ESR meter upgrades
This is a sticky topic.
    • 31298
    Re: ESR meter upgrades
    more improvements
    details here:
    https://github.com/svn2github/transi...commits/master
      • 31298
      get ready for - optocoupler testing!
      soon.
        • 31298
        now tests optocouplers.
        • xelectech
          retired tech
          • Nov 2014
          • 238
          Dam, that's impressive! Have you thought any about selling one of those with the software loaded? How much would you want/have to get for one?
            • 31298
            not worth it, if you take the china price and add European postage to forward it, you damn well ad 50% to the price before you even add the programming header & rotary encoder & crystal.
            you would be doubling the original price by the time your done!
            • xelectech
              retired tech
              • Nov 2014
              • 238
              I understand - still, sounds like a totally excellent piece of test equipment!
                • 31298
                maybe the chinese should include the header and faster crystal - then sell a bundle with the programmer.
                • xelectech
                  retired tech
                  • Nov 2014
                  • 238
                  That would be cool - the prices they pay for this kind of stuff must be mind boggling...
                  • roko
                    • Feb 2016
                    • Barcelona
                    #89
                    hi.
                    When upgrade to 16 mhz crystal , need to change fuses values?
                      • 31298
                      no, but if you didnt flash before then the chip will be erased to clear the locks.
                      fuse values are in the avrdude text file.
                        • 31298
                        here is a new build.
                        same code as before, but an extra version with no serial but nice fonts restored.
                          • 31298
                          i have an important question to anybody using or planning to use these testers.
                          what frequency's do you use or need from the frequency generator?
                          because i'm making large changes to it to save space.
                          i have a private test version that just generates 50Hz, 60Hz, 100Hz, 120Hz.
                          these frequency's are mains derivatives that can be used when testing things that time themselves from the mains like clocks.
                          (or comodore 64's!)
                          so lets hear it - what do you need?
                            • 31298
                            bugfixes & worthy stuff.
                            16MHz build has the big fonts and serial port back now.
                            • Per Hansson
                              • Jul 2005
                              • 5895
                              • Sweden
                              #94
                              Would it be possible to get it to 32Mhz or is that beyond the abilities of the controller?
                                • 31298
                                the atmel is rated at 20MHz, i know they have been o.c.'d to 40MHz+ but the problem is the slowest part - the ADC is the bit we need to work right!
                                in theory it could be clocked at 20MHz but the timings in the code are only for 1, 8 & 16MHz right now.
                                dont ask me why it's got timings for 1MHz.
                                *maybe it could be o.c.'d to 24MHz wihout problems - that's a nice number (8x3) so probably not to hard to work out the values needed.
                                  • 31298
                                  i emailed the master about the 24MHz idea - we shall see what he says.
                                    • 31298
                                    version 661
                                    some bug fixes, + i added the instrument tuning frequency 432Hz to the generator.
                                    • Per Hansson
                                      • Jul 2005
                                      • 5895
                                      • Sweden
                                      #98
                                      Ok cool, would be really useful with a tester for 32Mhz crystals since they are so common on mainboards.
                                      See here for an example
                                      https://www.badcaps.net/forum/showth...415#post539415
                                        • 31298
                                        for that, use a uni-t ut61E or one of these.
                                        http://www.ebay.co.uk/itm/181573121672
                                        even if you overclock the atmel on the component tester to 24MHz and it works, you wont read crystals higher than about 22MHz
                                        • xelectech
                                          retired tech
                                          • Nov 2014
                                          • 238
                                          Could someone tell me if the following item could be used to program one of the atmega168
                                          or atmega328 chips?
                                          http://www.ebay.com/itm/Basic-Starte...-/331675682733
                                          TIA
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
