now the scope (almost) works fine. The intensity and beam finder aren't quite right and the display judders and jiggles around, but the CRT now shows full waveforms.
    So what the fuck???
    What am I missing?
  • CapLeaker
    Leaking Member
    • 8220
    Re: RiddleMeThis - What smokes but doesn't burn?
    Usually these are known for to do this kind of noise in the PSU filter section (X cap). Sounds like it and smokes like crazy too.
    • Per Hansson
      • Jul 2005
      • 5895
      • Sweden
      Probably one of the Rifa caps let out the smoke, they can be inside the mains filter too.
      https://www.youtube.com/watch?v=XAbrU17hLTM
      • Crystaleyes
        • Sep 2021
        • 493
        • Brazil
        Holy Guacamole Batman...
        You hit the nail on the head.
        Thank you.
        Everyday is indeed a school day!
        • Per Hansson
          • Jul 2005
          • 5895
          • Sweden
          You're welcome
          C903 C904 C907 C908 are 250VAC 2200pF Rifa PME271 Y class safety caps on the preregulator board.
          C901 is a 250VAC 10000pF Rifa PME271 Y class safety cap located on the main PCB under the line filter.
          They are actually still in production, I have the same scope and used identical replacements in mine.
          Some people do frown on this because the way they fail, but I see it as they lasted 30 years so who am I to complain
          (They fail due to ingress of moisture, so it depends on how the unit was stored if it is a problem or not).
          Was it any of these that failed or was it actually the ones inside the line filter? (IEC receptacle)
          https://www.digikey.com/en/products/...22MR30/1927355
          https://www.digikey.com/en/products/...10MR30/1927357
          • Crystaleyes
            • Sep 2021
            • 493
            • Brazil
            Great info. Thanks again.
            For now, I have just swapped them out with polyesters and that seems to be ok. Getting original Rifa's here in Brazil is not cheap (+/- $10 ea).
            A much bigger hurdle right now is with what to replace the C628 matched set on the A12 Sweep board?
            One of them is a polarised 0.01uF and what appears to be electrolytic!
            • Per Hansson
              • Jul 2005
              • 5895
              • Sweden
              You can replace them with any other safety rated Y capacitors.
              Do not change those capacitors, they are extremely reliable and as you see part of a matched set precision capacitors!
                • 31090
                You're welcome
                no, they fail because the epoxy shrinks over the years until it cracks.
                that's why you dont get similar problems with caps potted into plastic shells
                a friend had hundreds of cracked rifa's - NOS in the bags!
                (he had an electronic parts store)
                • Crystaleyes
                  • Sep 2021
                  • 493
                  • Brazil
                  I found two out of the four on the power board had cracked. Only very finely.
                  For sure, without the plumes of smoke, it would have been a long time before I would have ever noticed.
                  Nuts as you like!
                  • Per Hansson
                    • Jul 2005
                    • 5895
                    • Sweden
                    I meant that they fail due to moisture ingress through those cracks.
                      • 31090
                      a cheap bastard could put them in an oven for a while and then coat them in RTV
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        bake and re-seal with another layer of epoxy, why not?
                        • Crystaleyes
                          • Sep 2021
                          • 493
                          • Brazil
                          I'll put them back in then, eh?
                          • Per Hansson
                            • Jul 2005
                            • 5895
                            • Sweden
                            Yes, you will not find matched replacements for these capacitors.
                            There was a thread on eevblog about them a year or so ago with a better explanation than I can give but I can't find it again.
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              I still need to recap my Tektronix 2465 and 2440 that also use these RIFAs. However possibly due to the fact I live in a fairly arid environment, they haven't started smoking...
                              • ttmi100x
                                HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                by ttmi100x
                                Greetings everyone,
                                I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                Upon closer inspection...
                                07-31-2024, 06:36 PM
                              • howardc64
                                Insignia NS-43D420NA20 backlight on no display - LCD panel burn failure
                                by howardc64
                                Eventually discovered a burn mark near lower corner of LCD. Here is a summary
                                • Backlight on, no image
                                • Disconnect right buffer board (view from front), left side display comes on
                                • Masked off pin 7+8 (both ~12,5v on both left and right buffer board) from t-con to right buffer board (view from front) display works but have some lines
                                • Buffer board is pretty simple
                                Removed the front bezel to examine edge of the glass. Found burn mark on lower right (view from front). Plastic bezel covering the burn mark region shows heat signature on the inside surface facing the LCD panel. Last 2 pics. Bright...
                                07-11-2025, 04:04 PM
                              • shelby5041
                                old trs80 computer lots of smoke
                                by shelby5041
                                hi
                                my neighbor gave me an old radio shack trs80 model3 computer...it was stored in his attic for 35yrs...i powered it on and after 5min lots of smoke was coming out of computer...i took it apart and didnt notice any fire evidence so i assume a cap split open...i looked around only saw 1 suspect part...see photo...could this be the smoke?
                                07-14-2024, 05:11 PM
                              • Seville
                                Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
                                by Seville
                                Hello all!
                                Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply .
                                I have a Westinghouse LED TV, model WD48FAB100 that is not powering on. Upon removing the back cover, I noticed a burn mark where the AC cord connects to the power supply/main board. In this model, there is only one board combining the two functions. Previous owner said the TV experienced a lightening strike, but who knows. I checked the main fuse, tested OK. Here are a collection of readings from the power supply ports. Looking for some guidance on what to test/check next....
                                10-10-2022, 07:31 AM
                              • Bubbsy 2002
                                Kiddie smoke alarm (120v with 9v battery backup) experienced 180v power surge (Newfoundland Power company).
                                by Bubbsy 2002
                                Hi to all, I was diagnosing 2 smoke detectors that experienced power surge. I opened one up and found a weird fuse/resistor, which now has open circuit. I can't find this part.
                                Forgot to mention they both light up and I believe the test function works, but when I put smoke to them no alarm!
                                Any help in this regard would be greatly appreciated.
                                Thanks,...
                                01-02-2024, 09:11 AM
