recommend good solder wick on aliexpress
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3719
    • slovakia
    • hard-enduro
    I get som bad cheap wick that im furious with so i need to order wick that suck solder like it should. best on aliexpress
  • diif
    • Feb 2014
    • 6978
    • England
    I use Chemtronics wick. I didn't buy mine from Ali but a search has it showing up.
    https://www.aliexpress.com/item/1005005011742579.html
    • прямо
      • Sep 2022
      • 261
      • Indonesia
      The Mechanic brand is good.
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3719
        • slovakia
        • hard-enduro
        thank guys i will try both
        • ktmmotocross
          Boardkiller
          • Feb 2014
          • 3719
          • slovakia
          • hard-enduro
          Mechanics work for me like other cheap chinese crap, but Chemkomex is ON ANOTHER LEVEL. i buy one and whe i work with it i imediatelly buys 20 pieces. I never work with better wick
          • redbaron1007
            • Jun 2021
            • 125
            You can buy it on there, but just like buying amtech flux on aliexpress it'll be counterfeit stuff of varying quality. The legit chemtronics stuff is made in the USA. My source for that is the last spool I bought from digikey a couple months ago for work had the COO on the invoice as United States. Curious though now how the aliexpress stuff compares to the stuff I got from digikey.
            • clearchris
              • Dec 2013
              • 687
              I'll be the first to admit that I never really used solder wick unless I had to. Some years ago, I bought a desolder station (almost 300usd), and it has been great.
              Lately, there are some very cheap soldering iron/desolder pump combos that seem to work ok. They had something similar to this at my former work and they seemed to like it.
              https://www.aliexpress.us/item/3256804929123151.html
              • CapLeaker
                Leaking Member
                • Dec 2014
                • 8724
                MG Chemicals solder wick for me. Just not from Ali.
                • acedogblast
                  by acedogblast
                  11-02-2024, 05:13 PM
                • Apoco_ lips
                  gigabyte x870i aorus pro ice stuck on dram light, ddr5 power good voltage 0 when ram stick installed
                  by Apoco_ lips
                  I have a gigabyte x870i board I am attempting to repair. I have a working board as well to reference. The board is stuck on the dram light, wont post and I found the power good pin has 0 volts when powered on with a stick of ram installed. With out the ram it is 3.3v. Another weird issue with the board is when trying to use qflash to update the bios, the qflash light blinks for about 15 seconds then turns off for 30-45 seconds and then turns back on solid for about 3 minutes. My working reference board will flash the qflash led for about 15 seconds, turn off for a few seconds then turn back on...
                  06-30-2026, 04:15 PM
                • Boardview and Schematic Bot
                  Multifix 425-01 and 450-01 Rework Flux Datasheet
                  REWORK FLUXES Multifix 425-01 and 450-01 are tacky fluxes designed for use in a wide range of electronics assembly and rework processes. They represent a range of activities and residue levels to meet different customer requirements.
                  - No Clean Formulations
                  - Low residue
                  - Range of activity to deal with different component solderability
                  - Halide free
                  - Suitable for dispensing
                  - Compatible with solder coatings and/or No Clean flux cored solder wire product range
                  Both products are supplied in syringes or cartridges for application by dispensing....
                  10-07-2024, 06:02 AM
                • spleenharvester
                  Good power bank shells for 18650 cells?
                  by spleenharvester
                  I did a cell salvage run on some Dyson batteries to build out a new fleet of Milwaukee batteries and the yield was a lot higher than expected, so I now have a lot of extra Sony VTC4s that are in reasonably good health. I'd like to build them into power banks, there's a glut of shells for 18650s on AliExpress but I don't know which are any good (read: won't explode). Can anyone recommend some (especially the ones that just fit a single cell)? Weld or weldless are fine, I have a spot welder
                  I suppose USB-PD and/or quick charge would be desirable too
                  Cheers
                  05-11-2025, 01:47 PM
                • Levande99
                  Lenovo ThinkPad X1 Yoga 4th Gen - Dead ThinkEngine (EC Chip)
                  by Levande99
                  Hi guys. I bought this one to see if I can fix it to use.
                  Immediately under the thermal camera I can see the ThinkEngine is glowing red hot - clearly an internal short. Absolutely zero corrosion or water damage anywhere.
                  Two pins shorted have low impedance - PGPIO0 (5 ohms), RD0_ON/5MUBAY (0.7 ohms).
                  It is the BD4179 (the schematic has it labeled as a TC62D518FTG_BD4179MW V-E2_W QFN56_7X7). I can of course solder a replacement IC, but can find no information on whether its self reprogramming. I do not see a seperate ROM chip, I understand these have internal ROM, and on...
                  12-12-2025, 11:47 AM
