Soldering Equipment
  • dreico33
    • May 2018
    • 36
    • Bolivia
    Soldering Equipment
    Hellow Everybody,
    I am new in this forum so if i'll say anything silly i am sorry,
    Like the title says i am looking for soldering equipment. I am on budjet so i'll not go for high end equipment.
    Can you tell / propose :
    1 .Soldering Station
    2. Hot Air Station.
    I would go for Hakko but the prices of 220 v are ridiculus in comparison of 110 v.
    I have heard that some stations can accept hakko tips which are all in one ( tip + heater ) .Is that true?
    I am bettwen atten and aoyue but any recommendation is very welcome.
    Thank you.
    • Jul 2011
    • 6064
    Re: Soldering Equipment
    Are you also looking for a Desoldiering Gun Station if so I can give you a link to some
    • dreico33
      • May 2018
      • 36
      • Bolivia
      What about the ATTEN St Series? Is it Reliable?
      And for Hot Air Station the Atten 858d+???
      Thank you
      • Agent24
        I see dead caps
        • Oct 2007
        • 5037
        • New Zealand
        Define reliable.... It's cheap Chinese gear. It'll work, but it won't be amazing. On the other hand, spare parts might be cheap, too!
        I'd personally go with the basic analogue versions. Less stuff to break so should be more reliable... A basic op-amp control circuit is easier to repair than something with an unknown micro-controller.
        -David VanHorn
        • dreico33
          • May 2018
          • 36
          • Bolivia
          I just want to find the balance between price and performance. I am not gonna buy something high end. I am planning to do some basic motherboard repair. ( Caps Dc Jacks Usb Ports Etc). Reliable well with the meaning of durable.I know the more expensive you buy the less possibilities you gonna end up buy another station after some short period of time.
          Konstantinos.
          • awyatt2
            • Feb 2012
            • 407
            • america
            I have a yihua 952d+ had it for over a year now and it does very well, no problems so far I use hakko tips on the wand and the tips for hot air are the ones that came with it. its probally a knockoff of the aoyue but it has been dependable.
            • mmartell
              • Oct 2013
              • 3189
              For an iron there's alot of good press on the cheap TS100 (google it). As to reliability it may be too early to tell...
              • Y. Signal
                • Apr 2018
                • 77
                • Spain
                If you go for the Yihua 858D or other el cheapo chinese gear please check it before use since it may have serious design flaws: https://www.youtube.com/watch?v=A319o8Ji4oI
                • awyatt2
                  • Feb 2012
                  • 407
                  • america
                  I did redo mine so the fuse is on the white wire, all ones from china have the same setup ,ground fused, as far as grounded tip the ground to case was fine.
                    master hoarder
                    • May 2008
                    • 12175
                    For a soldering station, I recommend anything that uses a T12 or T15 -type of tip. These are the ones that have the heating element and sensor built into the tip and they have pretty good performance, especially considering their price ($2-3 USD per tip usually). AVOID stations that come with "900M" style tips.
                    As for the station itself, go with whatever your budget allows. That said, I do recommend getting a station that has at least 60 Watts of output if you plan to do work on motherboards. I have a 75 Watt station (CSI 2900 - a close of the Aoyue 2900, I believe) and with several large tips (namely a T12-D52 bevel tip), there's almost nothing I can't desolder with it. I even often use it with my 30 Watt soldering iron to remove TO-252 MOSFETs directly from motherboards without hot air or pre-heating.
                    Now, for hot air... I can't really make a good recommendation. I acquired a KADA 852D+ from a friend of mine a few years ago and I still haven't outgrown it. But then again, I hardly do any work that requires hot air anymore, so I can't make any suggestions. I have heard that stations with a fan in the handle (not an air pump in their base) a better. I've used one briefly, and indeed they are more quiet and just as powerful (if not more powerful), so they may indeed be better. They are pretty cheap nowadays too.
                    Whatever you get, I do recommend that you open it and double-check all the wiring and soldering before powering it on. It's possible that some of these stations may have safety flaws. The majority of them, however, are just built too cheaply and so may have crappy soldering that needs fixing.
                    • dreico33
                      • May 2018
                      • 36
                      • Bolivia
                      Thank you very much for your answers guys.
                      As for the solder station can you recomend me a t12 - t15 solder station?? ( Not Hakko Not 110 Volts I Nedd 220 Volts)??
                      And as far for the Hot Air Station i'll go either 858d+ o 852d+. Can you recomend me a good one?
                      Lastly i was wondering if i need a pre-heater for desolering Smd or Any Kind of PuchThrough Devices (Usb Dc Jacks Hdmi Ports etc) or for this kind of work you only need a Hot Air Station.
                      Thank you very much guys one more time/
                      • llonen
                        • Sep 2014
                        • 495
                        • hampshire
                        If you are after a hakko hot air station then you might consider a second user FR802 or 801, they seem adequate and can be obtained on the second hand circuit cheaply. I find it adequate for my professional work until such time as I find something better. Now as to soldering equipment all of my other soldering stations and hand pieces are Pace, will provide a list if you are interested.
                        • tomodachi
                          • Apr 2012
                          • 607
                          • Turkey
                          For the hot air station I strongly recommend Quick 861DW,
                          see; https://www.youtube.com/watch?v=ChujyTV-HME
                          • sn4k3
                            • Oct 2016
                            • 68
                            • Portugal
                            861DW for hotair.
                            Soldering station: ERSA Nano or ERSA I-CON 1
                            If you want go cheaper you always have the T12 clones and TS100 which is great with minor modding eg: https://www.ebay.co.uk/itm/TS100-Sol...3NymjL1fIO7esg
                              07-01-2024, 06:34 AM
                            • chth96
                              What soldering station should I purchase for 900M-TJ-I tip?
                              by chth96
                              hello.
                              A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
                              https://ko.aliexpress.com/item/4001275635593.html
                              Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
                              Any reply would be appreciated.
                              11-24-2023, 05:08 PM
                            • SarcasticOP
                              Seeking Guidance on Motherboard Diagnostics
                              by SarcasticOP
                              Hello everyone!
                              I hope this is the correct place to post this, if not please let me know and I will post in the appropriate location.
                              I'm venturing into the intricate world of board repair within electronics, and I'm reaching out to this community for some guidance and shared wisdom. I have tried to do some research myself and find this information on my own, but I don't know what I don't know, and that is really starting to become an insurmountable issue that I cannot overcome. The only person I had nearby that I could turn to passed away recently so I do not have anyone...
                              01-10-2024, 03:35 PM
                            • mkbehbeh
                              KSGER C245 Soldering station PSU 220V only?
                              by mkbehbeh
                              I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
                              I am...
                              04-17-2023, 03:11 PM
                            • Peter_1402
                              Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                              by Peter_1402
                              Hi Everyone,
                              I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                              1. Soldering iron works great
                              2. There is a burnt mark on the hot air gun handle.
                              I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                              Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                              Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                              Reed switch tested ok with a magnet.
                              From the above test, I can conclude...
                              07-12-2025, 11:50 AM
