Bakon BK950D
    • 31063
    Bakon BK950D
    just got one.
    so as you do - i stripped it
    soldering and component placement is good.
    quality feels good.
    input is fused, has an inrush limiter & a choke before the rectifier.
    nice design
    well worth £18 i spent on it!!
    now the fun part - i know your all wondering.
    the caplist!
    primary smoothing,
    100uF 400v 18x30mm CHONG brand 105' no series marking.
    secondary's
    1000Uf 25v 10x20mm JWco brand CH series??
    1000Uf 25v 10x20mm AE brand KF series.
    and
    2x 22uF 50v 5mm AE brand KF series.
    so, who can find datasheets for CHONG, AE & JWco ??
  • Fast Alpha
    • Feb 2013
    • 245
    • United Kingdom
    Re: Bakon BK950D
    Hello stj
    Where did you get it from? what place and if I get it I need a UK plug.
    Also how do you solder a mini jack from 2 satellite speakers????
    eh?
    Also how do you solder a lcd connector on a broken lcd screen.
    http://www.hse.gov.uk/pubns/indg305.pdf
    • diif
      • Feb 2014
      • 6978
      • England
      Re: Bakon BK950D
      https://www.aliexpress.com/item/Newe...692790292.html
      I just cut off the plug and fitted a UK one.
      • japlytic
        • Oct 2005
        • 2086
        Re: Bakon BK950D
        The secondary capacitors are low-ESR series, given that there is a 400V unit in the power supply primary.
        • vinceroger69
          • Mar 2012
          • 6714
          Re: Bakon BK950D
          are the t12 tips that aliexpress sell ok? as i may order one of these irons plus some extra tips as some sellers sell about 8 in a kit
          • diif
            • Feb 2014
            • 6978
            • England
            Re: Bakon BK950D
            No complaints here. I use the chisel T12-K that came with the iron and a fine tip with a small bend T12-JS02 the most (£4 delivered).
            • vinceroger69
              • Mar 2012
              • 6714
              Re: Bakon BK950D
              Thanks i will get them ordered then.
              • Fast Alpha
                • Feb 2013
                • 245
                • United Kingdom
                Re: Bakon BK950D
                What fuse do you put in the new plug ?
                What amp? 13amp, 5amp, 3amp???
                • Fast Alpha
                  • Feb 2013
                  • 245
                  • United Kingdom
                  Re: Bakon BK950D
                  https://www.youtube.com/watch?v=tgwnIA1meCI
                  Some videos say it is faulty!!!
                  • diif
                    • Feb 2014
                    • 6978
                    • England
                    Re: Bakon BK950D
                    There will always be some defects with pretty much every product made.
                    I have a 3A fuse in mine.
                    • Fast Alpha
                      • Feb 2013
                      • 245
                      • United Kingdom
                      Re: Bakon BK950D
                      I got a euro to UK plug adapter, it came with the item.
                      It states on it that it should be grounded, but the device only has two plug connectors. The uk plug adapter has three.
                      So how do I make sure the soldering station is pluged in correctly?
                      WITH IT BEING GROUNDED.
                      • diif
                        • Feb 2014
                        • 6978
                        • England
                        Re: Bakon BK950D
                        Why not just cut the plug off and attach a UK one ?
                        • Fast Alpha
                          • Feb 2013
                          • 245
                          • United Kingdom
                          Re: Bakon BK950D
                          Post a photo of your plug and equipment.
                          To show me what you did inside the plug so I can copy, thank you.
                          • diif
                            • Feb 2014
                            • 6978
                            • England
                            Re: Bakon BK950D
                            You don't know how to wire up a UK plug without a photo ?
                            Or are you saying the mains wire on your 950D had only two wires and no earth ?
                            • Fast Alpha
                              • Feb 2013
                              • 245
                              • United Kingdom
                              Re: Bakon BK950D
                              http://www.maplin.co.uk/p/schuko-to-...pter-13a-tz55k
                              That is the adapter needed. I want to see how you did it pal.
                              I got to make sure I do it properly, your mobile phone has a camera on it.
                              Also what braid and solder do you use for your work.
                              • diif
                                • Feb 2014
                                • 6978
                                • England
                                Re: Bakon BK950D
                                No adapter. As i said, cut off the non UK plug and stick a UK one on. It's three core that comes out of the Bakon.
                                Solder from RS, Chemtronics braid for BGA, Gootwick for smaller, Amtech 559 flux for important jobs, cheap Kingbo in a syringe for eveything else.
                                Photo of some of my bits including how to wire up a UK plug.
                                • Fast Alpha
                                  • Feb 2013
                                  • 245
                                  • United Kingdom
                                  Re: Bakon BK950D
                                  How do you get rid of the flux on your items, how do you remove the flux off the motherboard.
                                  • diif
                                    • Feb 2014
                                    • 6978
                                    • England
                                    Re: Bakon BK950D
                                    IPA and a brush followed by a wipe with a clean room wipe.
                                    • jazzie366
                                      • May 2016
                                      • 304
                                      Re: Bakon BK950D
                                      Originally posted by stj
                                      just got one.
                                      quality feels good.
                                      nice design
                                      the caplist!
                                      primary smoothing,
                                      secondary's
                                      and
                                      Chong: Shit, get rid of it. ChongX is better, Chong is fake, ratings usually aren't true.
                                      JWCo: Largest capacitor manufacturer in the world, 1 billion caps per month produced. I have one in a fish tank that I have, 5 years old and still going, I don't think JWCo is that bad, they're definitely not that great though.
                                      Can't find anything of AE, probably some random generic.
                                      Popcorn.
                                      • miksi
                                        • Apr 2016
                                        • 11
                                        Re: Bakon BK950D
                                        Hello, I also got a Bakon 950D, 75W soldering station. Did you guys check with a power meter? My unit uses much less power than claimed. A T12 tip is about 8 Ohm, the station outputs ~19V, which gives only 45W.
                                        Google this: UnionTest UW501
                                        That is a (russian) station that looks pretty identical to the 950D, but it truthfully claims only 45W. I have the suspicion that many 950D units which are advertized as 75W are in fact only 45W. So, 40% less powerful. I feel a little bit cheated. Did I miss something? What do you think?
