Soldering How-To
  • and_
    • Nov 2005
    • 3
    Re: Soldering How-To
    hello
    i have 220v solder. if i heat it up and unplugg it can i use it to recap my mobo or there is still a risk to burn it down (electric charge) ?
    • willawake
      Super Modulator
      • Nov 2003
      • 8457
      • Greece
      what is the watts of your iron? i understand that 220V is the mains voltage of your iron.
      • Rainbow
        • Aug 2005
        • 1371
        I use AC powered 25W soldering iron - the tip is grounded so that should be safe. There's no temperature control, but who cares if it works fine anyway? I even use a 75W "pistol" type iron - for mosfets which need lots of heat - that one is not grounded but never killed anything.
        • willawake
          Super Modulator
          • Nov 2003
          • 8457
          • Greece
          25W is quite small my friend, your tip must be quite efficient. sometimes i have difficulty with my 60w on some boards.
          • Jay_EE
            • Nov 2005
            Re: DE-Soldering How-To
            Okay, I'm going to give my tips on desoldering in here. I'll give you the 'What has always worked best for me' tips. Being an Electronics Engineer gives me a little insight into this, you could say.
            First off, TRY NOT TO SCRAPE THE HOLES CLEAN WITH AN EXACTO KNIFE. you could very easily damage one of the leads on the INSIDE OF THE VIA for the thru-hole component. Some components can connect to multiple layers of the board (there are more layers than just the top and bottom surfaces) You do not want to damage one of those inner layers, because there is NO CHANCE of fixing that kind of mistake unless you have a detailed diagram of the boards etches.
            Now, for the tips:
            First, I suggest you remove the leads from the capacitor. Capacitors in general have weak leads that go into the case. Sometimes you can just pull a capacitor off the board leaving just the leads left on the board. This makes removal somewhat easier, as you can now grab the lead with a pair of needle nose plyers, one at a time. Pull the capacitor straight upwards and it should lose its leads. If it is taking too much force (it should not be strenuous), then just leave it be and we'll deal with the whole capacitor at once. I like to remove the caps by pulling them off their leads because I have found that sometimes rocking a capacitor can break nearby components (ie, traces, small surface mount objects, like resitors, caps, transistors, etc).
            Moderator comment : i dont like this method, each to his own though.
            Now, for the desoldering. Usually I just use a solder-wick, and apply that to the underside of the board then put heat directly over the wick (with lead still attached). If you heat and reheat solder, some of the softer metals will actually vaporize, and it will also start to oxidize, both of which will make it harder for the solder to flow. Keep the solder wick on top of the trace, and apply the heat until the lead comes free of the hole. Then keep applying heat until you do not see the solder flowing into the wick any more. Move the wick to a dry area (ie, no solder visible on the wick), and repeat once more. This should take anywhere from 3-10 seconds. The longer you apply heat, the more likely you are to peel a trace from the board, so try to keep it on the shorter side. This process SHOULD remove the solder and part in one sweep. IF you do not get all the solder out of the hole in that pass, APPLY MORE SODLER TO FILL THE HOLE COMPLETLY ONCE AGAIN, then repeat the removal with the solder wick. Do not try to wick a hole that is half empty, or you will just overheat the board. Between each try of removal, let the board rest/cool for some amount of time before you try again. Remember, heat is the enemy of the epoxy board substrate. Although it is made to withstand heat, it is not made to withstand high heat for prolonged amounts of time.
            Patience and a little insight and all your holes will be clear!
            ps: If you so desire to use the solder bulb/solder sucker, I suggest removing the cap like above, so the leads are left, then cutting the lead close to the board on the component side of the board (the side where the cap was sitting on). Then, suck the lead out as you heat the hole with lead and solder all attached. Once in a while you will get a lead that gets stuck because it is bent or something, then you can use your soldering iron to push it out, and then grab it while the solder is wet with a pair of needle nose plyers..
            Hopefully this all makes sense and helps some of you.
            Note, I usually set my iron to about 430 degrees F. That is hot enough to melt the solder, but not so hot to vaporize the flux in the solder instantly. You may need to increase the heat a little if the components you are soldering have a large heatsink source attached (ie, large metal component). Some motherboards have their caps attached to an internal ground plane, and therefore carry the heat away very quickly. You may need to increase the heat some to compensate.
            Good luck!
            Jay Kramer
            • and_
              • Nov 2005
              • 3
              #26
              I think it's 50watts
              and yes, 220V is main voltage
              its type is зтп-1
              • Rainbow
                • Aug 2005
                • 1371
                #27
                It's Velleman VTS25:
                Believe it or not - it works for most caps. If there's a large plane on the board, I just add solder to improve heat transfer from the tip.
                • willawake
                  Super Modulator
                  • Nov 2003
                  • 8457
                  • Greece
                  #28
                  its type is зтп-1
                  50w is ok, there is concern about using solder iron gun type which are like 200w+ too hot. I cant see much in your photo but the mains cable looks poor. it is necessary for the iron to be grounded for ESD reasons. does the plug have grounding point or pin? unplug the iron and check with multimeter from the grounding point of plug to tip of iron. should read about 1 ohm.
                  if you work with the iron unplugged then it will cool down while you are working. not recommended to work like that. not recommended to use non grounded iron either.
