Best soldering station UNDER $50?
Re: Best soldering station UNDER $50?
i'm not a Davy-Jones fanboy
some of his vids are a joke if you pay attention.
i really like the one for the Rigol psu.
he bitches about the rubber corner bits on the front calling them "stupid wanky bits" without realising it's to stop people putting stuff onto it and damaging the lcd.
then he complains about the "stupid dial controls" only to use them without even thinking about it 10 seconds later!
his multimeter rants are the best, cussing UNI-T for not putting mov's or spark-gaps in the meter.
let's be blunt, if you put the probes on a supply line higher than 1KV the meter is the least of your problems - the probes are going first!
likewise, if you set it to volts and plug the probes into the current-socket - the rating of the fuse really isnt the problem, it's the user that has issues!
(and again - your probes are gonna vaporise!)Last edited by stj; 05-02-2016, 06:58 PM.Comment
Wanna bet his "antics" and bullshitting over non-issues are deliberate, to mislead those truly "green?" Make everyone confused about meter "classes" about something that'll never be "stressed" beyond an arduio-weeno's +5V supply?
"B-bb-but dave said so- it must be true!" With rare exception, so much $hit on youtube is deliberate and misleading, as you well know. As in the almighty like, su'scribe, comment. Ba$tardize electronics, or any legitimate field, and throw it under the bus? No problem- it's all views (clickbait) after all...
Rule #2: Another day, another scam.
EOL it...
Originally posted by shango066All style and no substance.Originally posted by smashstuff30guilty,guilty,guilty,guilty!
guilty of being cheap-made!Comment
Exactly.
Remember those awful "shipped with kit" soldering irons? With terrible tip-to-heater contact (setscrew, loose tolerances) and overpowered heater, that tip got blazing hot! And lost its temperature the moment you held it to a joint. If you did manage to "solder" with one of these, the joints were bad from overheating/oxidation. You'd actually see the tip oxidize away if you left it on for half an hour. Waaay too hot, which still didn't "make up" for the lousy thermal interface, not in the least.
Should've been called "rip the traces off" irons...
TG, scrounge a used Weller TCP from ebay. Proven design and tips a'plenty.
as for cheapest going stations?.. well theres always yihua (wun hung lo) brand.. for as little as AU$16 .. and they actually don't work too bad.. you have to crank them up a bit because they don't have the thermal mass of a Hakko... but buy a set of better tips and they are perfectly usable for hobby use.. I have something similar.. a Sunkko clone from years back.. and for crumping big stuff.. a hardware store 50 watt monster... with the set screws and the copper tip that needs filing every week or so.. yup.. cheapskate.Comment
A properly designed meter will not blow up in your hand if you feed it 1KV in ohm's mode and it's CAT-IV rated.
See for example this video around 6min into it.
https://www.youtube.com/watch?v=OEoazQ1zuUM"The one who says it cannot be done should never interrupt the one who is doing it."Comment
A probe rated for CAT-IV must just like the meter be able to withstand that testing otherwise it wont be certified as such.
Had you watched the video you would have seen though that the Harbor Freight meters original probes where not used for the test.
Because the person performing the test said they had problems with them vaporizing during the test.
Or just plainly being open thus not working at all.
Indeed I can vouch for that: the probes I got for my UNI-T meter where intermittent!
That Harbor Freight meter btw is according to it's faceplate rated for CAT-II 750VAC & 1000VDC, obviously complete bullshit as you could see in the previous video."The one who says it cannot be done should never interrupt the one who is doing it."Comment
For the original topic - I'd get a 936 clone, in fact it's what I still haveSome copies are better than others though.
They're not the best, but it's not too bad either.
Don't even bother paying extra for digital control and temperature readouts, it's all a joke. Plus more parts to break. A full analogue-control one is best."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHornComment
Don't even bother paying extra for digital control and temperature readouts, it's all a joke. Plus more parts to break. A full analogue-control one is best.Comment
<- got a steel tipped clone :-(
Good: it will last a long time
Bad: poor conduction = bad regulation.
