Ever used the hFE tester on your multimeter?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    I found it really irritating and uncomforting to use the hFE checker on my multimeters that have it, so I usually just do diode checks.
    Curiosity is, have you used the hFE checker on your multimeter?
    20
    Yes, frequently
    0%
    1
    Once or twice
    0%
    6
    Never
    0%
    6
    Don't have one on my multimeter
    0%
    4
    WTF is this hFE?
    0%
    3
    The poll is expired.
  • lti
    • May 2011
    • 2548
    Re: Ever used the hFE tester on your multimeter?
    I tried it on a cheap meter from Harbor Freight, and it was unusable. A transistor that has been removed from a board won't have long enough leads to make contact in the transistor socket on that particular meter. I can measure hFE of a new transistor, but that isn't very useful for me.
    • modemhead
      Lurking
      • 52
      Never. For me, diode-test function suffices for general-purpose transistor checking.
      The sockets are unreliable on every meter I've ever touched with this "feature". They all tend to flash a lot of non-sense numbers while you're wiggling it around. I have no patience for that.
      If I am really interested in the beta, I'd use a transistor tester where the collector current is known and preferrably can be varied to match the type of transistor.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        I've used it a few times when I was building a mini amplifier from discrete parts. Other than that, I don't use much.
        Yes, those cheap HF meters have completely useless hFE sockets, even if you do take a brand new transistor with long leads and try to stick it in there. The socket is so unreliable and flimsy, that I probably would have better luck measuring the transisotr's hFE with my ass. Seriously!
        Perhaps I should mention that I use the hFE tester only on my Radio Shack meter, which is not exactly a cheapy. Has a very nice socket that is not round.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          I'm shocked the HF meters even have hFE at all. I would imagine the typical HF user would not even know what it is...
          I also have a Tenma meter with hFE check. This one has a linear arrangement but still suffers from the "lead too short" syndrome trying to test used transistors. Of course when comparing the HF and the Tenma units, the numbers are way off, but at least they're linear to each other (transistors with low hFE will be low hFE on both meters).
          I found the round sockets helpful for TO18 and TO5 transistors (and staggered TO92) at least...
          • cheapie
            null
            • Jul 2010
            • 849
            My meter doesn't have that function (and I don't know what it does anyway).
              • 31024
              i dont think it's much use unless your doing amplifiers and trying to get a "matching npn/pnp pair"
              even then, i suspect parts these days have a far tighter spec than they used to back when people matched transistors or valves for audio.
              • diif
                • Feb 2014
                • 6978
                • England
                So that's what it's supposed to be used for, i wondered when i got my meter.
                I have a Peak DCA55 because i'm lazy and i like toys.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Used it a few times, and i can recall one time when it really did help. I was still a novice back then, but it came in real handy in finding a bad transistor in an audio amplifier. It showed a hFE of 1, without being shorted or open.
                  However, most of the times when i DO need to use it, i find it needs the leads of the transistor to be very long to actually touch the contacts inside (in addition to obviously needing to remove the transistor from the board), so i just give up and test it on the diode scale.
                  A working TV? How boring!
                  • SteveNielsen
                    Retired Tech
                    • 2327
                    I only used it once to see if it worked.
                    • redwire
                      • 3910
                      The only time I measure beta is when building audio power amps that need matched-pair transistors, like the Leach Low-TIM amp using a test jig with 30VDC and a couple milliammeters and a resistor. Then you have to sort and bin the transistors.
                      Next, I tried my cheap-o $10 multimeter hFE and it's pretty close but only about 5V across the tranny and the reading drifts as the battery sags. Meh.
                      • nebundemult
                        • Jun 2010
                        I use this option to distinguish more collector emitter when I doubt about some transistors.
                        • CapLeaker
                          Leaking Member
                          • 8158
                          I use it rarely... only to match audio or rf amplifiers.
                          • Jidis
                            • Nov 2013
                            • 57
                            I found that same thing after reading people's comments about using it. I couldn't figure out how they got it to work, as I returned my first one thinking it was broken and had the same results on the replacement. Not having a meter with HFE, I wanted to see it work, so I ordered a machined pin socket where the contact holes sit flush with the surface, but I had to extend all eight legs to get it tall enough.
