Oscilloscope
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    #61
    Re: Oscilloscope
    A groundloop is when current takes detour through another potential lower resistance ground path other than the designed ground path of a circuit or device.
    For example: AC electricity coming from the hot side passes through a PSU that you are testing, it becomes current or load and is returning to the source via neutral/ground. When you probe the PSU, your scope probe has the potential to ground a component out which might create a electrical short. The current has a potential to shift to the probe due to lower resistances than the designed neutral/ground path and it passes through the scope which electrifies the chassis which kills you or destroys the scope and blows up the PSU.
    That's the reason why you need an isolation transformer, to isolate your test-subject from the structure wiring while providing a permanent power solution. If you don't have one then as Th3_uN1Qu3 said, battery backups or inverters connected to some deep cycle batteries will work just as long as you unplug the charger or battery backup from the structure wiring and have enough run-time to do the tests.
    One thing I don't know for sure is, do you plug the scope into the isolation transformer too or not? I don't have a scope, but this thread has been an interesting read.
    • godin
      • Dec 2011
      • 34
      #62
      Re: Oscilloscope
      http://www.youtube.com/watch?v=11Yve2ijWyk
      It explains it all, I hope correctly as I understand now.
      • Peter9DO
        • Dec 2011
        • 277
        #63
        Re: Oscilloscope
        Now about this isolation transformer that everyone is talking about.... Can someone post an example please (either a model number or a picture)... If you look it up there are all types of styles. Which one would we be using?
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: Oscilloscope
          I think the need for an isolation transformer questionable.
          It's become a 'pat answer' and honestly it's never made sense to me, particularly from a safety standpoint.
          I can't see how floating a ground intentionally makes things safer. - Doesn't make sense.
          We never used them in the Navy - that I can remember anyway.
          Scope probe grounds were ALWAYS connected to chassis-earth ground.
          [Seems strange calling it earth ground when you're floating on water....]
          If we needed to measure a hot to a hot we used two probes and a differential amp in the scope and the grounds on both probes were connected to earth ground.
          Further:
          Tektronix advises against isolation transformers - see page 2.
          If someone has an explanation of why they are needed that doesn't involve an 'I Believe' button then I'm all ears.
          Mann-Made Global Warming.
          - Dr Seuss
          • godin
            • Dec 2011
            • 34
            #65
            Re: Oscilloscope
            For work on laptops isolation still seems to be relevant. The -ve terminal on the power supply has continuity to mains earth in a non double insulated one.
            On the other hand I have a double insulated laptop power supply with a 2 pin mains plug and this has no continuity from -ve to mains earth on its output. In this instance is the power supply acting as an isolation transformer and is it safe to use the scope on a laptop with a double insulated supply?
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Re: Oscilloscope
              Only if you connect the ground lead to a hot.
              The probe's tip has like a 1 MegOhm + input impedance so you won't get significant current through that.
              [With a 1Meg input impedance even if you connect to 500v you'll only get 0.5 mA current. [0.0005 amps]]
              That's why the Navy taught us to always connect the ground lead to ground.
              If you connect probe ground to the PSU's chassis ground you won't cause a short with a scope.
              - Dr Seuss
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Re: Oscilloscope
                Double Insulated doesn't mean what you think it does.
                All Double Insulated means is that no -single- failure can result in dangerous voltage becoming exposed.
                There is a sundry or ways they can achieve that.
                The lack of a ground wire does not mean much electrically [voltage potential wise - in a way that matters to an o'scope] when the neutral in the building's wiring is connected to earth ground in your breaker box anyway.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  Re: Oscilloscope
                  Ground loops CAN cause problems with signal quality in some situations by way of EMI, but that's not a safety issue and it's not going to blow up your scope.
                  - Dr Seuss
                  • godin
                    • Dec 2011
                    • 34
                    #69
                    Re: Oscilloscope
                    I understand what double insulated is, it was just that I had observed that there was no connection to earth of the outputs from it. That is from the output plug to mains earth is open circuit and therefore isolated from it. I thought it might fit the bill not by definition of being double insulated, just that it happened to have this property.
