Did I blow powerboard with Multimeter
  • leniko
    • Jun 2017
    • 4
    Hi. Newbie here. I was looking at a friend's Toshiba TV with the blackscreen but power light on issue. First suggested step was to test incoming voltage. I failed this step.
    I put the multimeter to the incoming power source with the tv plugged in and I heard a pop, saw a flash and smoke. Pictures show the settings that I had my multimeter set to and the resulting blackened area (bottom right) where I attached my multimeter.
    I'm thankful I'm alive but would like to know did I "fry" the power board? Is there a way to test this? Sorry, but if so, could you explain whether I need to adjust the probes on my multimeter and what setting should I set it to?
    Re: Did I blow powerboard with Multimeter
    Where are the pictures so we can see how the meter was set to, and also the pictures of damages?
    BTW, you can always ask us first before attempting to make any measurement, especially in the HOT DEADLY side of the circuits.
    • R_J
      • 9535
      I will guess probe was in the current jack, not the volt/ohm jack, that would do it
      • leniko
        • Jun 2017
        • 4
        Sorry. Forgot the attachments. I'm dumber than I thought.
        • leniko
          • Jun 2017
          • 4
          An update. I went back to his place today and put black probe of multimeter to ground and red probe on different wire connection points and all the ones I checked still had voltage. Also standby light still comes on in front of tv when I turn it on (same as before I checked voltage first time and caused smoke, etc).
          • R_J
            • 9535
            The dial on your meter is set to 10 AMP! If you are measuring AC voltage it should be on the ACV 200
              • 31009
              put a new battery in the meter first.
              • retiredcaps
                • Apr 2010
                • 9271
                Before you continue, see this 5 minute video on how to use a multimeter.
                https://www.youtube.com/watch?v=bF3OyQ3HwfU
                Those cheap/free Harbor Freight meters are not forgiving of an "oops" moment.
                --- begin sig file ---
                --- end sig file ---
                • eccerr0r
                  Solder Sloth
                  • Nov 2012
                  • 8701
                  Actually, the harbor freight meter seems to be open when the probes are plugged into Volts and COM when the selector is at 10A mode.
                  All bets are off if the probe is plugged into 10A and COM regardless of the selector. The meter is unfused and will kill itself and possibly whoever's using it, if not careful...
                  On the other hand, if the power light is on, I think you should be able to safely deduce that power is getting in, and usually you can omit this step (and treat the circuit as LIVE as always.) It looks like the blackened spark area is near the inlet which is fairly robust and likely you didn't do too much more damage whether you shorted it with the multimeter in the 10A range or accidentally bridged the two incoming power wires with the long metal part of the probes near P801.
                  Thankfully likely nothing expensive got damaged like self. At most a fuse or breaker blew, and hopefully the power cable wires are still good (check insulation very carefully for any melt.)
                  • goontron
                    5000!
                    • Dec 2011
                    • 4108
                    • US
                    Normally I would make a snarky comments that the wires won't melt.... But after converting a Pakistani lamp for US use, I would believe it. It had 32Awg, at most.
                    Follow the white rabbit.
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Leds are out any way Lg E panel so testing psu was prolly pointless
                      • dropfry
                        Can an overheating bga blow out a powerboard?
                        by dropfry
                        Hello, guys. I fixed a monitor the other day, but I don't have a strong understanding of electronics and was curious about how the PFC and a couple of mosfets on the powerboard blew out. Here is what was known about the monitor:
                        I bought it "as-is" hoping to salvage it for replacement parts. However when I plugged it in it powered up and worked fine for about an hour. After that the monitor's power would be very irratic and turn off and on several times. I opened it up and noticed that the mainboard had a faulty heatsink on the main BGA chip. Not only was it not making...
                        09-20-2023, 10:26 PM
                      • PantherDave
                        by PantherDave
                        Hi all!
                        05-29-2024, 02:01 PM
                      • Jane
                        How do you test MOSFET in laptops ?
                        by Jane
                        I tried to use this method:
                        Testing an N-channel MOSFET:
                        Step 1: Discharge the Gate (turn off the MOSFET)
                        Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                        Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                        Step 2: Charge the Gate (turn on the MOSFET)
                        Now, place the red probe on the Gate (G) and the black probe on the
                        09-27-2024, 03:31 AM
                      • dj8452000
                        How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                        by dj8452000
                        I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                        02-18-2025, 08:28 AM
                      • trex66
                        Craftsman 82345 Multimeter broke!
                        by trex66
                        My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                        03-04-2025, 04:26 PM
