ESR meter upgrades
This is a sticky topic.
    • 31300
    Re: ESR meter upgrades
    the test routines have been changed a few times over the past year.
    and no, it cant test complex analog parts like regulators.
    • linker3000
      • Sep 2007
      • 24
      so your original firmware tests them all ok and give the proper tests results?
      Yes.
      • socketa
        Asbelowsoabove
        • Jun 2014
        • 663
        • samsara
        #683
        i got an EZM one of these, same as in post #446.
        And it was working fine.
        But i thought that it tested voltages; so bricked the chip.
        So got another chip and used a batch file to program it with "GM328x ESR tester (SVN684) - v2.zip"
        It now appears to operate well, except for one thing: after going through the calibration process, and the test finishes, it says that it is not calibrated.
        Any idea why it's not calibrating?
        • flywheelz
          • Aug 2016
          • usa
          #684
          Have you tried to run Selftest from menu?
          • socketa
            Asbelowsoabove
            • Jun 2014
            • 663
            • samsara
            #685
            Yeah,
            Strapped terminals 1, 2, and 3, and removed them when said to isolate.
            Then it asks for a cap greater than 100nf between 1 and 3, so i give it 25uf.
            It then visually flashes the capacitance measurement on the LCD for two or three minutes.
            Then it asks for 10-30nf, so i give it 12nf
            It then displays the capacitance briefly.
            And then it displays "Test end"
            And then returns to the menu.
            Then i test a few caps and it gives good readings.
            Then i select "turn off"
            With no components inserted, i turn it back on
            It tests the battery correctly
            Then displays :"no unknown or damaged part?"
            Then "Not calibrated!"
            And then automatically powers off.
            If i insert a capacitor, and push the button before it displays the "not calibrated!" message, it tests the capacitor.
            So, is this calibrated, or not?
              • 31300
              instead of 25uf, use something like 220nf - atleast not more than 1uf.
              it should not flash for a few minuits - that tells me it's not happy.
              • socketa
                Asbelowsoabove
                • Jun 2014
                • 663
                • samsara
                #687
                Thanks bud
                That fixed it.
                Nice one
                • TheOnlyDocc
                  • Sep 2016
                  • 8
                  Originally posted by stj
                  no, it's a kit from ebay with a red pcb.
                  i dont recommend it - it's slow to update the screen, and i cant free enough memory to enable crystal testing!
                  Which one would you recommend? Or is changing the crystall a solution?
                    • 31300
                    i recommend this at the moment.
                    http://www.ebay.de/itm/182221397168
                    and a case!
                    http://www.ebay.de/itm/112108340467
                    • TheOnlyDocc
                      • Sep 2016
                      • 8
                      Dam the ebay seller is not shipping to Germany. This should be the same if i am right.
                      http://www.ebay.de/itm/GM328-Transis...cAAOSw0fhXki5S
                      And because RS is really pricy in Germany (more than 8€ for shipping) i want to ask if i can use this crystall. It is not a 10ppm.
                      http://www.ebay.de/itm/272367597610
                      And because i can not find my old programmer (i used it to programm Atiny 13A chips for my flashlights).
                      http://www.ebay.de/itm/172229590674
                      Now i only need a cheap source for the voltage regulator. If i did not miss anything.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        • uk
                        #691
                        all those links look fine to me just be aware that stuff from china is taking ages to arrive lately due too some shipping company issues
                          • 31300
                          use this programmer link
                          http://www.ebay.de/itm/172266343471
                          • TheOnlyDocc
                            • Sep 2016
                            • 8
                            The Programmer has arrived. Now i am waiting for the Kit to arrive.
                            One question. Can someone check if i have found the right PMIC (https://www.conrad.de/de/pmic-spannu...html?insert=62).
                            A friend works nearbuy this shop and can get it for me. So i do not have to pay for shipping.
                            There was a second chip to increase the battery runtime but i can not find it in this shop. And i do not have the knowledge to check for a chip with similar characteristics.
                            Maybe someone here can take a look.
                              • 31300
                              that's the part,
                              i'll take a foto later of how to fit it - because it's not the same as the lm431 it replaces.
                              • TheOnlyDocc
                                • Sep 2016
                                • 8
                                Thanks that would be nice!
                                And can you also help with the other chip. I think it was a 5V low dropout voltage regulator. But i can not find the chip at Conrad Elektronics. But maybe they have something similar that i can use.
                                  • 31300
                                  which kit are you waiting for?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    • uk
                                    #697
                                    in post 690 he links this one
                                    • TheOnlyDocc
                                      • Sep 2016
                                      • 8
                                      Yes it is this one http://www.ebay.de/itm/GM328-Transis...cAAOSw0fhXki5S
                                        • 31300
                                        the AY-AT kit uses a 7550A regulator - it may be decent.
                                        i'll have to find the datasheet
                                          • 31300
                                          the 7550 actuually looks pretty impressive!
                                          so no need to change it.
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • Ryan Wurtz
                                            Lenovo Yoga C740-15IML 5V on usb meter.
                                            by Ryan Wurtz
                                            Hello. So I searched and didn't find any posts on this specific problem.
                                            When plugged in USB power meter reads 5v
                                            Doesn't charge battery. I can charge the battery with power supply. So it seems the battery works fine. Laptop started but didn't post on battery.
                                            Original mobo had a shorted cpu it seems.
                                            So I decided I need a new motherboard.
                                            Put the new one in the computer. Connect the battery, I think it starts, don't quite remember, but when I plug the adapter/charger.
                                            5v on the meter. Still won't charge. Can still charge the battery...
                                            11-24-2025, 01:08 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
