Ratdude's first scope
  • KeriJane
    Mac Enthusiast
    • Sep 2008
    • 681
    Re: Ratdude's first scope
    Doesn't XY mode involve using a two-channel scope?
    Didn't RatDude call his scope a one-channel scope?
    Or am I missing something again?
    Not trying to be sarcastic or anything... just wondering.
    The More You Learn The Less You Know!
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      XY mode doesn't involve a 2-channel scope, it only needs 2 inputs. It overrides the X axis which is normally controlled by the timebase. Differential measurements, or measurements of two different signals require a 2-channel scope.
      A working TV? How boring!
      • b700029
        Banned
        • Sep 2010
        • 640
        Based on the schematic this scope has only AC coupling on the inputs?
        • Krankshaft
          • Jan 2007
          • 2328
          I mean't. Most scopes integrate X and Y into the two channel inputs so they don't need to use 2 separate dedicated BNC jacks.
          • ratdude747
            Black Sheep
            • Nov 2008
            • 17136
            correct. it is an AC scope.
            sigpic
            (Insert witty quote here)
            • cadiman
              • Mar 2010
              • 397
              #26
              My first scope was full of tubes and worked great since all I did was audio (1989). I also got an isolation transformer with it.
              Nice find you have there!
              • eryjus
                by eryjus
                05-10-2023, 11:21 AM
              • EasyGoing1
                Reading input and output of bridge rectifier on the same scope?
                by EasyGoing1
                I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                06-26-2022, 12:52 AM
                Hantek scope that can hook up to your iPad or computer IDSO1070A feedback wanted about it specifications
                I thinking about about buying one later on this year depending on what feedback I get from this forum members that know more than I do about what is importance about what to have in a scope
                https://www.aliexpress.us/item/32568...3333736563%21s...
                04-12-2025, 10:24 PM
              • vestaviascott
                Dial Cord Hell! Radio Shack SW-100 (Venturer 2959, Rhapsody RY-610)
                by vestaviascott
                I'm looking for the dial cord winding settings for this radio!
                I spend most of a whole day yesterday trying to figure this out. I just need to know how many turns for the tuning knob stylus to get me started, then how many on the lower and upper bobbins on the first cord pulley (there are two on either side of the tuning band area).
                The dial cord system has a central gear where the dial cord spring and stay is, then the tuning knob stylus and two small rollers each with a small and a larger bobbin holder. I finally figured out how to wind the cord on those bobbins...
                06-07-2020, 08:36 AM
                new (old) scope
                by stj
                Metrix OX-8627
                100Mhz dual-trace digital storage CRT scope.
                all controls are digital and it has full remote via IEE488 bus
                very fucking rare and hard to find any info on
                some pics after a recap using about 90 new caps!!
                06-02-2024, 08:47 AM
