Ratdude's first scope
  • ratdude747
    Black Sheep
    • Nov 2008
    • 17136
    I was gifted one of these today:
    It is a 1966 Heathkit 10-12 AC 1 channel scope.
    It used to belong to one of the EET professors at my college... he built it from a kit when he was my age and no longer had a use for it. He thought I might have a use for it and offered it
    He even had the original manual in a large 3 ring binder of manuals... he built a lot of heathkit kits...
    It works:
    (a 12V wall wart without load, synced to line AC frequency)
    Since you can use bannana plugs with it, my PSU tester from another thread pairs well with it:
    I have one question:
    It uses a 2 prong non polarized plug, being from 1966. it also has a metal case. the cord is still good (no cracks, frays, etc). Should I:
    1. keep the power cord that is in it... it is vintage and it isn't worth it to mess that up
    2. swap it for a modern 3 prong grounded cord, with the hot going to the fuse, neutral to the other line connector, and ground being connected tot he case with a ring terminal and rivet
    Otherwise, I am happy with it...
    Any other comments/suggestions?
    sigpic
    (Insert witty quote here)
  • PeteS in CA
    • Aug 2005
    • 3580
    • USA, Unsure of Planet
    Re: Ratdude's first scope
    I probably used one of those in high school. IIRC, a lot of old tube consumer electronics connected AC Neutral to the chassis. So step one, IMO, should be to find out whether one of the AC cord prongs has continuity to the chassis and/or case.
    PeteS in CA
    • KeriJane
      Mac Enthusiast
      • Sep 2008
      • 681
      Ratdude...
      Congratulations!
      That's an ideal first scope. you can learn a great deal with and from it.
      It's all tubes, right? Learn about them. Practically no one else under 30 has and vacuum tubes have some unique characteristics as compared to semiconductors... characteristics that might be extremely useful in a 'scope.
      I wouldn't change the cord just yet if it's functional.
      You might want to look at it to see if it's connected to chassis.
      It might well be pointed out in the manual which is an invaluable study guide.
      Tying the case to ground wasn't necessary in 1966 and could possibly affect operation as it might affect shielding. Of course all of the insulation is pushing 50 so... it's an even better idea to study that manual!
      I prefer "live" scopes like yours over the digital ones... lag drives me nuts.
      Congratulations again
      The More You Learn The Less You Know!
      • Sparkey55
        • Jan 2010
        • 1523
        I have that same Heathkit model. Will eventually get around to a restoration in the future.
        • Agent24
          I see dead caps
          • Oct 2007
          • 4953
          • New Zealand
          Looks nice! Yours actually has division labels on the knobs. Better than mine...
          -David VanHorn
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            the prof also has a vac-tube based volt meter... it has super high impedance... he says he isn't sure if he will keep it or give it away...
            his office has half of his collection in it... the other half is for home use. he has a bunch of devices stacked, all made from kits and most of them quite aged.
            the thing is that heathkit manuals do not exist in a .pdf... the prof says that anybody who posts a pdf gets a cease and desist letter from them (aka lawsuit).
            I doubt the neutral is tied to ground... it doesn't have a polarized plug, which makes finding neutral vs hot ambiguous...
            I will leave the cord anyway... the unit may be worth something as since it is in such good condition and it still has the manual... having 100% stock parts makes it that much better.
            this is not my first time using a scope btw... the labs at my college have both analog and digital scopes... we learned how to work analog scopes at the start of this semester; the first lab was solely on the use of an analog scope.
            sigpic
            • Agent24
              I see dead caps
              • Oct 2007
              • 4953
              • New Zealand
              That's a bit stupid for something that old...
              -David VanHorn
              • Toasty
                • Jul 2007
                • 4171
                Here:
                Houston - We have a problem. Site keeps changing .gifs to .jpg's and shrinking them. STOOOOOOPID.
                Be back shortly with a jpeg that works...
                Okay. Let's try this again:
                veritas odium parit
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  I think there's a mistake on the schematic. On the right, at the HV output after the 1V2 tube, the first cap is labeled as 1000v while the voltage at that point reads 1400v. That cap should be 1600v like the one to its left.
                  A working TV? How boring!
                  • ratdude747
                    Black Sheep
                    • Nov 2008
                    • 17136
                    i know he swapped a 200v cap for a 400v cap as per a penciled in mark in the manual.
                    sigpic
                    • berniedd
                      • Mar 2007
                      • 119
                      Cease and Desist Letter from who? I thought the Heathkit company closed down years ago.
