Isopropyl alcohol as a cleaning agent?
  • ClockChip
    • Jul 2023
    • 14
    Hello All,
    I wanted to check with the board before I do anything foolish and/or irreversible. Can someone please set me straight on the use of isopropyl alcohol to clean electronics? I understand it is commonly used to clean electrical contacts. However, in this case, I am wondering if I can safely immerse a small electronic item in alcohol provided a) all power has been removed and b) I take care to dry it thoroughly before re-applying power.
    The short version is that I am seeking to clean an older used (well-used) electronic item. The basic plan is to immerse it in alcohol, shake it dry, then set it in the (mild) sun for a week. Frankly, this thing is so grimy that I am seeking to disinfect it as much as clean it, hence the desire to give it an alcohol bath.
    Is this a bad idea? Or is it perfectly reasonable provided I give it plenty of time to dry afterward? Also, Isopropyl alcohol seems to come in different concentrations. Should I make it a point to use the 91% stuff, or will any concentration do?
    I would be grateful for any advice on this.
  • petehall347
    • Jan 2015
    • 4444
    i wash first in hot soapy water then use the isopropyl to finish off then blow dry with the airline . go high percentage like 97 percent or more .
    • harp
      • Jun 2022
      • 643
      • Planet Earth
      Use only 99% ipa or higher dehidrated alcohol for electronic
      Avoid to pour in it fine optics or mehanics, like camera, speaker, microphone, sensors etc... the this things must be removed before cleaning or protect against liquid penetrate.
      Anything thats it disolved in it after cleaning must be quickly soaked from pcb first with towel, then dried, not only left on pcb to dry...
      Cleaning proces repeat 2-3 times to ensure to remove dirt from pcb to towel
      Alcohol is great for disolving rossin from flux, and help with removing water, but it is not so good for cleaning fats, soup and other sweet sirup. If the device is nasty, you may have to first washup in some detergent in water, soap on brush etc, and then cleanit in ipa to help remove water and desinfects surface.
      Always use brush in cleaning like toothbrush, it is generaly better then towel, and always use towel like wc or kitchen towel to soaked it up.
      What item is your concern, and what parts wish to clean?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8340
        99% IPA or Acetone
          • 31258
          NOT Acetone!!
          it will take the paint off resistors.
          IPA is "Safe and Effective" - for real this time!
          it'a also a bit expensive so the method i use is put it in a pump-spray bottle,
          spray the board and rub it in with a brush.
          then put the board on it's edge on a bit of kitchen-towel and spray it again and brush downwards,
          repeat a couple of times to get all the disolved crap onto the paper.
          it takes minutes to evaporate after - you dont need days.
          • CapLeaker
            Leaking Member
            • Dec 2014
            • 8340
            If paint comes off with Acetone, you’re doing something wrong. A quick clean does zero paint removal of the board. It does clean like a SOB… try it on a junker board.
            • petehall347
              • Jan 2015
              • 4444
              i use electrical cleaner in a spray can . its only £3 a big can . its just isopropanol
              • harp
                • Jun 2022
                • 643
                • Planet Earth
                Carefuly with acetone, it has known noticable health hazard throug skin contact or vapour to internal organs, like acumulated toxic properties.
                Also, it melt some plastics and coating using in electronics part or housing of device.
                It is agresive to much, I dont recommend using it in general for cleaning, only special purposes.
                  • 31258
                  your Acewtone is not pure - are you buying "nail varnish remover"? thats watered down.
                  • redwire
                    • Dec 2010
                    • 3912
                    OP, it depends on what kind of dirt is on the board. What is it?
                    Soaking a PC board in IPA does not really clean it, after a soak you have to use an old toothbrush and scrub gently. Staring at it immersed in alcohol does not remove much. Think about washing your car.
                    Some components do not tolerate a wash, like buzzers, potentiometers and switches because they have lube in them that gets washed out. Have not used acetone because it can destroy some plastics.
                    For soda pop spilled in a TV remote control, I soak it all in hot water with dish soap and gently toothbrush and rinse. The carbon-print can come off if you are aggressive.
                    Oily dirt, like tar and nicotine I use Fantastik if it's really bad.
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8340
                      Not watered down shit. Pure out of a Liter can. I just don't flood the whole area, rather just dip the toothbrush in it and rub away. Fastest clean up job on any PCB. Lettering only starts to go away if you douse it repeatedly and scrub like crazy.
                      to clean whole boards, I use hot water with Dawn dish detergent and a ultrasonic cleaner. Also works wonders.
                      • MORETTIGIAN
                        by MORETTIGIAN
                        Title:
                        Description:
                        Procedure performed:
                        - Removed backplate
                        - Reapplied thermal compound
                        - Reassembled card
                        09-18-2025, 12:14 PM
                      • rumi409
                        LG OLED C1 Pixel Cleaning Made Picture Worse
                        by rumi409
                        ​​​​​​ Hi,
                        I'm trying to resurrect a LG OLED C1 TV that has some panel banding. I used the TCON error bypass to get a picture. I was able to update the firmware as well. But when I performed a pixel cleaning to try to get the banding out, it made the image significantly worse. I tried to undo the effects of the pixel cleaning by performing a factory reset and IN_Stop, but that didn't work. Any way to reset pixel cleaning data?...
                        11-15-2024, 01:09 AM
                      • Twiesel
                        Asus ROG Strix B450-F Gaming II stuck on POST
                        by Twiesel
                        Hey y'all,
                        I am currently working on an Asus ROG B450-F Gaming II ATX Mainboard. The board is in very good condition (no missing components/scratches), but when I power it on using a Ryzen 3 1200 and one stick of DDR4, it gets stuck at 1,4A with none of the POST-LEDs lighting up.
                        I checked all voltages, which are present. The CPU gets slightly warm.
                        What I did try:
                        -Resetting CMOS
                        -Reflashing BIOS (manually and using the flashback tool)
                        -"cleaning" the socket with isopropyl alcohol
                        -using several sticks of DDR4 in every slot...
                        12-01-2024, 04:14 PM
                      • otoluk
                        Auriol weather station humidity sensor
                        by otoluk
                        I have two Lidl LD6273 Auriol units with DCF77 radio for time update.
                        I really like the idea but the cheap moisture sensor(guess HR202L) inaccuracies make the device unreliable. Also not clear why indoor and outdoor unit sensors being same type doesn't match. For example I place both units on same table and indoor unit shows 23% humidity while outdoor sensor shows 39%. What I found out is that I get better readings if cleaning the solder points of sensor inside with isopropyl alcohol.
                        Looking for replacement sensor which I could solder in place of HR202L resistive sensor but need...
                        11-06-2024, 07:57 AM
                      • acedogblast
                        by acedogblast
                        11-02-2024, 05:13 PM
