Any Substitute for Iso Propyl Alcohol IPA that could find in a general hardware shop?
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    Another little problem lol
    I need something to remove flux etc from PCBs after rework. I normally use IPA for this, when I am in the UK.
    But I spend most of my time in Gran Canaria now where I am doing some repair work and hopefully setting up a new workshop soon. Now the problem is with IPA... I can't bring it with me on the plane in hand luggage and flammable liquids are banned in hold luggage too.
    Getting specialised items like that is not so easy on a small island - So does anyone know of some substitute that would be available in a general hardware store, or Ferreteria as they are called here?
    I have the same problem with Switch Contact Cleaner and Freezer spray as pressurised containers are also a no-no on the planes
    I've tried Absolute Vodka and it kinda works as a flux cleaner but it is too 'wet' and I wouldn't like to power up a board afterwards until the next day, though putting it out in the sun here would dry it pretty rapido.... and sunshine is something we have in abundance!! Anyway, the missus says that is a waste of damn good vodka!
    Rich
    Any ideas?
    Follow me on YouTube
    Learn Electronics Repair
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Any Substitute for Iso Propyl Alcohol IPA that could find in a general hardware s
    Pharmacy or grocery stores might sell 91% IPA. General stores like Wal-Mart, Home Depot, etc might sell 50% to 75% IPA.
    --- begin sig file ---
    --- end sig file ---
    • dmill89
      • Dec 2011
      • 2534
      Acetone works pretty well (though you have to be careful what you use it on as it will melt some plastics), but I doubt it is much easier to get ahold of than IPA is.
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        I would venture to say all grocery stores should carry 70% isopropanol (that 30% is purified water). Drug stores and grocery stores with drugstores will carry 91% azeotropic isopropanol, and some may carry 99% (in the USA, Safeway seems to have 99% but concentration not tested). Only junk stores carry 50% (like Dollar Tree in the USA.) Any stores that sell 50% should be dragged out into the street and shot.
        Though salting out water-IPA solutions should work fine, I'd suggest against it.
        And I found that acetone was a bit harder to get... Denatured Alcohol (ethanol) also could be used in a pinch and this should be available in hardware stores (if they don't carry isopropanol too).
        • piernov
          • Jan 2016
          • 4437
          • France
          Here it's not very easy to get either ethanol or isopropanol in large quantities, so I use alcohol with 90% ethanol and 10% methanol sometimes. I prefer to use acetone instead since methanol is highly toxic, but acetone can't be used on every surfaces so it depends on what I'm working on.
          OpenBoardView โ€” https://github.com/OpenBoardView/OpenBoardView
          • petehall347
            • Jan 2015
            • 4427
            i dont find it so easy here to buy in a general shop .but can buy it as switch cleaner 97 percent from car spares supplier no problem in aerosol cans .
            • megaraider
              • Jul 2015
              • 307
              • Portugal
              @dicky96
              You can use a better IPA replacement than acetone (nail polish thinner / remover).
              I'm sure that although being a small island you will find car paint shops.
              These are bound to have paint thinner, also referred to as a filler, dilutant, diluent.
              Be careful, besides melting plastic it is highly flammable!!!
              • mariushm
                • May 2011
                • 3799
                Acetone was already mentioned. Should be fairly easy to find.
                You may also want to look into LCD screen cleaning solutions (usually sprays). They're typically around 50-70% isopropyl alcohol, almost all the rest distilled water, then in tiny percentage perfume and sometimes preservatives (i guess to keep the perfume from going bad or perhaps reduce the risk of bacteria growing in water, if it's even possible)
                On the more active side (stronger, and you should normally use it in well ventilated areas and with gloves) you could use paint thinner - most compositions are in large proportions acetone, turpentine, toluene, naphta... all of these are solvents that will clean the surfaces. Note that these would attack plastics and paints so you may loose silkscreen on pcb (printed text) or color could come out of pvc/plastic sleeves on capacitors and other components.
                In some situations, the enamel (insulation) of wires in inductors/chokes could be damaged by such strong solvent.
                But after use, you should really clean the surface with sanitary alcohol or distilled water.
                • dicky96
                  Sun Seeker
                  • Mar 2017
                  • 1825
                  • Spain
                  Thanks for the suggestions. One thing I can easily get here is Absinthe and some of that is 85% alcohol by volume (ethanol I would presume). I guess I could try that
                  Rich
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    Another possibility: Auto parts store: Drygas usually is isopropanol (though watch out, some use methanol).
                    I really would not use acetone as a straight substitute. It can only be used as a substitute in certain situations else each have their specific uses... I'd use denatured alcohol, even with its methanol for isopropanol before using acetone.
                    Except when using it to disinfect human wounds (unless I know what the denaturing agent is), then again I wouldn't use acetone to treat wounds either.
                    • Silveruser
                      • Nov 2015
                      I don't think Absinthe would be a good choice the green fairy might get you!
                      I don't know if Vapping is a thing there but I noticed a while back one of the local corner store / Vapping shop had gallon jugs of 99% IPA, not cheap @ 50$CDN. I have no idea what they use it for but you never know where stuff will show up.