                      • Toasty
                        • Jul 2007
                        • 4171
                        Nope:
                        http://electronicdesign.com/article/...heathkit-20689
                        http://www.heathkit.com/
                        veritas odium parit
                        • PeteS in CA
                          • Aug 2005
                          • 3580
                          I remember Heathkit VTVMs from high school, too. Try talking to a modern young tech or engineer about their voltmeter having to warm up before it can operate ...
                          I work with vacuum tubes pretty much every day ... aka TWTs.
                          PeteS in CA
                          • Toasty
                            • Jul 2007
                            • 4171
                            You work with TWATs? How lucky can you get!
                            veritas odium parit
                            • Jack Crow
                              It's a CLASOB!
                              • May 2008
                              • 823
                              R,
                              Looks like a good start.
                              With a minimum of care it should last another ten years or more.
                              You can do a lot of good stuff with that.
                              I presume you can set it for X/Y display?
                              If so, I will re send a sketch for a cheap semiconductor curve tracer.
                              Made a lot of money with that tool over the years.
                              A simple and cheap gizmo that will let you look at diodes and transistors and see real fast (as in 60 times a second) if the junction is any good.
                              Keep it safe
                              Jack Crow
                              "You are, what you do, when it counts"
                              The Masso
                              "Gravity, the quickest way down"
                              Mayor John Almafi
                              "You ever drop an egg, and on the floor you see it break?
                              You go and get a mop so you can clean up your mistake.
                              But did you ever stop to ponder why we know it's true?
                              If you drop a broken egg you will not get an egg that's new?"
                              MC Hawking
                              • PeteS in CA
                                • Aug 2005
                                • 3580
                                Yep, Toasty. I connect some to 3.8KV and some to 4.2KV ... after warm-up, of course.
                                PeteS in CA
                                • Agent24
                                  I see dead caps
                                  • Oct 2007
                                  • 4953
                                  • New Zealand
                                  That sounds like a useful tool - but I think my scope is too basic for that.
                                  Would a curve tracer by any chance do a similar job to this: http://www.siliconchip.com.au/cms/A_112767/article.html ?
                                  -David VanHorn
                                  • ratdude747
                                    Black Sheep
                                    • Nov 2008
                                    • 17136
                                    R,
                                    Keep it safe
                                    Jack Crow
                                    it has both a horizontal input and a vertical input. is that the same?
                                    sigpic
                                    • Krankshaft
                                      • Jan 2007
                                      • 2328
                                      You usually set the scope to XY mode and use Channel 1 for X and Channel 2 for Y.
                                      • Jack Crow
                                        It's a CLASOB!
                                        • May 2008
                                        • 823
                                        R and K,
                                        The gadget in the article is over complex.
                                        Mine is 'stone ax simple' and works 99% of the time.
                                        http://www.flickr.com/photos/9010884...57626109758650
                                        Been trying to find the 'photos' of it in use, but they are refusing to show up at the moment.
                                        J
                                        The Masso
                                        Mayor John Almafi
                                        MC Hawking
                                        • repair-it
                                          Need advice testing a samsung power supply board with scope
                                          by repair-it
                                          I am attempting to test a samsung power supply board to verify the pfc ic is working. I am powering up the board with my isolation transformer. The board turns on fine but when I attempt to connect the ground for the scope probe, it trips out the isolator. I was taught not to 'float my scope' so I am wondering if I should test without connecting the ground lead or would that be asking for trouble? Not sure how else to test, I don't have a portable scope. I could plug direct to mains power but that would bypass the safety factor.
                                          07-12-2025, 11:00 AM
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • EasyGoing1
                                          Reading input and output of bridge rectifier on the same scope?
                                          by EasyGoing1
                                          I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                                          When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                                          06-26-2022, 12:52 AM
                                          Hantek scope that can hook up to your iPad or computer IDSO1070A feedback wanted about it specifications
                                          I thinking about about buying one later on this year depending on what feedback I get from this forum members that know more than I do about what is importance about what to have in a scope
                                          https://www.aliexpress.us/item/32568...3333736563%21s...
                                          04-12-2025, 10:24 PM
                                        • vestaviascott
                                          Dial Cord Hell! Radio Shack SW-100 (Venturer 2959, Rhapsody RY-610)
                                          by vestaviascott
                                          I'm looking for the dial cord winding settings for this radio!
                                          I spend most of a whole day yesterday trying to figure this out. I just need to know how many turns for the tuning knob stylus to get me started, then how many on the lower and upper bobbins on the first cord pulley (there are two on either side of the tuning band area).
                                          The dial cord system has a central gear where the dial cord spring and stay is, then the tuning knob stylus and two small rollers each with a small and a larger bobbin holder. I finally figured out how to wind the cord on those bobbins...
                                          06-07-2020, 08:36 AM