                            Long story short, I tried a few things on-hand and it surprisingly gave readings almost dead center of the range listed in the corresponding datasheets. I think I also compared against some manual calculations I found using Ohm's law. Not sure how useful it will be, but there was a slight feeling of accomplishment in forcing the feature to work.
                            Take Care
                              master hoarder
                              • May 2008
                              • 12175
                              • Bulgaria
                              Nice work!
                              That is actually a great idea there . I do have some SIP machined sockets left over from an electronics class. I'm thinking I could cut a slot on the side of the meter and attach the socket there. It wouldn't look as neat as yours, but it should still work.
                              Not that I use the hFE feature much, but like you, I would feel a sense of accomplishment if I got it working right.
                              • Jidis
                                • Nov 2013
                                • 57
                                If you see a machined pin socket that's tall like the original, I'd be interested, though I'm not sure it's worth modding a second one. The only tall ones I saw look like the stock one, but I couldn't tell if they're any more reliable.
                                I see some non-DT830's with dual row rectangular sockets. I think that or the single like you're doing is what they probably should have used.
                                George
                                • Jidis
                                  • Nov 2013
                                  • 57
                                  If anybody ever wonders what they're up against with those god forsaken blue sockets, I just realized the old one was sitting in front of me.
                                  rough checks with a caliper:
                                  The blue body is about 10mm deep (diameter is roughly 9), and the pins stick out from the bottom by about 3mm (they're around 6.5 total length). The pins are also pretty "flat". They look to be about 0.3mm thick. So you've got to go about 6+ mm down into the socket before you have any chance of touching that fork thing, and then your leads will need to be thick enough to make contact.
                                  George
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    • Bulgaria
                                    ^ Good info, thanks.
                                    This gave me a new idea - what if you cut the top part of the socket all the way up to where the pins begin to protrude? I think that might be another way to mod these without buying anything. But how well it would work... I don't know. Might try this instead of my previous idea, though.
                                    • redwire
                                      • 3910
                                      Keystone makes transistor sockets.
                                      I bought a tiny breadboard on eBay $2-$4 and use that as a socket for testing large batches.
                                      • Jidis
                                        • Nov 2013
                                        • 57
                                        Yeah, I actually considered that too, but you'd still be dropping the socket way down below the face of the meter. Seems like it would still work, just wouldn't look that good. I was actually thinking of burning that blue one down to size with a belt sander without even removing it. Just make sure you vacuum the holes out or something afterward. I don't think those fork/contact things need any extra help making a flaky connection.
                                        Redwire's link looks like the one I installed. Mine appears to have been this thing by "Mill-Max". Still sits way too low though without extensions.
                                        Take Care
                                        • dj8452000
                                          How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                          by dj8452000
                                          I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                          02-18-2025, 08:28 AM
                                        • Lifeisfun
                                          Trying to troubleshoot DDR4 SODIMM slot with slot tester
                                          by Lifeisfun
                                          Hi folks!
                                          I have some kind of memory problem on Lenovo laptop. I was initially able to install windows after several tries since the laptop did freeze in middle of those attempts.
                                          Eventually I discovered that it was related to moving the laptop.
                                          Later on it even stopped booting unless I pressed around the memory slot. (no keyboard LEDs only power button responds)
                                          If I remove the RAM I get the beeps that RAM is missing. Inserting the RAM there is silence and it will not boot most of the time. No picture.
                                          I removed the board got one of those memory slot testers...
                                          06-04-2025, 02:26 PM
                                          FNIRSI HRM-10 Internal Resistance Detector AC Lead Acid Lithium Battery Tester Review on some testing of device
                                          by sam_sam_sam
                                          https://www.ebay.com/itm/405035016711
                                          I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
                                          I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it...
                                          04-13-2025, 08:17 PM
                                        • trex66
                                          Craftsman 82345 Multimeter broke!
                                          by trex66
                                          My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                                          03-04-2025, 04:26 PM
                                        • Sofian75
                                          Things not to do with a multimeter?
                                          by Sofian75
                                          I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
                                          I fixed some of them and some I ve made things worse by blowing components.
                                          Every time while taking measurements with my multimeter.
                                          Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
                                          So my question is are there things I should not do with my multimeter?
                                          Or measurements I should do only with the charger and battery unplugged?...
                                          06-27-2024, 05:13 AM
