ESR meter upgrades
This is a sticky topic.
+ More Options
Posts
  • linker3000
    • Sep 2007
    • 24
    Re: ESR meter upgrades
    is this the one
    http://www.ebay.co.uk/itm/GM328-Tran...1%26rkt%3D1%26
    which firmware version have you found that works? did you re calibrate the tester after installing the firmware?
    I tried calibrating both of these with the results as listed:
    GM328_EZM_v1.12k_r541: Board is hard to turn on. Seems to perform most tests OK but often incorrectly identifies small signal transistors as JFETs
    mega328_GM328 from current trunk at the same repo: Board turns on, but ditto with the small signal transistors.
    • linker3000
      • Sep 2007
      • 24
      Originally posted by stj
      can you copy & paste the screen output when you ran avrdude.
      the pot is surplus btw, it's just rfom when they sold the lower pcb with a character display.
      it's the manual contrast setting.
      So good I did it twice:
      Code:
      C:\temp\mk328>avrdude -c USBasp -p m328p -U flash:w:TransistorTester.hex \-U eeprom:w:TransistorTester.eep \-U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
      avrdude: AVR device initialized and ready to accept instructions
      Reading | ################################################## | 100% 0.04s
      avrdude: Device signature = 0x1e950f (probably m328p)
      avrdude: NOTE: "flash" memory has been specified, an erase cycle will be performed
           To disable this feature, specify the -D option.
      avrdude: erasing chip
      avrdude: reading input file "TransistorTester.hex"
      avrdude: input file TransistorTester.hex auto detected as Intel Hex
      avrdude: writing flash (30056 bytes):
      Writing | ################################################## | 100% 15.75s
      avrdude: 30056 bytes of flash written
      avrdude: verifying flash memory against TransistorTester.hex:
      avrdude: load data flash data from input file TransistorTester.hex:
      avrdude: input file TransistorTester.hex contains 30056 bytes
      avrdude: reading on-chip flash data:
      Reading | ################################################## | 100% 10.46s
      avrdude: verifying ...
      avrdude: 30056 bytes of flash verified
      avrdude: safemode: Fuses OK (E:FD, H:DE, L:FF)
      avrdude done. Thank you.
      Reading | ################################################## | 100% 0.05s
      Writing | ################################################## | 100% 15.59s
      Reading | ################################################## | 100% 10.63s
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #663
        are the fuse settings rite?
          Great Sage é½Šå¤©å¤§č–
          • 31054
          did you actually read all that?
          it's not writing the eeprom or fuses.
          copy & past in 3 seperate operations.
          avrdude -c USBasp -p m328p --U eeprom:w:TransistorTester.eep
          avrdude -c USBasp -p m328p -U lfuse:w:0xf7:m \-U hfuse:w:0xd9:m \-U efuse:w:0xfc:m
            • 31054
            btw, this looks like another windows10 fuckup.
            piece of shit cant even handle long commandline strings!!!
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #666
              I tried yesterday on windows 10 and mine failed, when you posted the three seperate commands on a windows 7 laptop the firmware load worked fine.
                • 31054
                maybe i should make a batch-file
                • vinceroger69
                  • Mar 2012
                  • 6714
                  • uk
                  #668
                  batch-file? im still learning programming so is this just another method of loading the firmware?
                    • 31054
                    batch-file
                    you create a text file, and put command strings in it.
                    then name it xxxx.bat
                    you run it like a command and windows does whatever is in it - like a macro
                    i'll give you an example.
                    create a text file called "program.bat"
                    then copy & paste this into it:
                    avrdude -c USBasp -p m328p -U eeprom:w:TransistorTester.eep
                    avrdude -c USBasp -p m328p -U hfuse:w:0xd9:m
                    avrdude -c USBasp -p m328p -U efuse:w:0xfc:m
                    exit
                    then if you type "program" or "program.bat" it will run all those commands.
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      • uk
                      #670
                      thanks for explaning that its easier when shown commands etc too as examples.
                        • 31054
                        the power of the command-line will never be beaten by a mouse!
                        • linker3000
                          • Sep 2007
                          • 24
                          Duh! Copied the instruction verbatim from the accompanying text file. Will redo in three steps.
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            • uk
                            #673
                            This pdf from the eevblog thread is worth a read
                            • linker3000
                              • Sep 2007
                              • 24
                              Now reflashed and running OK. Calibrated OK, but like the other firmware I tried it has problems with small signal transistors which can either report as JFETs or a pair of diodes. If I revert to the original firmware the transistors check as expected.
                              Happy to check out any suggestions or stick with the original firmware if there's no desire to look into this.
                              Thanks either way.
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                • uk
                                #675
                                can you upload the original firmware file im just wondering if stj can modify it into the new firmware?
                                  • 31054
                                  what part numbers are being miss-read?
                                  • linker3000
                                    • Sep 2007
                                    • 24
                                    Samples from the parts drawer:
                                    Correct
                                    TIP42A
                                    TIP32B
                                    BCY70
                                    2N4036
                                    ZTX651
                                    2N3906
                                    MJ1410
                                    Two diodes
                                    SE9302
                                    BD139
                                    BFY50
                                    BF494
                                    2N3053
                                    N-JFET
                                    BCY65E
                                    BC182L
                                    BC650
                                    2SC546
                                    BC107
                                    ZTX300
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      • uk
                                      #678
                                      stj on the eevblog forum someone has just said
                                      Yes, the tester can't correctly identify integrated circuits, including voltage regulators. This is normal.
                                      so some parts it cant test properly?
                                      • linker3000
                                        • Sep 2007
                                        • 24
                                        Just to clarify, all the parts I listed in my previous post are bipolar transistors. The list shows which ones are detected correctly and which are incorrectly identified as either FETs or diode pairs.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          • uk
                                          #680
                                          so your original firmware tests them all ok and give the proper tests results?
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the ā€œEā€ stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
