Finally built the Bob Parker "Blue" ESR Meter
Re: Finally built the Bob Parker "Blue" ESR Meter
huge probes!
i have several of these - i get a pair for every meter!
https://www.aliexpress.com/item/32848907433.html
Plus those banana plugs are completely useless. Cut the probe wires if needed, and replace.Comment
Ryzen 3600x
16GB Patriot 3600MHz
MSI B450 Gaming Plus
MSI Air Boost Vega 56
Acer 32" 1440P Freesync
Rosewill Capstone 750W
Hakko FX-888D Station
FX-8802 Iron
MG Chem .8mm 63/37 RA 2.2%Comment
Incidentally, where does one get shrouded banana jacks?
Ah, looks like ponoma makes some and distributed by the usual newark, mouser, digikey, etc...
Sigh. Wonder if I should convert my old DMMs to shrouded type jacks so I can use my probes from dead DMMs...Last edited by eccerr0r; 04-27-2021, 02:24 PM.Comment
they are everywhere - you need to look for "test connectors" or similar descriptions.
https://www.rapidonline.com/4mm-single-pole-connectorsComment
- Once circumcised... you are stuck (in fact, not you but the probes...
- Change the sockets and you're free to swap probes (see @stj remark about clearance)
Even free to attach alligator clips when handy
I built the Bob Parker Blue ESR meter kit a few years back and i still love it today.
All except the graph on the face,... I had to make a chart to replace it with!Comment
What ESR chart did you go with?
I've heard measuring battery ESR can also be done if you add a series DC blocking capacitor. Good for many testing different batteries, LiIon and car batteries with the Blue ESR meter.Comment
Printed it to sticker paper and after applied I put clear laminate over it!
I made a bunch in case i messed up. lol
Worked fine on the first one.Comment
Did the included sticker give you trouble removing it? I agree it's a bit too vague. Need a simple chart. Plus I put mine on a little too high so you can't quite see the decimal positions if it's slanted too much.--------------------------------------------------------------
Ryzen 3600x
FX-8802 Iron
I can`t recall but i bet there was some hot air involved.Comment
Hey redwire
You can measure battery ESR with the Blue as is. No need to add anything.
This is only if you did not do any diode mod to your meter!
(back to back diodes on the input)Comment
Hey I looked at the schematic and it's already got a 22uF BP cap to block DC and not damage the ESR meter
It must be other shitty ESR meters I've built like the 5-transistor special that need a cap.
Tried a bad 12V 7Ah gel-cell and its ESR 2.3 ohms, a good one is 0.1-0.2 ohms.Comment
Ryzen 3600x
FX-8802 Iron
by sam_sam_samI have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery... -
This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 14 I7-1255U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 14 I7-1255U 8GB 512GB BLUE boardview and IP3 14 I7-1255U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...09-07-2024, 05:00 AM
- Loading...
