What equipment??
  • newtothis
    • Mar 2013
    • 1556
    • england
    What equipment??
    Ok it is getting very tiring pulling tonnes of SMD components from boards in an attempt to find a short on the board... So..
    What is the best method of finding shorts?
    What equipment is needed?
    Suggestions of best make/models of equipment?
    Cheers guys
    • 31013
    Re: What equipment??
    a low ohms meter.
    you may get away with using an esr meter.
    • newtothis
      • Mar 2013
      • 1556
      • england
      How do you find a short with an ESR meter?
      This card I have had in today has a short somewhere down one of the 12v rails.... Of course on my meter it is showing 0 ohms across the pads of many components... Would this not also be the case with an ESR?
      I have read up about people using variable PSU's and pushing a small current through the circuit then using a sensitive meter to track the path of the current.
      Basically I am looking for the quickest way of finding them
        • 31013
        esr meters can often show resistance with a higher resolution.
        my meter for example can show xx.x ohms
        an esr meter can show xx.xx
        10 times more detail.
        the resistance of the solder and copper tracks is very small, but it's still there, so with a good enough meter the short will show a lower resistance as you get closer to it.
        there used to be circuits for this using a speaker that generated a tone that rose in pitch as you got close.
        maybe you can find one.
        • newtothis
          • Mar 2013
          • 1556
          • england
          Can you recommend a decent ESR meter for the job then? I only have this crappy homebuilt thing which is useless TBH
          Are the Atlas readers any good?
            • 31013
            atlas are very overpriced.
            either get a cheap ebay job like this:
            http://www.ebay.co.uk/itm/181573126240
            or talk to Behemot about the quality Russian one he sells.
            as for finding shorts though, go look on schematics sites for a low-ohms tracer.
            • newtothis
              • Mar 2013
              • 1556
              • england
              LOL I am crap at reading diagrams nevermind building a circuit! Remember my name stj! lol
              • SteveNielsen
                Retired Tech
                • 2327
                Even a cheap Chinese knock-off of the Kubbeler AVR tester can measure resistance down to hundredths of ohms. Those can be had for around $25.
                • newtothis
                  • Mar 2013
                  • 1556
                  • england
                  Takes too long to get things in from abroad. Also i had a cheap ass thing from HK before and it died within a week.
                  Price isn't an issue to me
                    • 31013
                    found this - it looks simple.
                    • newtothis
                      • Mar 2013
                      • 1556
                      • england
                      Simple as it may be I can't build circuits so I will need to buy one
                      • SteveNielsen
                        Retired Tech
                        • 2327
                        I don't think you should limit yourself like that, you CAN build circuits if you just start doing it and you've got to start somewhere.
                        • newtothis
                          • Mar 2013
                          • 1556
                          • england
                          It is not something i intend on getting into so no point. On average I spend 30 minutes per repair on Video Cards, I make an average of around £100 profit per card, I get through around 10 reballs per week so make around £900 after expenses. I started seeing a higher amount of cards with dead shorts lately which is something I need to be able to address properly rather than pulling LOTS of smd components to find them. Taking the time to learn how to build circuits + buying in the stuff needed just isn't worth my time.
                            • 31013
                            i pm'd someone - wait for Behemot.
                            • Behemot
                              • 4845
                              • CZ
                              Oh yeah here I come I can supply the newest ESR Micro v4.0si, or if you don't need the relay protection (for charged capacitors) also the older v4.0s for cheaper. As my stock is sodl out and Mikhail is on vacation now, it does not matter which you choose, I'll need to order all of them
                              It can measure 0.01-200 ohm and capacitance 0.01-65535 uF.
                              • mmartell
                                • Oct 2013
                                • 3189
                                Is the idea here is to test across components or pick a ground location and move the other probe around ?
                                • rievax_60
                                  • May 2012
                                  • 897
                                  • australia
                                  I have been having good success at finding shorted Multi-layered Chip Capacitors using about 0.5A of bias current and using a multi-meter with at least 10uV resolution by measuring the voltage drop on the ground plane. The readings increase as I get closer to the shorted MLCC.
                                  Some example photos on this page,
                                  https://www.badcaps.net/forum/showth...164#post423164
                                  • Behemot
                                    • 4845
                                    • CZ
                                    How exactly does it work? And 10 uV is really too low…
                                      • 31013
                                      he is tracking the volt-drop.
                                      • SteveNielsen
                                        Retired Tech
                                        • 2327
                                        The meter is set to 10uV resolution to measure small changes in voltage, that's not the voltage he's applying to the ckt.
                                        • chth96
                                          Is it possible to test small ceramic disc capacitor with analogue meter?
                                          by chth96
                                          I read EBOOK of Testing Electronic Component and found that
                                          "In order to test the small blue resin coated ceramic disk capacitor which has 104 50v specification,it is possible to test this small ceramic capacitor by making use of analogue meter.
                                          Set to times 10Kohm that has 12v output from the probe to check disorder of ceramic capacitor.
                                          It is not uncommon that testing result of digital capacitance meter is okay,But It show shorted reading when you check it with analogue meter."
                                          Is it really possible to test small ceramic disc capacitor with analogue...
                                          03-09-2024, 10:03 PM
                                          Modification of a Fluke multi meter that uses three AA batteries to use a 14500 lithium ion battery
                                          by sam_sam_sam
                                          I have had with regular AA batteries that leak this meter is expensive new I already replaced the battery battery clips once and the same thing happened again and I am tried of so it is getting modified to accommodate lithium ion batteries that are the same size excluding the positive terminal and removing the battery clips I will have enough room for the BMS protection board
                                          I going to put 3 lithium ion battery in parallel with the BMS protection board and a way to charge the battery externally and heat shrink the battery pack and use a JST connector so I easily remove the battery...
                                          12-31-2023, 06:04 AM
                                        • jorpec
                                          Changing the scale of an analog meter
                                          by jorpec
                                          Hi
                                          I want to change the scale of an analog meter, to monitor the charge of an li-ion single cell, so the needle at the end would point 4.2 volts and the 0 on the meter would point 2.5 volts or so, i tried to add diodes or a zener in series with the meter but the changes of the ambient temperature also changes the voltage value on the meter
                                          I wonder how i can accomplish this so the meter would be precise at any temperature ?
                                          Thnaks
                                          01-23-2023, 10:37 AM
                                          How an incandescent light and a ESR meter ** friend**have a machine blowing fuses
                                          by sam_sam_sam
                                          About a month ago we had a transformer jumper wire that burned in two different places between two transformers caused over $200 thousand dollars worth of damage to VFD drives at least 10 of them and a memory card and quite a few power supply as well
                                          Now we have most of the equipment that got damaged back up and running except a feeder that has issues and we are waiting for some parts for
                                          Now we also have another piece of equipment that was blowing fuses on the 110 volt controller switch circuit with the “E” stops and one switching power (24 volt) supply and a transformer...
                                          12-14-2023, 07:45 PM
                                        • Stephan Mathers
                                          EDMI ATLAS MK10 Electronic Meter Discussion
                                          by Stephan Mathers
                                          Greetings, new guy here but always interested in the crazy universe of modding
                                          We just finished construction of around 25 vacation houses, all inside the same private area.
                                          Each house has 3phase power , and we bought an atlas MK10 meter for each house (25 meters total ! )
                                          The metering on a per-house basis is done privately. Its not done by a utility company. The utility company will only charge us for the total consumption of all 25 houses together.
                                          Id like to do a small modification on the firmware of our MK10 to make it easier identify each house's...
                                          05-20-2025, 09:09 AM
