ESR meter upgrades
This is a sticky topic.
+ More Options
Posts
    • 31199
    Re: ESR meter upgrades
    no need, the tracks from the part under test are only a couple of cm long.
    on the multi-meter style meters it's going to make more of a difference though.
      • 31199
      update time.
      smaller zips with no pdf until the pdf changes btw.
      the K version fully sorted now for the GM328A
      frequency generator is back to working.
      and - drum-roll.
      the Markus Trendy software.
      this was a bitch to get configured and still is not perfect, but it runs and has some interesting features!
      read the readme!
      again, this is only for the GM328A and you WILL need a rotary encoder.
      • SteveNielsen
        Retired Tech
        • Jun 2012
        • 2327
        Thanks for these things. I am saving them for when I can buy the rotary swx and a programmer.
          • 31199
          dont save them,
          i'll be updating on every major source update.
          • SteveNielsen
            Retired Tech
            • Jun 2012
            • 2327
            I'm a little fuzzy on the rotary vs test switch, how do you activate a test without the test switch?
              • 31199
              then encoder has a switch - press the shaft in.
              • SteveNielsen
                Retired Tech
                • Jun 2012
                • 2327
                I wasn't sure about that. Thank you.
                  • 31199
                  fresh updates.
                  • SteveNielsen
                    Retired Tech
                    • Jun 2012
                    • 2327
                    I just got my rotary control in the mail today. Programmer should be here soon too.
                    What did you use to make the 10-6 pin adapter?
                    I'm gonna mount the 6-pin header on the top of the board beneath the display instead of the back. I checked clearance with a connector and it will fit fine. That way I don't have to cut a hole in the back of my box or port it out.
                      • 31199
                      i used some old cables from a pc.
                      i think the 6pin was a 5x2 internal usb connector for a pc frontpanel that i cut-down.
                      the 10pin was an idc connector from a 9way serial port from an old AT standard motherboard
                        • 31199
                        if you do that, remember the 6way pinout will be mirrored and dont try to use your adapter on anything else!!
                        • SteveNielsen
                          Retired Tech
                          • Jun 2012
                          • 2327
                          But the 10 pin needs to be male, I've only seen female idc. Got a pic of your adapter?
                          Edit: nevermind, I looked one up. I honestly have never seen one before.
                          Yes indeed. I figured that was obvious but that might not be to someone else reading, so thanks.
                            • 31199
                            10pin conector must be female, the programmer has PINS on it
                            you could also use a pair of those usb headers if you had them
                            • SteveNielsen
                              Retired Tech
                              • Jun 2012
                              • 2327
                              Jeez, I was thinking about the cable included, not the programmer board connector! My mind slips gears sometimes. Thanks for filling in a blank for me.
                              I'm pretty well set then, I've got a 10-pin ribbon cable with female ends here I can modify. It's 21" long, I could cut it in half and make two adapter cables if I wanted to. I've got other connectors I can use for the 6-pin end.
                                • 31199
                                you want the cable 15cm / 6" long at most.
                                it programs real fast and you dont want data errors
                                  • 31199
                                  i have another update soon as attachements are active.
                                  • SteveNielsen
                                    Retired Tech
                                    • Jun 2012
                                    • 2327
                                    Coolness. Look forward to it. The included cable is 8" long BTW.
                                    I'd like to add a helpful tip for adding the rotary control, tin the cut/bent center pin and where you scratch off the lacquer from ground-plane on the board that it will connect to before soldering the control on instead of struggling to solder within that narrow space between the control and the zif socket after the control is mounted.
                                      • 31199
                                      update here.
                                      • SteveNielsen
                                        Retired Tech
                                        • Jun 2012
                                        • 2327
                                        I just flashed mine and it appears to work ok however during the flash I got this error at the end. I repeated the flash and the error repeated...
                                        avrdude: 1 bytes of efuse written
                                        avrdude: verifying efuse memory against 0xfc:
                                        avrdude: load data efuse data from input file 0xfc:
                                        avrdude: input file 0xfc contains 1 bytes
                                        avrdude: reading on-chip efuse data:
                                        Reading | ################################################## | 100% 0.00s
                                        avrdude: verifying ...
                                        avrdude: verification error, first mismatch at byte 0x0000
                                        0x04 != 0xfc
                                        avrdude: verification error; content mismatch
                                        avrdude: safemode: efuse changed! Was fc, and is now 4
                                        Would you like this fuse to be changed back? [y/n] n
                                        avrdude: safemode: Fuses OK (H:FC, E9, L:F7)
                                        avrdude done. Thank you.
                                          • 31199
                                          that's fine, some chips do that.
                                          • chth96
                                            by chth96
                                            03-09-2024, 10:03 PM
                                            12-31-2023, 06:04 AM
                                          • jorpec
                                            by jorpec
                                            Hi
                                            Thnaks
                                            01-23-2023, 10:37 AM
                                            Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                            12-14-2023, 07:45 PM
                                          • irepair559
                                            ps4 1215 model Changed port and encoder still no video?
                                            by irepair559
                                            hi guys so i have this ps4 fat 1215 i believe ( the one with the ps4 pro/slim newer encoder ic ) so i replaced hdmi and 2 blown filters and still no pic so i replaced encoder and still no pic. i made sure port is solid even checked with a breakout hdmi and tested ground and data lines.. Filters are all good , though 2 of the newer ones are larger then the original ones i dont know if that matters ?
                                            Made sure under the scope encoder pins all look solid went over with fine tip and solder again. Idk but this thing is stressing me out..
                                            ps4 seems to boot fine blue light then solid...
                                            01-01-2023, 12:41 AM