                    • KeriJane
                      Mac Enthusiast
                      • Sep 2008
                      • 681
                      Re: Oscilloscope
                      Further:
                      Thank you for the Tektronix reference.
                      I also learned that probe grounds must always be connected to chassis ground and never, ever to a circuit path. Just use the ADD or differential between channels feature or get a differential probe.
                      Aren't isolation transformers a leftover from the bad old days of hot chassis radios and televisions?
                      For the children around here, yes, they used to build consumer electronics with chassis connected directly to power! They were often wired to the wide, "neutral" blade of the plug but it wasn't always so..... You could get a dangerous or deadly shock from just touching the chassis, if maybe a knob came off and uncle "deadly" Smedly had replaced the cord or plug...
                      When testing such equipment, wouldn't an isolation transformer be a really good idea? How did the techs deal with hot chassis scoping way back then?
                      Could one ground the chassis (and scope) while connected to an isolation transformer?
                      The More You Learn The Less You Know!
                      • godin
                        • Dec 2011
                        • 34
                        #71
                        Re: Oscilloscope
                        I read the Tektronix link this morning and also found it very informative.
                        It does not mention the other option of isolating the equipment being tested from ground. I think this is what people are advocating and not floating the scope but using the isolation transformer on the equipment to be tested. If you only connect the earth clip to earth it would be safe but may affect measurements. This seems to make sense to me as a novice.
                        I am as always willing to be corrected.
                        • cmj21973
                          • 267
                          Re: Oscilloscope
                          Here's a good FAQ's an isolation transformers (Chapter 4 Section 4)
                          http://www.repairfaq.org/REPAIR/F_tshoot.html
                          • Mad_Professor
                            A Mech Warrior
                            • Feb 2011
                            • 1587
                            #73
                            Re: Oscilloscope
                            That was very informative, it doesn't float the ground.
                            • godin
                              • Dec 2011
                              • 34
                              #74
                              Re: Oscilloscope
                              That was the case with the one in the video I posted, but the guy disconnected the earth from the isolated side to make into what he called a technicians isolation transformer as opposed to the domestic one that it was manufactured to be.
                              • PCBONEZ
                                Grumpy Old Fart
                                • Aug 2005
                                • 10661
                                Re: Oscilloscope
                                No but if you use it on a grounded chassis it DOES float the AC Return in the device under test which actually makes using the Iso-Xfmr MORE dangerous than not using one.
                                - Dr Seuss
                                • PCBONEZ
                                  Grumpy Old Fart
                                  • Aug 2005
                                  • 10661
                                  Re: Oscilloscope
                                  Isolation Transformer section in that link:
                                  - If you don't put the proper emphasis on the correct part of the FIRST sentence then that can get you into trouble.
                                  The First sentence with proper emphasis:
                                  >> An isolation transformer is very important for safely when working on live chassis equipment. <<
                                  Live chassis equipment = Hot chassis design = No chassis-to-earth grounding.
                                  [As KeriJane suggested earlier] - It's only for really old designs like old 'Live/Hot chassis' TV sets.
                                  Using an Isolation Transformer on modern grounded chassis equipment will make the work MORE dangerous, not less, by Isolating [Floating] the AC Return above (Earth) Ground Potential.
                                  That basically means you DON'T want to be using an Isolation Transformer for anything to do with a PC.
                                  - Dr Seuss
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    Re: Oscilloscope
                                    I can't tell you without tracing the circuit or seeing the schematic.
                                    I never considered it before and I don't have anything handy to look at.
                                    Measuring the resistance between the Negative DC Output and the AC Return [Neutral] Input will tell you is it's Isolated completely.
                                    I can't see floating the DC ground inside a Laptop as a good idea because they can be connected to external AC powered LPT/Serial/USB devices that do [or might] have the DC Negative at earth ground potential.
                                    - Dr Seuss
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      #78
                                      Re: Oscilloscope
                                      Not any more dangerous than not connected the ground lead to earth, which a lot of people do. The only thing between hot and earth is an Y cap, and that can bite a little, but it is far from dangerous. Without isolation you CANNOT probe in the primary of a SMPS with an earthed chassis scope - only with one powered by batteries and without a metallic frame. Never ever disconnect the earth ground connection of a mains powered scope, significant risk of electrocution exists if you do so. That not mentioning that the measurements will be screwed up anyway by the large common mode currents.
