Sony OLED XBR-65A8G 4 flashes
  • Glaval
    • Jan 2025
    • 6
    • US
    Hello, my Aunt recently gave me her broken Sony XBR-65A8G OLED after getting a replacement. It had a 4x led flash error, a replacement T-con didn't fix the error but with helpful info from this forum I found one of the smd ceramic caps on the panel pcb (C575/C378) on a 24v line was shorted to ground. I removed that cap and the tv turned on without error. It still had a black screen with the original t-con back in it, once I put the replacement t-con in it finally had a picture. After doing a panel refresh it had a very good picture but with a few vertical lines for some scenes. For owners with this error, if shorted cap removal fixes the error for you I'd recommend you leave it be and don't try to re-solder in a cap unless you're good at micro soldering.
    I was about to put the back cover on but I decided to solder in a cap of similar size off the bad t-con, big mistake as I accidentally messed up four of the surrounding caps unfortunately. Now with those caps missing the TV gives a 4 flash error again. I've double checked there are no short circuits or bridged power connections and there are none. With error sos bypassed on the mainboard, the tv relay clicks on but there's no picture, as the t-con is not supplying voltage to the EVSS lines except for a few seconds when factory reset with power + volume down. Testing with only the right side t-con to panel flex cable connected and sos bypassed there is no error, but with only the left side t-con to panel flex cable, which is the side with the missing caps, there's a 5x blink error, which could be panel id err or t-con internal err.
    I've since gotten better soldering equipment and watched several videos on smd soldering. One question I have is could having a few pads bridged on the ground side cause a problem, I understand it would for the positive side but none are bridged there. I've experimented with a few caps I've harvested from the old t-con but it's made no difference so far. Three of smallest capacitors missing are 2 in parallel from a 1.8v line and one missing on a .104v line with one in parallel still intact. A slightly larger one running on a 8v line did not make a difference when I soldered a 5-10uf cap in. If anyone has any advice I'd really appreciate it, thank you.
  • EazyBone
    • Jun 2023
    • 1405
    • United states
    • Anything I can do with my hands
    That is a hell of a hack job. No flux ? To remove a cap I always just cut it off as it's much easier.
    • nomoresonys
      • 12370
      • U.S.
      Guess you need to clean it up and see if you can find some the same physical size to put in there, it's true you can probably get along fine without one but you have 4 or 5 gone, check out some more youtube videos and see how the pros do it, practice on a scrap board, once you get those replaced you should be ok.
      • lotas
        • Jan 2016
        • 5205
        • Russia
        Yes.. what have you done here (you need to practice soldering on donors...) remove the last capacitor, it is already destroyed, drop a little flux and remove the remaining solder with a braid for removing solder, clean this place with isopropyl alcohol...
        • Glaval
          • Jan 2025
          • 6
          • US
          Removing it was no problem, soldering the flea sized thing was a different story unfortunately. I did pick up some flux and been using it since and wiping the board with isopropyl afterwards. I will remove that final cap, it has been giving different capacitance readings compared to it's mirrored cap on the other side panel pcb. I will practice on the bad t-con, then try to get them back on, thanks!
          • nomoresonys
            • 12370
            • U.S.
            Some basics there: https://www.youtube.com/watch?v=eheEHv4Nzzg
            • thstuff
              Sony OLED XR-77A80J - Initially dead, now 4 Flashes
              by thstuff
              A) TV initially dead
              B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
              C) Was able to perform a Reset from Settings menu and completed out of box configuration.
              D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
              E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
              12-26-2024, 09:10 PM
            • Daren87
              Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
              by Daren87
              I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
              08-13-2023, 03:25 PM
            • iglitare
              Sony KD-75XF9005 grey Picture but Sound. TCON or panel?
              by iglitare
              i want to repair a Sony KD-75XF9005 TV that initially only showed a grey picture.
              Backlight seems to work, Sound (Setup menu after reset) works.
              If i dissconnect the left FFC cable from TCON to panel i have half a screen on the right. If left cable is connected always only the grey screen.
              Interchanged the cables, its always only the right side that is working. Always grey if left side is connected.
              With my small knowledge i would think at least the cables are good.
              Can this happen because of a bad tcon board?
              Or is it always a bad/shorted...
              09-04-2025, 07:13 AM
            • kca
              by kca
              Hello all ~
              08-31-2025, 06:38 AM
            • rimwall
              Sony KD-65x7500D - double image - Tcon or Panel?
              by rimwall
              This TV was showing a fine image and pulsing with a partial double image (offset vertically) every few seconds. I taped 8 clock pins on one ribbon cable from the Tcon to the panel. It stopped the double image, but some pulsing in intensity was still visible. I then taped another 8 clock pins on the same ribbon cable and the image is now ‘fixed’. Although I understand this results in some loss of resolution, presumably because the clock signal degrades as it passes horizontally across the screen.
              I am wondering - do these symptoms and ‘fix’ mean that it’s a Tcon fault or...
              11-18-2025, 02:09 AM
