General Question(s) & Question About USB Jtag u-Link NT
  • Whale linguini
    • May 2024
    • 30
    I'm not sure if I am posting this in the right spot, I don't have any question or anything specific to one board. I am *kinda* starting out with this kind of work. I have been IT in one role or another for my job the last 30 years, and I am familiar enough with basic board stuff generally speaking. So, I dunno for example if someone told me to find a uart header, or flash some generic tsop8 something, etc I understand that kind of stuff. Point being, I'm not 100% clueless. I just don't have the specific knowledge when it comes to some of these more advanced repairs. I actually have spent the last few years doing a lot of flashing and board work in the automotive world, so much is more or less the same.
    As an example, I have been reading that in order to do the MEC16xx on a t14, the only tools that can do it are the SVOD or RT809H which are the only two that support this. I was somewhat curious what else is out there, and I found this USB Jtag u-Link NT. Which claims support for the MEC16xx. I was just wondering if something like this would work or not. To me it seems that if the chip is supported, then it should be just fine? Or am I missing a caveat of some type? for myself, if I was working on some chip that for whatever reason was hard to red/flash, first thing is just pull it off the board to flash and make life easy. So does this come down to just the software for the SVOD or RT908H that has some extra function needed? Which then I am sure only runs on each tool respectively.
    Also the usb jtag u-link nt just looks like a st-link to me. Which is one thing I have been generally curious about as these little things seem to pop up a lot. I would assume when you see something that looks like a st-link, but is more application specific labeled, does the developer flash new software to the st-link when they are making their software to use with it? Or are all of these just identical with different stickers on them.
    I understand many here do lots of work, so having one of those tools more or less meant for computers specifically, is nice to have a tool like that.
    I hope this makes sense. I am trying to ask in a very general way. I still get confused about some things.
  • mon2
    • 14673
    Post the request in the bios section. The tools are proprietary and based on custom fpga firmware.
    • Whale linguini
      • May 2024
      • 30
      Ok, I wasn't sure where to post, I guess I didn't mean anything specific to bios either. I also found that device is not just a st-link either.
      • rogfanther
        • Jul 2006
        • 458
        • Brazil
        In a general way, as you put it, the jtag NT is for , well, jtag. Not like ST-Link, that is directed to arm programming. Well, both can do other things, but I mean in a general way.
        You should ask the jtag NT guys what do they offer to program the MEC. Adapters, software, etc. Other software can probably program it, but those mentioned ( SVOD and RT ) have already determined adapters, compatibility, etc.
        • Whale linguini
          • May 2024
          • 30
          Yes I have been meaning to jump on their forum. I did figure out that the HW used is actually just a off the shelf (sorta, it is customized to an extent, but it looks like it operates exactly the same) CY7C68013A-56 EZ-USB FX2LP dev board, which is only a few dollars. Not that $70USD is very much, probably better off supporting them. I guess if for some reason you are unable to get one in your country, perhaps that could be a work around. I have not verified anything yet. Meant to post on their forum.
          • dicky96
            Air Con PCB repair : some general question
            by dicky96
            Hi guys
            I've been getting more air con controller boards of various brands for repair - mainly the ones from the outdoor compressor unit and I realise I have a lot of gaps in my specific knowledge, while being pretty good at electronic repair in general.
            Does anyone know of any good resources for information on this sort of repair? I'm hoping here there will be some guys who are experienced in this. I'd specifically like more info on how the controller PCB works, because I expect they are all pretty much the same, and especially how it communicates with the indoor unit (protocols,...
            11-22-2024, 04:40 AM
          • kingiii
            A very general question...
            by kingiii
            A very general question, when inject voltage and board draw over 4a and pull down 5v to 1v, but nothing is hot under thermal camera. Can I assume it is layer short? or it could be something very typical that I just have no idea of being a noob.
            11-16-2024, 03:58 PM
          • acedogblast
            by acedogblast
            11-02-2024, 05:13 PM
          • nobbnobb1
            General Question - Rebuilding Lithium Ion Battery Packs on Mobile Devices/Laptop
            by nobbnobb1
            Hi guys,
            Just a general question. Usually on mobile devices/laptops the battery pack consists of lithium ion cells with their +/- tabs welded onto the controller IC. I'm wondering, in general if it can be assumed that one can find a replacement lithium ion cell, is it ok to simply re-use the old controller IC in an attempt to re-build the pack? Or is that controller somehow paired to the cells from the factory?
            From my experience it sometimes seems to be hit or miss. Not sure if this is true, but sometimes it's almost as if the controller IC will go to a failsafe...
            12-25-2022, 01:02 PM
          • coolshrimp
            T14s - MEC-1663 - Jtag - Pinout - Bios Password Removal
            by coolshrimp
            Here is all the info you should need to remove bios password from your same model or one with an MEC-Chip and also write back the config data
            See Diagram for Wiring.
            Use MEC-1633#ISP on your RT809h
            This is same Jtag pinout and method for T490S/X390
            (But your R/W 10K Resistor Location May In a Different Location)
            MEC-Chips Store Bios Password In a Secure Un-Editable Area
            Following steps clear that secure area to re-initialize itself to default (Blank)
            10-24-2022, 12:18 AM