                                      An alternative is differential probing like you mentioned. But if you only got one channel on your scope it obviously won't work.
                                      A working TV? How boring!
                                      • godin
                                        • Dec 2011
                                        • 34
                                        #79
                                        Re: Oscilloscope
                                        Yes it is completely open circuit from input to output
                                        • godin
                                          • Dec 2011
                                          • 34
                                          #80
                                          Re: Oscilloscope
                                          I thought I understood this now, but I still do not understand the reason for this.
                                          Would you mind explaining please?
                                          Many thanks
                                          • skwarszczow
                                            Macbook Pro A2141 020-01700-A GPU Artifacts then no S5 rails
                                            by skwarszczow
                                            This is my first post on the forum
                                            I recently purchased a MacBook A2141 from a colleague at work, which had issues with the dedicated GPU. The system occasionally displayed artifacts on the screen and sometimes experienced kernel panics related to the GPU. Interestingly, applying pressure to the VRAM module would temporarily resolve the artifact issues, which made me optimistic about the ease of repair.
                                            Board: 020-01700, Config: Intel i7, 512GB SSD, 16GB Ram.
                                            Before completing the purchase, we decided to erase...
                                            03-23-2025, 06:04 PM
                                          • prodigy83
                                            MacBook Pro M1 Pro Logic Board 820-02100 Mosfet where to purchase?
                                            by prodigy83
                                            My reference only: TT10141.
                                            Problem: I need to purchase a mosfet chip from board 820-02100 M1 Pro, that is supposed to be Q5820 but according to Digikey, the schematic diagram I sent them, neither are relevant to the actual mosfet specification I sent them. I just basically need to find this mosfet to purchase, I cannot find it anywhere and am hoping someone could point me in the right direction without have to purchase this entire allusive board. Already checked with Digikey, Mouser, Aliexpress, eBay. Any suggestions?
                                            Mosfet specs are as follows:
                                            Chip markings:...
                                            03-12-2024, 01:38 PM
                                          • Evets
                                            Dynamco analogue oscilloscope
                                            by Evets
                                            I have recently acquired a Dynamco D7100 analogue oscilloscope without a user manual. As this is the first time I have owned or used an oscilloscope I would like to try and find an instruction book. The manufacturers no longer hold any information and a Google search only found one site but when I downloaded a 'service manual' all I got was gobbledegook. Any help would be gratefully appreciated or even pointers to a generic manual where I could learn more.
                                            08-30-2024, 06:54 AM
                                          • SolomonMan
                                            Vintage BK Precision 1403 Oscilloscope....
                                            by SolomonMan
                                            All,
                                            Some of you have helped me in the past and I am very appreciative of all the help! (I have fixed TVs/Stereos/ and other small appliances with your efforts...Thanks so much!!!
                                            Today I went to a local HAM Radio Festival. It was one of the smaller ones in our area. My stepfather is the HAM operator. I tinker in electronics but am a Software Programmer (27 years now).
                                            I was looking for a few odds and ends for some electronics work I have to do for the household/farm. Typically these type of shows have the grab bags or a electronics vendor...
                                            12-03-2023, 10:39 PM
                                          • rive.hafintosh
                                            HP Probook 650 G4 - Lost power?During AMT de-provision process, now I get blackscreen
                                            by rive.hafintosh
                                            First here is how things went down.
                                            I entered the bios and began to de-provision Intel AMT - it began with a reboot and then prompted me to de-provision AMT - proceed Y/N -
                                            I pressed Y and hit enter, and I thought the PC shutdown, but perhaps it actually lost power at this point. I had the power adapter plugged in but apparently the plug from the wall came out of the brick when I wasn't noticing so 1 of two things could have happened…
                                            Something went wrong with the process, or it lost power during the process and corrupted something
                                            I tried making a HP recovery...
                                            10-12-2023, 07:42 PM
