Air Con PCB repair : some general question
  • dicky96
    Sun Seeker
    • Mar 2017
    • 1825
    • Spain
    Hi guys
    I've been getting more air con controller boards of various brands for repair - mainly the ones from the outdoor compressor unit and I realise I have a lot of gaps in my specific knowledge, while being pretty good at electronic repair in general.
    Does anyone know of any good resources for information on this sort of repair? I'm hoping here there will be some guys who are experienced in this. I'd specifically like more info on how the controller PCB works, because I expect they are all pretty much the same, and especially how it communicates with the indoor unit (protocols, method etc). I can generally fix these boards if they have an obvious problem such as burnt components, low value power resistors gone high, shorts, low voltage (standby) PSU not working etc etc. The ones I am struggling to understand is where the board will power up on my bench, On these boards I have 12V, 5V, 24V whatever and often have some flashing LEDs and hear relays clicking so the microcontroller is doing something at least but the customer is reporting some error code like EL10 or F4. I need to understand how this works, where the errors are coming from (microcontroller on the outdoor unit board?) so I have some chance of diagnosing the fault. Another thing I have read about is the eprom on the controller board often causing this type of error. I've tried to find out if this eprom holds firmware or if it just holds preset user data but that info seems hard to come by. In other words is this a common failure ,can they just be replaced, or do I need firmware and if so where to find it. There are a lot of aircons here and talking to companies who fit them, nobody on the island is repairing the boards. So that sounds like good business to me. Another thing I am interested in is putting some sort of test rig together on my bench to help me. For example I already use an old passive PFC choke as a makeshift reactor coil to power the boards up.
    So I have a lot of questions in my head as this is a new area of repair work for me, can anyone help enlighten me or at least point me in the right direction?
    Rich
    Follow me on YouTube
    Learn Electronics Repair
    • Jul 2011
    • 6070
    If you are talking about condenser coil defrost boards if so one major failure is the terminal area on the bottom of the board corrosion on the traces bad temperature sensors bad relays for cooling fan operation bad thermostat wiring from the condenser unit to the thermostat on the wall
    Two things to check when the customer complains about the condenser coil freezing up ( in the winter ) first thing to check the temperature sensor fan control relay and a reversing valve relay on some models
    One note some defrost control boards can affect the cooling function especially if it has a temperature sensor for outside temperature and not the temperature sensor on the condenser coil it just will not activate the anti cycling timer and act like the thermostat is bad not necessarily
    If you have the new air conditioner controller boards that have error messages you need to get the troubleshooting manuals and keep them where you can easily find them and if need be call the manufacturer for the air conditioning unit if you do not understand the error message that is given
    On occasion I have had to do this because the information given in the manual does not really make sense sometimes do not be afraid to call tech support for a better understanding of the error code message
    One note on variable speed evaporator cooling fans and variable speed compressors are sometimes a nightmare to figure out what is going with them
    One thing about variable speed compressors some controller boards have a troubleshooting function that can sometimes help you find the cause of the problem that are going on you need to find the troubleshooting manual for how to use this feature some of these troubleshooting functions are not all like and some of them are worthless because they are trouble makers that they are not worth anything for troubleshooting any kind of issue
    One other note sometimes defrost board are to badly damaged from a very bad voltage spike or by lightning and not worth trying to repair them one word of caution be careful of some manufacturers recall notices because sometimes this what is causing the issue at hand you have research the problem you are faced with if you have not seen this issue before
    Here is a case in point I once went to a customer home to look at his dishwasher because it was doing weird things that it was not supposed to do things like you would select a certain type of cleaning cycle and was supposed to have a certain amount of time well this was not what it was showing unfortunately and the other weird thing was the timer was not counting down continuously either some times it would get stuck doing the rise cycle and not go to the next step so I did some research on where to buy another controller board well I found that but that was not the only thing I found I found several forums that talked about the issue with this particular controller board how even replacing the controller board a week or a month later you could have the same issue again with the controller when I told the customer about what I found out they decided to buy a brand new dishwasher and the one they had was a little over two years old no extended warranty was purchased at the time of purchase
    I once went to a customer house and he tells me that what is weird was the evaporator cooling fan would not always turn on when the thermostat was calling for cooling oh really I like to see this and sure enough when the thermostat was satisfied and went to cycle back on again the cooling fan was barely running and then just stopped turning altogether hun I look at the back of the fan motor and it was a variable speed fan the one that has the VFD module mounted on the back end of the motor these things are expensive to repair if you can still get the modules but when I got the price of the module versus the complete motor and VFD module there was only about $75.00 different in price the customer opted to buy all of it brand new over $500.00
    One note about checking the functionality of a defrost controller board off the condenser unit I not sure if this can be done reliably or not because when I repair them I reinstall in the unit to test them to make sure that they are functioning correctly or not
    In a past life I used to do air conditioning work for a living and you would not believe some of things I have learned and run into
    • SolomonMan
      Nest Thermostat Discussion...
      by SolomonMan
      All,
      I was over my sons place helping him with projects today. (Broken Dryer Belt, a Couple leaking pipes (One cracked - that got me over there),and Thermostat swap.
      The Energy company offered a Rebate on the Nest Thermostat System (Not the Learning One) last year and we picked it up and its sat in the shipped box for about a year now.
      Anyways I was thinking it would be a quick job as I currently have a Nest Learning Thermostat at my place and it was not a problem to install. (Old Rheem 90 Furnace)
      At my boy's place he has a York Stellar...
      12-11-2022, 10:54 PM
    • domix
      LG Air Conditioner AC unit bypass
      by domix
      i have Lg AC indoor unit connected to heatpump warm water. To flow thru unit. I have it to heating up garage. I have previus old indoor ac unit. It was only connected to power supply and is was woking.
      Now i have new one which has a problem, it needs outdoor unit. It has error, 5 blinks which means that outdoor unit is not connected.
      how can i bypass this :/
      I need only to turn on and i need only fan to blow, and adjust speed od fan. To blow over a warm pipes....
      11-25-2025, 02:54 PM
      Alexia thermostat is this a good idea for for controlling your air conditioning system feedback wanted
      My wife is asking me about getting one because our electric bill was that it has ever been even more than last year at this time nothing has really changed since last year last month unless the electric company has done some fuel adjustment charges I have not done any investigation into yet but I might have to but there was a time back a few years ago that I use to set the temperature warm during the day when we were not home but when we got wooden floors in our house and you have to keep the humidity down to keep it from warping I just set to a temperature to 75*F to keep the humidity down but...
      06-22-2025, 10:23 AM
    • ngml
      Repair of an LG split AC system indoor unit PCB
      by ngml
      I am trying to repair an LG split AC indoor unit, which does not start and gives a CH05 error code.
      This indicates an error in the communication between the outdoor and the indoor unit.
      The outdoor unit is fine, so the problem is the indoor PCB.
      The indoor unit is an LG PC09SQ NSJ (3SNM09JA2FA), and the PCB has the following type number: EAX35907219-1.2 (see photo1)
      I changed optocouplers ICO1X & ICO2X and the NPN transistor S9013 which drives optocoupler ICO2X (see photo2), but this did not remedy the fault.
      Does anybody have the schematics of this board,...
      02-01-2025, 12:55 PM
    • CoinCoin88
      Garage door RX unit (Cardin S38C) does not short relay to send opening signal
      by CoinCoin88
      I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
      Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
      09-15-2025, 03:36 AM