                      • sofTest
                        • Aug 2008
                        • 361
                        Check your local petrol station, if they got any additive to remove water from petrol tanks. They usually contains a high percentage isopropyl.
                        Be a mensch
                        • diif
                          • Feb 2014
                          • 6978
                          • England
                          Rich
                          Absinthe is for drinking and getting f****d up on. Not for wasting trying to clean stuff.
                          If you're planning on having a permanent repair shop over there, perhaps investigate one of the chemical companies that supplies the islands.
                          Failing that you should be able to use acetone in cheap nail polish remover, but avoid using it near plastic.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            what about car clutch and brake cleaner? ive used it in the past it did a really good job but not 100% sure if ok for pcbs
                            • dicky96
                              Sun Seeker
                              • Mar 2017
                              • 1825
                              • Spain
                              Hi guys thanks for the continued suggestions.
                              A spanish member on here got in touch via PM and told me to get Alcohol de Quemar 'para encender y limpiar' from the local supermarket which basically means Alcohol for fires (barbecues) and cleaning.
                              I found a litre of this in the local supermarket for a couple of euros.
                              Limpiar translates as 'cleaning' and it also says 'desengresante domestico and limpieza cristales'
                              So that is 'degreaser and glass cleaner'.
                              There are no exact list of contents but it does say it contains ethanol and does not contain methanol.
                              It smells more like vodka than meths.
                              I tried that on a pcb and it seems to remove flux OK and evaporates fast.
                              Oh and it does indeed help to light the barbie.
                              rich
                              • Chungalin
                                • Jul 2014
                                • 422
                                • Spain
                                Let’s not complicate things: any spanish supermarket have 96ยบ alcohol that is poor man’s flux-off, but it leaves residue. You can buy IPA at any pharmacy!
                                • delaware74b
                                  • Apr 2009
                                  • 628
                                  Most brake/clutch cleaners are pretty aggressive to plastics. The cleaner I use contains toluene, acetone and MEK (methyl ethyl ketone). Great for stripping flux, no residue - just watch the overspray and where it runs.
                                  Stupidity should be a crime, especially for drivers. I have NO patience for them.
                                  • srhofmann
                                    • Aug 2016
                                    • 135
                                    • usa
                                    Really aggressive, MEK can dissolve potting material. I wonder if something like MAP sensor cleaner would be better. But if you've got access to an auto parts store they should have electrical contact cleaner which would probably be your best choice.
                                    • ClockChip
                                      Isopropyl alcohol as a cleaning agent?
                                      by ClockChip
                                      Hello All,
                                      I wanted to check with the board before I do anything foolish and/or irreversible. Can someone please set me straight on the use of isopropyl alcohol to clean electronics? I understand it is commonly used to clean electrical contacts. However, in this case, I am wondering if I can safely immerse a small electronic item in alcohol provided a) all power has been removed and b) I take care to dry it thoroughly before re-applying power.
                                      The short version is that I am seeking to clean an older used (well-used) electronic item. The basic plan is to immerse it in...
                                      03-16-2024, 12:10 PM
                                    • odonono
                                      Louis Rossman style repair shop for regular laptops?
                                      by odonono
                                      I made a post over on reddit about how my windows laptop only works when plugged in now, because I dropped a screw driver on the connector pins where the laptop battery plugs into, causing sparks. I put a brand new battery in but still the same result, so something on the board obviously got fried (however, there's no visible burn marks, so no clue what was affected). I honestly wouldn't care, but my laptop is power throttling even with the internal battery unplugged (turns out this is a common problem on laptops with poor batteries or missing batteries). The GPU won't go above 40W when the TDP...
                                      03-06-2024, 07:31 PM
                                    • dicky96
                                      Air Con PCB repair : some general question
                                      by dicky96
                                      Hi guys
                                      I've been getting more air con controller boards of various brands for repair - mainly the ones from the outdoor compressor unit and I realise I have a lot of gaps in my specific knowledge, while being pretty good at electronic repair in general.
                                      Does anyone know of any good resources for information on this sort of repair? I'm hoping here there will be some guys who are experienced in this. I'd specifically like more info on how the controller PCB works, because I expect they are all pretty much the same, and especially how it communicates with the indoor unit (protocols,...
                                      11-22-2024, 04:40 AM
                                    • kingiii
                                      A very general question...
                                      by kingiii
                                      A very general question, when inject voltage and board draw over 4a and pull down 5v to 1v, but nothing is hot under thermal camera. Can I assume it is layer short? or it could be something very typical that I just have no idea of being a noob.
                                      11-16-2024, 03:58 PM
                                    • Whale linguini
                                      General Question(s) & Question About USB Jtag u-Link NT
                                      by Whale linguini
                                      I'm not sure if I am posting this in the right spot, I don't have any question or anything specific to one board. I am *kinda* starting out with this kind of work. I have been IT in one role or another for my job the last 30 years, and I am familiar enough with basic board stuff generally speaking. So, I dunno for example if someone told me to find a uart header, or flash some generic tsop8 something, etc I understand that kind of stuff. Point being, I'm not 100% clueless. I just don't have the specific knowledge when it comes to some of these more advanced repairs. I actually have spent the last...
                                      07-26-2024, 02:12 PM
