Re: Help needed getting an ESR meter...
Seller's 4th pic shows a three headed test probe noted as Not Included
Do you know if that's a standard item ?
And if so, where to get it / what to search for ?
you could still get caught.I purchased the Bob Parker 'BLUE ESR Meter' from Alltronics LLC/Ana Tek Instruments earlier this year. I am very happy with its performance and accuracy. Yes, you can test caps in-circuit, though I prefer to test out-circuit, with accurate results. One of the best pieces of test equipment I own now. My repair success rate has increased since caps that would give good uF test readings CAN give bad ESR readings, causing circuit malfunction.
my new tester gives me capacitance, ESR, and Vloss (leakage)
i'v found a number of used caps in my stash with good capacitance and ESR, but high Vloss.Leave a comment:
anybody buying a "bare pcb" tester, make a base for it.
if you touch the resistors or atmel while it's running, you will mess up the readings.
so a nice insulating layer is good protection and prevents damage while your not using it.
just do what i did and slice up the defuser layer from a busted lcd panel.
I purchased the Bob Parker 'BLUE ESR Meter' from Alltronics LLC/Ana Tek Instruments earlier this year. I am very happy with its performance and accuracy. Yes, you can test caps in-circuit, though I prefer to test out-circuit, with accurate results. One of the best pieces of test equipment I own now. My repair success rate has increased since caps that would give good uF test readings CAN give bad ESR readings, causing circuit malfunction.Leave a comment:
Yes there quite good meters for the price i have one myself (earlier version) the one stj has got maybe my next purchase too.Leave a comment:
OK, deffo getting some el-cheapo from Ebay.
If it's good for stj and csh (*waves to neighbour
*) it's more than good for me.
that's not the real version number, because the release is 1.12 and the beta is around 1.18Leave a comment:
Only contrast setting in the menu. If held longer, device shuts off.
Software version is 2.07.Leave a comment:
for calibration, link all 3 connections together and press the button.
have an acurate 100n cap ready - it will ask for it.
for a menu, hold the button down.
i dont know if that model has it - nothing stopping you upgrading the software though.
here is some info:Attached FilesLeave a comment:
Nice.i am using this.
http://www.ebay.co.uk/itm/181861030068
I got this one a couple of days ago:
www.ebay.com/itm/251563800953
For me as an amateur and hobbyist it will do.
Seems to be working, i tested a couple of known good/bad caps and the results are ok. Even found some caps to be bad that i was not planning to replace
Is any calibration on this things needed?
How do you get this menu for special functions like frequency generator?
Nice job with the acrylic shield btw
well there are already schematics, the problem is safety for the noob putting his finger in the wrong place, and isolating the supply from the microcontroller.
i built my own zener tester and it can go upto about 200v!Leave a comment:
That's very cool and would seem to be a handy feature for any tech, not just beginners.Leave a comment:
the next generation AVR based units will have a high voltage generator on it and test zener diodes - that will be a big leap for beginners.Leave a comment:
For someone beginning in electronics an AVR micro-controller tester is a good choice. I can't see spending a lot of money on a dedicated ESR tester when one of them will do a decent job measuring ESR and a lot more. I've used one for testing solid state devices and precision resistors just as much as for testing caps.Leave a comment:
yes, why not satisfied?
my only problems wih it:
1 - no case - fixed that.
2 - no clips on the cables.
i have put over 1000 used caps in mine so far - very reliable.
just dont put a supercap / double-insulated cap in it - it will ask for calibrationLeave a comment:
i agree with you , Stj, i recently bought one, the same thing but not satisfied.Leave a comment:
btw, none of them are reliable "in-circuit", if they say they are then they are lying.
they will be effected by other components.Leave a comment:
i am using this.
see here:
https://www.badcaps.net/forum/showpo...6&postcount=50Leave a comment:
			by chth96I read EBOOK of Testing Electronic Component and found that
"In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
Is it really possible to test small ceramic disc capacitor with analogue...-
							Channel: General Capacitor Questions & Issues
			by jorpecHi
I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
I wonder how i can accomplish this so the meter would be precise at any temperature ?
Thnaks -
			by sam_sam_samAbout a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the āEā stops and one switching power (24 volt) supply and a transformer... -
			Greetings, new guy here but always interested in the crazy universe of modding
We just finished construction of around 25 vacation houses, all inside the same private area.
Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...05-20-2025, 09:09 AM -
			by sam_sam_samI have had this in my wish list for quite a while now and I might need to test BMS protection board with this device because of the limitations of the battery testing machine that I have been using
https://www.aliexpress.us/item/32568...yAdapt=glo2usa
What this will allow me to do is use my load testing machine that is having issues with the voltage cutoff set/ current meter monitoring system and I decided not to try to replace it or repair it I just going to use a very primitive load testing... - Loading...