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    #29
                    Velleman VTS25
                    gotta be the bargain of the year if it works fine. 10 euro on the web?????? great find
                    • Rainbow
                      • Aug 2005
                      • 1371
                      #30
                      I bought it in a local shop, don't remember the price anymore. I also bought a stand - it's a must. I plug it in and let heat up for a while - if the remainings of old solder on the tip can be cleaned using wet sponge, it's ready to work.
                      The tip is replaceable - might be compatible with tips for the more expensive temperature controlled irons - but I still use the original one (it's not very sharp anymore but it doesn't matter for caps).
                      That yellow part is rubber - good for handling but it slowly moves down the handle during work which is annoying. Glue would surely fix this
                      • willawake
                        Super Modulator
                        • Nov 2003
                        • 8457
                        • Greece
                        #31
                        i was thinking it looked like Goot ones
                        • and_
                          • Nov 2005
                          • 3
                          #32
                          it has only two wires and stays hot quite long time (made in good old CCCP ) so i think i should heat it up, unplugg, desold a cap, plug it in and let it to heat up again .. it takes time but right now i don't want to waste money on newer solder that i only use once a year
                          thank you, willawake, for your answers
                          • willawake
                            Super Modulator
                            • Nov 2003
                            • 8457
                            • Greece
                            #33
                            it is going to take time that way. if it has two wires then yes dont use it on the board plugged in.
                            • Rainbow
                              • Aug 2005
                              • 1371
                              #34
                              Found out recently that my 25W iron can even solder/desolder TO-252 and also TO-263 components! It can do it even better than 75W soldering gun, provided that correct technique is used. There are two keys to success:
                              1. add some solder
                              2. lie the tip as flat to the component's tab as possible
                              This maximizes heat transfer between the iron and the component, desoldering it in a couple of seconds.
                              • tazwegion
                                • Jun 2006
                                • 444
                                I usually alternate between 25w & 40w irons, and while a vacuum-tube solder sucker is good, I still need to use a sewing needle (mounted in a hobbyist's knife handle w/ vice tip) to clear those PCB holes on occassion, while heating from opposite side
                                Viva LA Retro!
                                • bpjl
                                  SEF 551.10 - How to raise the temperature of the unleaded soldering furnace?
                                  by bpjl
                                  We continue to struggle with the SEF 551.10 reflow oven. After we managed to start it in october - the topic here -> https://www.badcaps.net/forum/troubl...he-reflow-oven everything promised to be good. But...
                                  While soldering with lead paste somehow goes, but we cannot force the stove to raise the temperature
                                  that he would dissolve the unleaded binder. I even doubted what this bastard shows on screen and passed through it a thermocouple...
                                  03-16-2025, 09:26 AM
                                • CapLeaker
                                  AcuRite 5 in 1 temperature sensor replacement repair
                                  by CapLeaker
                                  Got a new victim:
                                  AcuRite 5 in 1 Iris outdoor weather station not updating the temperature / humidity anymore. The original sensor is a SHT21. Also there are identical other sensor manufacturers. I chose the HTU21D to replace the original SHT21. Both have identical specs. I've had two failure modes with these sensors.
                                  A: outside temp stuck at -40? It's cold here at times in Canada, but not that cold!
                                  B: stuck at some temperature and maybe updating once in 12 hrs or so.
                                  Easy solution is to go to AcuRite website and purchase the sensor. Right?...
                                  04-15-2025, 01:32 PM
                                • datsnow
                                  [Baku 702B] Soldering iron not heating up and the temperature doesn't go up
                                  by datsnow
                                  Hi!
                                  I'm owner of a Baku 702B. I do some SMD work with it, and since I have a spare soldering iron that works very well for the little soldering that I do, I hardly use the soldering iron that this station comes with.
                                  (To add some info, this station went to RMA some months ago, the hot air gun resistance was changed to a new one.)
                                  So, some days I needed to use the soldering iron that comes with the station, but for my surprise, the temperature would not rise. The temperature screen would always show 22/23ºc and no matter what, if I rised or decreased the...
                                  06-26-2018, 09:29 AM
                                • Azurain
                                  Elitebook 840 G5 Bios Chip Soldering Question
                                  by Azurain
                                  I have an HP Elitebook 840 G5 that I am trying to get working again. I've removed the front bios chip (the 32mb one) and have run it through HP unlocker already. I've uploaded and verified the new bin, but am now experiencing an issue that has led me to believe I've been soldering the chip back to the motherboard incorrectly.
                                  Essentially, after re-soldering the chip back into its place and reassembling the laptop, the charging light immediately flashes orange and white and then shifts to a solid white. The capslock and numlock lights blink seven times...
                                  04-14-2023, 06:58 PM
                                • asdas09
                                  Temperature to remove chips from motherboard
                                  by asdas09
                                  What temperature with the heat gun should be use to remove large and small chips from the laptop and mobilephones motherboard? My problem is that the chips not easily remove from the motherboard, example 380°C degrees. I don't know if there is a difference with the devices that the temperature is not stable with them even it shows the right temperature, what should it be? I don't know if I should use higher temperature but the risk of destroying other components?
                                  I have device Sugon 202. I'm used also normal flux and rosin flux.
                                  09-12-2023, 12:44 AM