Then again, is it really all steel tip or is it ironclad? I was testing with a neodymium magnet, and it did not stick to the tip like it does with a screwdriver, perhaps it is ironclad?Comment
Oddly the copper tips are steel plated.. About the only difference is the thermal mass.. I doubt many people would actually notice unless they solder 8 hours a day every day..
I think the real nasty cheap ones these 2 quid irons come with use some sort of monkey metal almost stainless steel (but who knows?.. it's from China.. spose we should consider ourselves lucky they are actually metal and not some kind of painted asbestos plastic !!!).. I just put good tips on the cheap irons.. that works for me.
After using a cheap temp controlled station for over 10 years now (Sunkko wasn't exactly cheap back then.. pretty much where Aoyue are now.. between Wun Hung Lo and Hakko) having to use a thermally balanced 20W Antex yesterday was.. frankly.. horrid.. thing had no grunt at all.. How I ever used one of those things for 20 years daily I don't know... When I got home I did a leaky P3 motherboard just to cleanse my soulComment
Another thing about the steel tips (ironclad or 100%) is that they don't tin very well...
=> time for more cursing
I have another Ungar temperature controlled rework station that they used some other alloy to coat their tips for longevity. Not sure what it is... Alas it sticks to a magnet, so probably chrome plated steel? :\Last edited by eccerr0r; 06-15-2016, 04:19 PM.Comment
i have one of these heats up really quick been good so far
http://www.ebay.co.uk/itm/SMD-Rework...0AAMXQlgtRoyOjComment
When 936 clones are mentioned, a distinction needs to be made between the types that use the high power Japan made heater and the types have a lower powered China made heater. It is usually mentioned in the eBay listing description. The type that have the Japan heater usually have 936A in the model. Another clue is that the Japan heater type clones are more expensive.
I have been using an Aoyue 936A for years.Last edited by rievax_60; 08-10-2016, 07:49 PM.Comment
by sam_sam_samI have been working on this concept for quite some time now with limited success but recently I found a switching power supply that is setup for the voltage that this soldering station needs to operate at however it also needs part of the secondary circuit from the original switching power because you need several voltage rails
I once tried to get a ZD-915 desoldering station to work on a 18 volt battery power supply but unfortunately things did not go well but I did find a work around but I might try this idea again but going at a little differently more about this another time... -
by chth96hello.
A few months ago,I have purchased 0.1mm Soldering Iron Tip of below aliexpress link,But I noticed that It is totally impossible to use this 0.1mm iron tip in the T12 soldering station
https://ko.aliexpress.com/item/4001275635593.html
Is there any good soldering station which is possible to use 900M-TJ-I tip and have inexpensive or reasonable price in aliexpress?
Any reply would be appreciated. -
by capriderHey,
I'm looking for some recommendations of a decent quality soldering station and a separate hot air station. I'm just a hobbyist, so even if (ultra)premium tools are not required, I still want some good tools. They should be available in Europe.
I now have a TS100 and some soldering irons and looking for some better tools.
1. Soldering station, budget around 200-240€
JBC BT-2BWA seems to be a good product in the budget.
2. Hot air station, budget around 200€
Up to now I've found ATTEN ST-862D to be a good option.... -
by mkbehbehI purchased this soldering station when it was on sale at amazon. It had a slew of one star reviews, but the price was low enough that even if the controller and PSU were toast, the handle tips and stand were worth more than the price. All of the reviews mentioned that the unit was either DOA, or died on the first use. I looked on Aliexpress and the first clue was that KSGER still sold the 220V version of this station, but all of the 110V versions had been discontinued. I figured That there was a problem with the 110V on the power suppply and the controller would be fine.
I am... -
by deep000Hi,
I'm looking to get on Aliexpress a hot air soldering station for hobby use, nothing too fancy, just something "reliable" and budget-friendly.
Any recommendations for a "good" cheap one that gets the job done?
Thanks in advance - Loading...
