ESR meter upgrades
This is a sticky topic.
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    #721
    Re: ESR meter upgrades
    Do you mean the issues posted by madires here?
    http://www.eevblog.com/forum/testgea...-project/2900/
    Because I do have a 20Mhz crystal too, didn't make that clear I see now
      • 31303
      no, the firmware i posted is not from madires - it's from karl heinze.
      completely different code.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        #723
        Ok, I thought you had compiled madires firmware too, guess my memory played me a trick
        Gives me a good excuse to try it myself, might wait for the next release though as he mentioned a few caveats in the current build with the 20Mhz option...
          • 31303
          *if* you do that, put the crystal in a socket - or you will be stuck with madires firmware.
          • socketa
            Asbelowsoabove
            • Jun 2014
            • 663
            • samsara
            #725
            GM328x ESR tester (SVN684) - small fonts.zip
            Is there an easy way to change the operation of the rotary encoder, so that downwards movement through the menu corresponds with clockwise rotation? (rather than anti-clockwise)
              • 31303
              set a flag in the makefile and rebuild the source.
              # the option CHANGE_ROTARY_DIRECTION changes the rotary direction by swap of switches
              CFLAGS += -DCHANGE_ROTARY_DIRECTION
              • socketa
                Asbelowsoabove
                • Jun 2014
                • 663
                • samsara
                #727
                Ok, i see that that code is already the makefile.
                How does one set this flag in the makefile?
                Do i need to download a compiler?
                Can it be done with windows XP and Codeblocks?
                  • 31303
                  edit the makefile with any text editor, then compile it.
                  does codeblocks build AVR ?
                  • socketa
                    Asbelowsoabove
                    • Jun 2014
                    • 663
                    • samsara
                    #729
                    What exactly needs to be added/changed in the makefile?
                    i really have no programming compiling skills except extremely basic stuff, that i've mostly forgotten.
                    Definitely don't know what a flag is.
                    Will AVRdude rebuild the source, and which one is the source file? Is it transistortester.h ?
                      • 31303
                      updates - inc one for socketa
                      • socketa
                        Asbelowsoabove
                        • Jun 2014
                        • 663
                        • samsara
                        #731
                        Thankyou very much
                        Works nicely (did you just comment out the flag?)
                        Noticed that ESR was not right after 1st calibration - but it came good after the 2nd calibration.
                          • 31303
                          you put a hash in front of the line you want to disable.
                          • jondoe
                            • Nov 2016
                            • 547
                            Please find attached the most recent compiled version of the mega328_st7565_kit - Standard 8Mhz, English, v1.12k rev 700
                            I've had some fun this week learning how to use an Arduino to flash some blank chips, patience and more coffee got me there in the end I've tested various components, all seems fine.
                            • jondoe
                              • Nov 2016
                              • 547
                              mega328_st7565_kit - Standard 8Mhz, English, v1.12k rev 696
                              • socketa
                                Asbelowsoabove
                                • Jun 2014
                                • 663
                                • samsara
                                #735
                                This is better because you can put in whatever frequency you want.
                                But why's the text a mirror image, and also upside-down? (at least on this meter)
                                so i went to https://n2github/transistortester/tr...mega328_st7565 and programmed it with that.
                                Now it's looks good, except that there is only a third of the first character on each line, and it's only upside down and not mirror-imaged
                                • jondoe
                                  • Nov 2016
                                  • 547
                                  You're having some problems? I didn't see anything flipped upside down text on mine, is that somewhere in the menu? I haven't looked at the freq counter on mine. I might potentially need to use a different tool chain as I've seen mentioned that the one shipped with winavr can cause troubles, this might be related!
                                  Ignore the rev 700 i posted, I got the revision number wrong!
                                    • 31303
                                    you have a GM328 not an st7565_kit.
                                    different hardware needs different firmware.
                                    • jondoe
                                      • Nov 2016
                                      • 547
                                      I'll compile one for the GM328 when I get a moment tomorrow
                                      • socketa
                                        Asbelowsoabove
                                        • Jun 2014
                                        • 663
                                        • samsara
                                        #739
                                        Yeah, the penny dropped just dropped a few minutes ago.
                                        The GM328 on that website works good but no rotary encoder/option. And i see that that's what you've enabled - but the frequency option has being restricted.
                                        Is it easy enough to recomple it, so that any frequency can be inputted?
                                          • 31303
                                          the different frequency generator is intentional, the changed code is in my zips.
                                          the frequency code that you can allegedly input any frequency is very difficult to use.
                                          @jondoe - use the makefiles from my zip - the regular one is pretty wrong.
                                          infact most of the makefiles on the SVN are only just working and need to be finetuned.
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
