Finally built the Bob Parker "Blue" ESR Meter
    • 31262
    Re: Finally built the Bob Parker "Blue" ESR Meter
    Originally posted by bcstedt
    Those look pretty neat especially for the price. Do you use this seller specifically?
    i do because they are consistant
    they have silicone ones too.
    • megaraider
      • Jul 2015
      • 307
      • Portugal
      Originally posted by stj
      huge probes!
      i have several of these - i get a pair for every meter!
      https://www.aliexpress.com/item/32848907433.html
      Originally posted by jayjr1105
      Not a ton of options when you need modular ones that will accept 4mm banana plugs.
      Agree with @stj.
      Plus those banana plugs are completely useless. Cut the probe wires if needed, and replace.
      • jayjr1105
        • 281
        I'm still tossing the idea around in my head to convert it to banana jacks like the MESR-100 meter. They give you an extra top plate, just need to find jacks like these somewhere.
        Ryzen 3600x
        16GB Patriot 3600MHz
        MSI B450 Gaming Plus
        MSI Air Boost Vega 56
        Acer 32" 1440P Freesync
        Rosewill Capstone 750W
        Hakko FX-888D Station
        FX-8802 Iron
        MG Chem .8mm 63/37 RA 2.2%
          • 31262
          you would be better using the shielded type like on multimeters.
          you can still use 4mm banana jacks, but you can also then use comercial probes and cables.
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8704
            Incidentally, where does one get shrouded banana jacks?
            Ah, looks like ponoma makes some and distributed by the usual newark, mouser, digikey, etc...
            Sigh. Wonder if I should convert my old DMMs to shrouded type jacks so I can use my probes from dead DMMs...
              • 31262
              they are everywhere - you need to look for "test connectors" or similar descriptions.
              https://www.rapidonline.com/4mm-single-pole-connectors
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8704
                Question if it's easier to replace the old DMMs' connectors, or is it time to get the probes circumcised...
                  • 31262
                  that depends on the meter.
                  i have drilled out the molded crap on a couple and fitted ones with locking rings, but it depends on clearance.
                  • megaraider
                    • Jul 2015
                    • 307
                    • Portugal
                    #29
                    Well the answer is quite obvious:
                    1. Once circumcised... you are stuck (in fact, not you but the probes... )
                    2. Change the sockets and you're free to swap probes (see @stj remark about clearance)
                      Even free to attach alligator clips when handy
                    • volkswagenvan
                      Volks
                      • Mar 2009
                      • 35
                      I built the Bob Parker Blue ESR meter kit a few years back and i still love it today.
                      All except the graph on the face,... I had to make a chart to replace it with!
                      • redwire
                        • 3912
                        What ESR chart did you go with?
                        I've heard measuring battery ESR can also be done if you add a series DC blocking capacitor. Good for many testing different batteries, LiIon and car batteries with the Blue ESR meter.
                        • volkswagenvan
                          Volks
                          • Mar 2009
                          • 35
                          I kinda made one from the old Bob Parker meter.
                          • volkswagenvan
                            Volks
                            • Mar 2009
                            • 35
                            Printed it to sticker paper and after applied I put clear laminate over it!
                            I made a bunch in case i messed up. lol
                            Worked fine on the first one.
                            • jayjr1105
                              • 281
                              Did the included sticker give you trouble removing it? I agree it's a bit too vague. Need a simple chart. Plus I put mine on a little too high so you can't quite see the decimal positions if it's slanted too much.
                              Ryzen 3600x
                              FX-8802 Iron
                              • volkswagenvan
                                Volks
                                • Mar 2009
                                • 35
                                I can`t recall but i bet there was some hot air involved.
                                • volkswagenvan
                                  Volks
                                  • Mar 2009
                                  • 35
                                  Hey redwire
                                  You can measure battery ESR with the Blue as is. No need to add anything.
                                  This is only if you did not do any diode mod to your meter!
                                  (back to back diodes on the input)
                                  • redwire
                                    • 3912
                                    Hey I looked at the schematic and it's already got a 22uF BP cap to block DC and not damage the ESR meter
                                    It must be other shitty ESR meters I've built like the 5-transistor special that need a cap.
                                    Tried a bad 12V 7Ah gel-cell and its ESR 2.3 ohms, a good one is 0.1-0.2 ohms.
                                    • volkswagenvan
                                      Volks
                                      • Mar 2009
                                      • 35
                                      Cool,... You got a new toy!
                                        • 31262
                                        doesnt esr on batteries vary with charge?
                                        i know on 18650's i salvage that they look a lot better after a full cycle
                                        • jayjr1105
                                          • 281
                                          Did a few more minor upgrades. New thicker and longer cables, better banana plugs, cut off the massive finger guards on the probes, and 3d printed a case that holds the meter upright.
                                          Ryzen 3600x
                                          FX-8802 Iron
                                            Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                            by sam_sam_sam
                                            I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                            I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                            12-31-2023, 06:04 AM
                                            Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 I3-1215U 4GB 128GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I3-1215U 4GB 128GB BLUE boardview and IP3 15 I3-1215U 4GB 128GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            09-07-2024, 05:00 AM
                                            Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 I5-1235U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 I5-1235U 8GB 256GB BLUE boardview and IP3 15 I5-1235U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 R7 5825U 8GB 512GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R7 5825U 8GB 512GB BLUE boardview and IP3 15 R7 5825U 8GB 512GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook 300 Specification for Upgrade or Repair
                                            This specification for the Lenovo IdeaPad IP3 15 R5 5625U 8GB 256GB BLUE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IP3 15 R5 5625U 8GB 256GB BLUE boardview and IP3 15 R5 5625U 8GB 256GB BLUE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
