Best soldering station UNDER $50?
  • kaboom
    "Oh, Grouchy!"
    • Jan 2011
    • 2507
    Re: Best soldering station UNDER $50?
    Originally posted by stj
    magnastat - eww nasty!
    Still better than those setscrew monstronsities!!!
    How about something with a thermistor in the heater, and full PID thyristor control? With the caveat that "dave" didn't "endorse" it.
    "pokemon go... to hell!"
    EOL it...
    All style and no substance.
    guilty,guilty,guilty,guilty!
    guilty of being cheap-made!
      • 31197
      i'm not a Davy-Jones fanboy
      some of his vids are a joke if you pay attention.
      i really like the one for the Rigol psu.
      he bitches about the rubber corner bits on the front calling them "stupid wanky bits" without realising it's to stop people putting stuff onto it and damaging the lcd.
      then he complains about the "stupid dial controls" only to use them without even thinking about it 10 seconds later!
      his multimeter rants are the best, cussing UNI-T for not putting mov's or spark-gaps in the meter.
      let's be blunt, if you put the probes on a supply line higher than 1KV the meter is the least of your problems - the probes are going first!
      likewise, if you set it to volts and plug the probes into the current-socket - the rating of the fuse really isnt the problem, it's the user that has issues!
      (and again - your probes are gonna vaporise!)
      • kaboom
        "Oh, Grouchy!"
        • Jan 2011
        • 2507
        Wanna bet his "antics" and bullshitting over non-issues are deliberate, to mislead those truly "green?" Make everyone confused about meter "classes" about something that'll never be "stressed" beyond an arduio-weeno's +5V supply?
        "B-bb-but dave said so- it must be true!" With rare exception, so much $hit on youtube is deliberate and misleading, as you well know. As in the almighty like, su'scribe, comment. Ba$tardize electronics, or any legitimate field, and throw it under the bus? No problem- it's all views (clickbait) after all...
        Rule #2: Another day, another scam.
        EOL it...
        • juliadream
          Otaku Mode
          • Dec 2015
          • 44
          Originally posted by kaboom
          Exactly.
          Remember those awful "shipped with kit" soldering irons? With terrible tip-to-heater contact (setscrew, loose tolerances) and overpowered heater, that tip got blazing hot! And lost its temperature the moment you held it to a joint. If you did manage to "solder" with one of these, the joints were bad from overheating/oxidation. You'd actually see the tip oxidize away if you left it on for half an hour. Waaay too hot, which still didn't "make up" for the lousy thermal interface, not in the least.
          Should've been called "rip the traces off" irons...
          TG, scrounge a used Weller TCP from ebay. Proven design and tips a'plenty.
          yowzers.. those things were an improvement we all bought after a few weeks .. at my first electronics employment they had wooden handle blocks of copper which went in a gas flame burner like a little furnace type thing... and you waited til the flames went a pretty green colour.. but it was mostly tube tv's with wired chassis rather than pcb's we handled.. the boss didn't like paying for electricity and I think he stole the gas.....
          as for cheapest going stations?.. well theres always yihua (wun hung lo) brand.. for as little as AU$16 .. and they actually don't work too bad.. you have to crank them up a bit because they don't have the thermal mass of a Hakko... but buy a set of better tips and they are perfectly usable for hobby use.. I have something similar.. a Sunkko clone from years back.. and for crumping big stuff.. a hardware store 50 watt monster... with the set screws and the copper tip that needs filing every week or so.. yup.. cheapskate.
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Complete bullshit.
            A properly designed meter will not blow up in your hand if you feed it 1KV in ohm's mode and it's CAT-IV rated.
            See for example this video around 6min into it.
            https://www.youtube.com/watch?v=OEoazQ1zuUM
              • 31197
              a meter is as good as it's probes - and most probes arent great.
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                #27
                A probe rated for CAT-IV must just like the meter be able to withstand that testing otherwise it wont be certified as such.
                Had you watched the video you would have seen though that the Harbor Freight meters original probes where not used for the test.
                Because the person performing the test said they had problems with them vaporizing during the test.
                Or just plainly being open thus not working at all.
                Indeed I can vouch for that: the probes I got for my UNI-T meter where intermittent!
                That Harbor Freight meter btw is according to it's faceplate rated for CAT-II 750VAC & 1000VDC, obviously complete bullshit as you could see in the previous video.
                • Agent24
                  I see dead caps
                  • Oct 2007
                  • 5037
                  • New Zealand
                  #28
                  For the original topic - I'd get a 936 clone, in fact it's what I still have Some copies are better than others though.
                  They're not the best, but it's not too bad either.
                  Don't even bother paying extra for digital control and temperature readouts, it's all a joke. Plus more parts to break. A full analogue-control one is best.
                  -David VanHorn
                  • juliadream
                    Otaku Mode
                    • Dec 2015
                    • 44
                    I'm in full agreement.. What I like about those cheap clones is the price of extra irons. I like having a few with different tips so I can just swap the whole thing rather than faffing about changing hot tips.. I've become a bit averse to burning myself as I have got older..
