recommend good solder wick on aliexpress
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3599
    • slovakia
    I get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress
  • diif
    • Feb 2014
    • 6978
    • England
    I use Chemtronics wick. I didn't buy mine from Ali but a search has it showing up.
    https://www.aliexpress.com/item/1005005011742579.html
    • прямо
      • Sep 2022
      • 261
      • Indonesia
      The Mechanic brand is good.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3599
        • slovakia
        thank guys i will try both
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3599
          • slovakia
          Mechanics work for me like other cheap chinese crap, but Chemkomex is ON ANOTHER LEVEL. i buy one and whe i work with it i imediatelly buys 20 pieces. I never work with better wick
          • redbaron1007
            • Jun 2021
            • 107
            You can buy it on there, but just like buying amtech flux on aliexpress it'll be counterfeit stuff of varying quality. The legit chemtronics stuff is made in the USA. My source for that is the last spool I bought from digikey a couple months ago for work had the COO on the invoice as United States. Curious though now how the aliexpress stuff compares to the stuff I got from digikey.
            • clearchris
              • Dec 2013
              • 687
              I'll be the first to admit that I never really used solder wick unless I had to. Some years ago, I bought a desolder station (almost 300usd), and it has been great.
              Lately, there are some very cheap soldering iron/desolder pump combos that seem to work ok. They had something similar to this at my former work and they seemed to like it.
              https://www.aliexpress.us/item/3256804929123151.html
              • CapLeaker
                Leaking Member
                • 8188
                MG Chemicals solder wick for me. Just not from Ali.
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                  Multifix 425-01 and 450-01 Rework Flux Datasheet
                  REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                  - No Clean Formulations
                  - Low residue
                  - Range of activity to deal with different component solderability
                  - Halide free
                  - Suitable for dispensing
                  - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                  Both products are supplied in syringes or cartridges for application by dispensing....
                  10-07-2024, 06:02 AM
                • spleenharvester
                  Good power bank shells for 18650 cells?
                  by spleenharvester
                  I did a cell salvage run on some Dyson batteries to build out a new fleet of Milwaukee batteries and the yield was a lot higher than expected, so I now have a lot of extra Sony VTC4s that are in reasonably good health. I'd like to build them into power banks, there's a glut of shells for 18650s on AliExpress but I don't know which are any good (read: won't explode). Can anyone recommend some (especially the ones that just fit a single cell)? Weld or weldless are fine, I have a spot welder
                  I suppose USB-PD and/or quick charge would be desirable too
                  Cheers
                  05-11-2025, 01:47 PM
                • Glaval
                  Sony OLED XBR-65A8G 4 flashes
                  by Glaval
                  Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with...
                  01-23-2025, 04:04 PM
                • irepair559
                  Ps4 1215a hdmi diode readings good everything good but no pic??
                  by irepair559
                  PS4 1215A HDMI DIODE READINGS GOOD EVERYTHING GOOD BUT NO PIC? everything is good! what else can it be? if hdmi diode values are good that means encoder and filters are good right? idk what else it can be guys...
                  01-05-2023, 12:32 AM