                      • 31197
                      i wouldnt buy a 900M clone,
                      too many sellers are selling steel tips instead of plated copper - they are complete shit.
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        <- got a steel tipped clone :-(
                        Good: it will last a long time
                        Bad: poor conduction = bad regulation.
                        Then again, is it really all steel tip or is it ironclad? I was testing with a neodymium magnet, and it did not stick to the tip like it does with a screwdriver, perhaps it is ironclad?
                        • juliadream
                          Otaku Mode
                          • Dec 2015
                          • 44
                          Oddly the copper tips are steel plated.. About the only difference is the thermal mass.. I doubt many people would actually notice unless they solder 8 hours a day every day..
                          I think the real nasty cheap ones these 2 quid irons come with use some sort of monkey metal almost stainless steel (but who knows?.. it's from China.. spose we should consider ourselves lucky they are actually metal and not some kind of painted asbestos plastic !!!).. I just put good tips on the cheap irons.. that works for me.
                          After using a cheap temp controlled station for over 10 years now (Sunkko wasn't exactly cheap back then.. pretty much where Aoyue are now.. between Wun Hung Lo and Hakko) having to use a thermally balanced 20W Antex yesterday was.. frankly.. horrid.. thing had no grunt at all.. How I ever used one of those things for 20 years daily I don't know... When I got home I did a leaky P3 motherboard just to cleanse my soul
                            • 31197
                            lol i started with an Antex CS model
                            • eccerr0r
                              Solder Sloth
                              • Nov 2012
                              • 8701
                              Another thing about the steel tips (ironclad or 100%) is that they don't tin very well...
                              => time for more cursing
                              I have another Ungar temperature controlled rework station that they used some other alloy to coat their tips for longevity. Not sure what it is... Alas it sticks to a magnet, so probably chrome plated steel? :\
                                • 31197
                                Ungar = Weller.
                                i think they used to plate stuff with Ni.
                                • Fast Alpha
                                  • Feb 2013
                                  • 245
                                  • United Kingdom
                                  #36
                                  Originally posted by comptek
                                  i have one of these heats up really quick been good so far
                                  http://www.ebay.co.uk/itm/SMD-Rework...0AAMXQlgtRoyOj
                                  Did you buy it from china, how do you know it is a safe genuine product.
                                  http://www.hse.gov.uk/pubns/indg305.pdf
                                  • Agent24
                                    I see dead caps
                                    • Oct 2007
                                    • 5037
                                    • New Zealand
                                    #37
                                    Of course it's not safe, or genuine
                                    But if you check the wiring and fix anything stupid before plugging it in, then you're away laughing!
                                    -David VanHorn
                                    • rievax_60
                                      • May 2012
                                      • 897
                                      • australia
                                      #38
                                      When 936 clones are mentioned, a distinction needs to be made between the types that use the high power Japan made heater and the types have a lower powered China made heater. It is usually mentioned in the eBay listing description. The type that have the Japan heater usually have 936A in the model. Another clue is that the Japan heater type clones are more expensive.
                                      I have been using an Aoyue 936A for years.
                                      • Fast Alpha
                                        • Feb 2013
                                        • 245
                                        • United Kingdom
                                        #39
                                        Why don't some one buy it and check it out for me?
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • chth96
                                          What soldering station should I purchase for 900M-TJ-I tip?
                                          by chth96
                                          hello.
                                          A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
                                          https://ko.aliexpress.com/item/4001275635593.html
                                          Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
                                          Any reply would be appreciated.
                                          11-24-2023, 05:08 PM
                                        • caprider
                                          Recommendations of quality soldering station and (separate) hot air station
                                          by caprider
                                          Hey,
                                          I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
                                          I now have a TS100 and some soldering irons and looking for some better tools.
                                          1. Soldering station, budget around 200-240€
                                          JBC BT-2BWA seems to be a good product in the budget.
                                          2. Hot air station, budget around 200€
                                          Up to now I've found ATTEN ST-862D to be a good option....
                                          01-15-2022, 02:05 AM
                                        • mkbehbeh
                                          KSGER C245 Soldering station PSU 220V only?
                                          by mkbehbeh
                                          I purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
                                          I am...
                                          04-17-2023, 03:11 PM
                                        • Peter_1402
                                          Yihua 992DA+ Hot air gun and soldering rework station, burnt mark
                                          by Peter_1402
                                          Hi Everyone,
                                          I bought a Yihua 992DA+ hot air gun and soldering iron unit from a used market.
                                          1. Soldering iron works great
                                          2. There is a burnt mark on the hot air gun handle.
                                          I am a bit concern by the look of the melted plastic. I opened the hot air gun handle and took some readings with a multimeter.
                                          Heating element ~ 75ohm. (Similar reading taken from a spare heating element that came with the unit.)
                                          Thermocouple ~ 1.5ohm. (Similar reading from the spare heating element.)
                                          Reed switch tested ok with a magnet.
                                          From the above test, I can conclude...
                                          07-12-2025, 11:50 AM
